jhcole's Build Thread - 2015 DCSB 4x4 TRD Off Road
Discussion in '2nd Gen. Builds (2005-2015)' started by jhcole, Dec 31, 2014.
  1. Feb 10, 2016 at 5:22 PM
    #121
    ArtyBlaydes
    ArtyBlaydes Well-Known Member
    Arthur
    North AL
    2012 Toyota Tacoma TRD offroad DC
    So Since you have had time to drive around quite a bit. What is your thoughts on not running UCA's ? Any problems since installing the lift ? Any feed back would be cool BC I'm about to order the same lift except I'll be running OME 885's which are similar to the 521600 toytec coils. LMK neighbor
  2. Feb 29, 2016 at 4:49 PM
    #122
    pa blaster
    pa blaster Well-Known Member
    Scott
    central pa
    2024 GMC Canyon AT4X AEV
    If you don't mind could you get a center hub to bottom fender measurement I'm just curious I'm at 22.5 up front thanks
  3. Mar 5, 2016 at 12:00 PM
    #123
    atxwrangler
    atxwrangler Member
    martin
    South texas
    2014 crew cab long bed 4x4
    None so far, have 5100s for front, toytec add a leaf for back. Not installed
    Nice truck for sure! I am installing the 521600 springs with 1/4 spacers just to try and make sure i dont have alignment issues with my 2014 cc. So, am i to understand from what i have read, that you used the 521600 coils and 1/2 spacers, with no correction for driver side lean?thanks for this thread....
  4. Mar 6, 2016 at 9:42 AM
    #124
    lawrenccar1
    lawrenccar1 Well-Known Member
    Springfield, Virginia
    2015 4x4 DCSB TRD Off-Road
    subbed...
  5. Aug 18, 2016 at 10:22 AM
    #125
    m.reed.1
    m.reed.1 Well-Known Member
    Adam
    Sacramento, CA
    2015 MGM TACOMA TRD OFFROAD 4WD
    A few
    HAIL STATE! We will have to meet up next time I come home to the south!
  6. Jan 5, 2017 at 5:01 AM
    #126
    danronian
    danronian Member
    Dan
    2015 Gray SR5 Double Cab 4X4
    Great build! I love the stance. I'm going with the same tire size soon.
  7. Mar 24, 2017 at 11:31 AM
    #127
    jhcole
    jhcole [OP] Well-Known Member
    Hunter
    Birmingham, AL
    '15 DCSB 4x4 TRD-OR MGM
    ToyTec 3" w/ Bilstein 5100's
    Haven't posted in awhile but wanted to share some photos after finding a great bargain on a used Leer 100R w/ windoors and adding Yakima bars:
    Srice57 likes this.
  8. Jun 19, 2017 at 2:58 PM
    #128
    TAC1
    TAC1 Well-Known Member
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello @jhcole,
    Very nice build! I read all of the posts on your thread over the last few days. I found this post because I am researching different suspension options for my next truck. I currently have a 2008 SR-5 Prerunner DCSB (owned it since January 2012, excellent truck) & my wife & I bought a 2016 4Runner Trail for her last September. I plan to sell my truck by the end of this year & will be purchasing a 2015 4x4 DCSB SR-5, Off-Road, or Sport. My Prerunner has a Maxtrac Spindle lift & I know that for a 4x4 that won't work.
    I like your set-up very much. Only thing I will change for me is that I may just install the front springs without the 1/2" spacer. I am basically just looking for 2"'s of lift front/back. I'm also deciding between the Ivan Stewart wheels (PTR20-34070) with 265/75r16 "E" BFG A/T K02's or a set of 17" 7-spoke 4Runner Trail wheels (like the ones on my wifes 4Runner) with 265/70r17 "C" BFG A/T K02's .
    Has your suspension settled over time? Are you still at 2.75"'s of front lift?
    I know that I can set the 5100's at 1.75 with the OEM springs & a 1/4 spacer but that will shorten the spring travel & may ride more stiff than using lift coils with 5100's at "0".
    I read that you have a bit of take-off vibe. I've had it for over 5 years & 96,000 miles. I've driven to the Smoky Mountains a few times, Atlanta, Stone Mountain, GA. I live in Miami so you can imagine the mileage driving to those places, HAHAHAHA. I also have a 3/8" CB drop spacer installed. My PreRunner is lifted 4"'s out back & 4.5"s out front. The take-off-vibe hasn't damaged anything & no one ever notices it so it's minor.
    Thank you
  9. Jun 20, 2017 at 12:51 PM
    #129
    RadRed06
    RadRed06 Christ Follower
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    I have the same springs. I am currently sitting at 2'' of lift WITH a 1/2'' spacer. I also have shrockworks sliders (same sliders the OP has) that may have brought the front down a tad. Moral of the story, put the spacers in because without them you'll get less than 2''. I don't really know where Toytec got their 2.5'' numbers from to be honest.
    TAC1[QUOTED] likes this.
  10. Jun 20, 2017 at 5:36 PM
    #130
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    Hello @RadRed06,
    Not doubting what your saying but could it be possible that you have the ToyTec 1.6" springs instead of the 2.5" springs? Just asking since OP stated that 8 months after the initial install his truck is at 2.75"'s of lift up front with the spacer as well. How long have you had your springs on your truck?
  11. Jun 20, 2017 at 5:41 PM
    #131
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    @RadRed06 , I just saw your build. Truck looks awesome & the scenery is beautiful!
  12. Jun 21, 2017 at 3:04 PM
    #132
    RadRed06
    Daniel
    Flowood, MS
    '12 Pyrite 4x4 OR
    Lifted on 33s
    Thanks! Unless they printed the wrong number on the coils mine are the 521600 2.5''. Maybe I just got a bad set, I'm not sure, but thats my personal experience with them. Ive been running them for around two years.
  13. Jun 21, 2017 at 10:08 PM
    #133
    ItsRichieRich
    ItsRichieRich Well-Known Member
    Richard
    Temecula, CA
    '13 Ford Raptor
    Looking good OP!
    TAC1 likes this.
  14. Jun 22, 2017 at 7:25 AM
    #134
    TAC1
    Tac1
    Miami, FL
    2015 DCSB O/R 4WD
    If that's the number posted then that's good enough for me. Hahhaah. Every truck seems to be a bit different.
    Yesterday I saw a Tacoma at my job with Bilstein 6112's at the 3rd setting (about 2"'s for a 4x4) and the guy said he's very happy with them. I may look into those as well
