Jiffy Lube for Differential Fluid exchange
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ScrippsRanch67, Feb 7, 2024.
  1. Feb 7, 2024 at 9:53 PM
    ScrippsRanch67
    ScrippsRanch67 [OP] Well-Known Member
    Bob
    06 Tacoma Pre-Runner 2wd Quad Cab short bed
    Fiberglass shell
    Yes or No on using Jiffy Lube for differential fluid exchange?
  2. Feb 7, 2024 at 10:19 PM
    cbouch001
    cbouch001 Well-Known Member
    Charlie
    PNW
    2020 SR5 Taco
    OTT Tune, Bilstein 5100 with Icon RTX, SCS F5 , ARB Recovery point, MBRP Exhaust
    Honestly I’d do it yourself if you have the means to. There’s lots of info on here and YouTube . It’s not difficult , and you’ll have , I think , a little more peace of mind.
    Just my 2 cents
  3. Feb 7, 2024 at 10:23 PM
    Vance4
    Vance4 Member
    I guess it depends on the specific Jiffy Lube, but I am very particular about who I will let work on my truck. I prefer the smaller independent shops. I still research the crap out of them to be sure. I just don't trust the quick places in general. I've heard too many horror stories. I would check lots of reviews on the specific location and go from there.
    oldtimertoyota and cbouch001 like this.
  4. Feb 7, 2024 at 11:04 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    At what price?
    Some guys will be along just to bash Jiffy.
    Some guys will bash you for not wanting to do it yourself.
    Give use the quoted price, we can help you more once we know the price.
    ZMan2k2 and oldtimertoyota like this.
  5. Feb 8, 2024 at 12:53 AM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
  6. Feb 8, 2024 at 1:17 AM
    TacoTuesday1
    SD CA
    Yes.
    -they destroy part
    -I get paid to replace
    -easy job, many hours, music headphones
    win win
  7. Feb 8, 2024 at 4:48 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
  8. Feb 8, 2024 at 5:10 AM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
  9. Feb 8, 2024 at 5:47 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    TRD Pro Grille, Skid Plate, TRD Cat-Back Exhaust System, 2017 Tacoma TRD Rims, ARE Series II Lid,
    I wouldn’t use Jiffy Lube for any services.
  10. Feb 8, 2024 at 5:52 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    I recently did mine, not a bad job, with minimal automotive skills you’ll have no problem, you’ll save a lot of money and know that it’ll be done correctly
  11. Feb 8, 2024 at 6:13 AM
    Waasheem
    Waasheem
    2007 xrunner
  12. Feb 8, 2024 at 9:09 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    On an 18 year-old truck, the shop needs to be equipped to deal with the situation if the drain plug with the shallow 24mm wrench flats is rounded off, with a torch, welder, etc. May be better to go to an indie shop that does general auto repair.
    TireFire likes this.
  13. Feb 8, 2024 at 9:11 AM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
  14. Feb 8, 2024 at 9:29 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Jiffy Lubes have a proven track record of screwing things up... either do it yourself or have it done by a real mechanic.
  15. Feb 8, 2024 at 9:50 AM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I’m pretty sure even at jiffy lube they teach them to open the fill plug first.
    Clearly, OP is asking because he doesn’t wanna do it himself. I’d have no trouble using a quick lube place as long as they let me watch (no puns intended).
    Edit: most will even let you bring your own lube and only charge you labor.
    ScrippsRanch67[OP] likes this.
  16. Feb 8, 2024 at 9:56 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I say No but it comes down to you.
    I was instructed to use them for the company Truck .
    First time they ruined the engine oil drain plug .
    I would use an independent shop that knows Toyota`s
    Good luck
  17. Feb 8, 2024 at 10:07 AM
    motolife313
    motolife313 Well-Known Member
    They change oil all day. I think they would do a good job.
  18. Feb 8, 2024 at 10:08 AM
    Thomas Jefferson
    Sacramento,CA
    '13 SR5 DCSB 4x4
    Hopefully they don't pump 5w-30 into your rear differential.
    ScrippsRanch67[OP] and Bivouac like this.
  19. Feb 8, 2024 at 10:43 AM
    agmason
    agmason Well-Known Member
    Austin, Texas
    2007 Prerunner 4dr LWB
    But think about how much more efficiently it will spin! Got to be worth 0.1/mpg. But what about 0w20....
  20. Feb 8, 2024 at 3:34 PM
    Williston
    Williston Unknown Member
    New England
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    My biggest worry getting it done there would be they might remove the drain plugs first, before they first verified the fill plugs could be removed, or that they would strip/round out the front diff allen key hole plugs trying to remove them. (even if I had mentioned these things to them prior)
