JFR Equal Length Y-Pipe for 2nd Gen Tacoma, T4R, & FJ Cruisers
Discussion in 'Performance and Tuning' started by Roostfactor, Nov 17, 2018.
  1. Jun 20, 2019 at 11:26 AM
    #1281
    Roostfactor
    Roostfactor [OP] Well-Known Member
    TX panhandle
    2015 DCSB OR Pyrite Mica
    HPT/justDSM tuned factory ecu, URD Headers, JFR Y-Pipe/l 3" exhaust, Walbro 255 fuel pump, Maggy SC (JFR ported), JFR ported lower intake manifold, 76mm tb, 2.5 pulley, 640cc injectors, CSF Radiator, custom electric fan wit Autocoolguy controller, JFR SC pulley wrap mod
    Sounds great man! Thx for posting!
    Just enough growl but not loud at all, at least from the sound clip.
    BassAckwards[QUOTED] likes this.
  2. Jun 20, 2019 at 11:29 AM
    #1282
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Thanks brother! Really appreciate all your hard work, im loving how it sounds:cheers:
  3. Jun 20, 2019 at 11:41 AM
    #1283
    JacksonTacoma
    JacksonTacoma Well-Known Member
    James
    Jackson, MI
    2015 S/C TRD Pro
    Magnuson SC, 2.5 pulley, hptuner, FPR mod, AFE Intake, URD longtube headers, JFR Y-pipe, 255 Deatschwerks, 76mm TB, Banks 3" exhaust, cam gears
    Did you swapp the TRD CB muffler or add another one?
    Does anyone know who produced the TRD muffler?
  4. Jun 20, 2019 at 11:49 AM
    #1284
    loginfailed
    loginfailed Well-Known Member
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I think the TRD system manufacturer is Bosal.
  5. Jun 20, 2019 at 11:50 AM
    #1285
    BassAckwards
    I kept the TRD muffler and added a Borla to try and quiet things down. Had an aFe exhaust before this and it was stupid loud
    JacksonTacoma[QUOTED] likes this.
  6. Jun 20, 2019 at 12:14 PM
    #1286
    JustDSM
    JustDSM Oderint Dum Metuant
    Justin
    Ogden, UT
    It's official. I need one of these! John, can you put me on the list :)
    I'd like mine to have 2 bungs in stock location w/ 1 post merge, 2.5" collector, 2.5" v-band, flex, cat, res, 6" extension.
  7. Jun 20, 2019 at 1:23 PM
    #1287
    Roostfactor
    TX panhandle
    You got it buddy! I'll add you when I get to my comp. It's about time!
  8. Jun 20, 2019 at 3:12 PM
    #1288
    DiamondW
    DiamondW Stockblocker
    Kent
    Gonzales Co. TX
    ‘06 AC SR5, ‘17 Tundra, ‘14 GX460
    It is about time lol. And now I’m not last on the list!
  9. Jun 20, 2019 at 3:43 PM
    #1289
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    TacoLeeSD, elnip, ajohnson and 7 others like this.
  10. Jun 21, 2019 at 11:07 AM
    #1290
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That pulls hard!
  11. Jun 21, 2019 at 12:12 PM
    #1291
    Roostfactor
    TX panhandle
    Probably one of the fastest FJ's around! Not many sound like that either!!!:D:thumbsup::D
    BassAckwards and DocME[QUOTED] like this.
  12. Jun 21, 2019 at 12:16 PM
    #1292
    Roostfactor
    TX panhandle
    JacksonTacoma and DiamondW like this.
  13. Jun 21, 2019 at 2:29 PM
    #1293
    JacksonTacoma
    James
    Jackson, MI
    2015 S/C TRD Pro
    No apology needed. Thank you, Roost!
  14. Jun 21, 2019 at 2:35 PM
    #1294
    Roostfactor
    TX panhandle
    Thanks for your understanding!
  15. Jun 23, 2019 at 10:19 AM
    #1295
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I have URD headers and I originally installed the O2 sensors in the upper bungs. I didn’t know about extension harnesses to mount them in the lower bungs to read each cylinder, and now I want to move them but it looks like the auto transmission cooler lines are in the way on the passenger side. If it does fit, I would have to unbolt the header from the head to install the sensor. Has anyone mounted them in the lower bungs with an auto transmission?
  16. Jun 23, 2019 at 10:56 AM
    #1296
    Roostfactor
    TX panhandle
    Mine clears. It runs in between the two cooler lines.
    Some have had to loosen the line and/or bend it out of the way. Be careful not to crease the line!
  17. Jun 23, 2019 at 11:17 AM
    #1297
    loginfailed
    Dwayne
    Houston, TX
    2014 DCSB 4WD
    I bent my lines a little bit and the sensor clears. It’s been like that for a year or two with no issues.
  18. Jun 23, 2019 at 11:21 AM
    #1298
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Bending is not a problem. :D
    loginfailed likes this.
  19. Jun 23, 2019 at 11:23 AM
    #1299
    Roostfactor
    TX panhandle
    How dare you say that!
    Speaking of which, here is my extremely custom crossmember clearance I did yesterday.....
    BassAckwards, elnip, Hawk373 and 5 others like this.
  20. Jun 23, 2019 at 11:24 AM
    #1300
    Roostfactor
    TX panhandle
    Look familial @loginfailed? We did your y-pipe similar to this.
