JL 1000/1 under rear seat
Discussion in 'Audio & Video' started by mrmumbels, Dec 11, 2010.
  1. Dec 11, 2010 at 7:45 AM
    mrmumbels
    mrmumbels [OP] Well-Known Member
    Land O Lakes, fl
    09 prerunner
    none
    Has anyone managed to fit this amp under here? I need 1 more inch :/
  2. Dec 11, 2010 at 10:05 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    What if I cut this metal? Looks like it's double layered here. My amp would slide right down perfect.
    BTW this is the compartment under the rear seat without the plastic in place.
  3. Dec 11, 2010 at 10:07 AM
    elblako91
    elblako91 Well-Known Member
    Blake
    Lubbock/Houston/Katy
    1992 Toyo Pickup
    Just wondering if you should be thinking of the cooling efficiency of the amp. It seems that the amp would be in a pretty confined spot and wouldn't be able to vent off heat well enough.
  4. Dec 11, 2010 at 10:25 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    It'll be fine. It'll be bolted to metal on all sides and it's actually pretty open under there. The guy I bought the amp from had it enclosed in an mdf box with another jl amp and only a 1.5 inch hole for air with no fans running a jl 13w7 and it never overheated.
  5. Dec 11, 2010 at 10:34 AM
    elblako91
    Blake
    1992 Toyo Pickup
    If by cutting that piece of metal it would make it fit then go ahead and do it but if you ever plan on taking the amp out and selling the truck that might affect the value of the truck. Just a thought :)
  6. Dec 11, 2010 at 10:57 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    That's the thing. If I ever sell the truck I'll
  7. Dec 11, 2010 at 10:58 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Put the plastic back and it'll be hidden :)
  8. Dec 11, 2010 at 10:59 AM
    elblako91
    Blake
    1992 Toyo Pickup
    Oh ok I understand then yeah go for it! Just be sure it fits before you bust out the Saw-All and don't get too carried away lol :D
  9. Dec 11, 2010 at 4:12 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    .....or you could sell that amp and buy a PDX1000.1 or an HD750/1 and make your life a hell of a lot easier.
  10. Dec 11, 2010 at 8:35 PM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    I cut it. If looks perfect and I can even keep my jack in it's original spot.
  11. Dec 13, 2010 at 8:18 AM
    rscecil007
    rscecil007 Well-Known Member
    Seattle
    06 4x4 TRD Sport Access Cab
    Goodyear Duratracs 265/70R17's, Bed mat & extra d-rings, Weathertech floor liners, Husky Liner for rear seat area, Biceman Illuminated 4x4 Switch, Pioneer 800 PRS, Hybrid Audio L6 and L1V2, JL 13TW5 in a Mr. Marv box, JL HD900/5
    Some guy on here, not sure who, did an amazing install with two Orions in the location you put yours with cooling fans and all. Maybe IS remembers the guys name or has the thread bookmarked.
  12. Dec 13, 2010 at 8:32 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
  13. Dec 13, 2010 at 9:32 PM
    supersuk
    supersuk Well-Known Member
    Honolulu, HI
    2010 Dcab TRD Sport Magnetic Gray
    Sounds!
    I was able to fit a 300/4 under the passenger seat, but that 1000/1 is way too big. Nice job on the install of the amps! Now you just have to make a trip for it so that it has a finished look.
  14. Dec 16, 2010 at 4:08 AM
    YP4269
    YP4269 Active Member
    SOUTH LOUISIANA
    06 PRERUNNER
    20" rims, pioneer 4200 DVD, 2- 11" screens in head rest, 2 jl 12w1s, jl 1000/1 for subs jl 300/4 for highs. Alpine 6 1/2" components in front and Alpine 3 way 6 1/2" in back. Also bunch of other stuff to come as time permits.
    Looks good brother. I have just about the same set up. I put a fan on either side on the front corners of the storage box. Keep the pics coming. Great work
  15. Dec 16, 2010 at 5:38 AM
    ItalynStylion
    Steven
    DFW, Tx.
    Lovely. Way to go the extra mile. Now clean it up and make it nice! :)
  16. Dec 16, 2010 at 5:41 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Funny, I found a set of IDQ 12's on craigslist right down the road that I'm going to possibly pick up today.
  17. Dec 16, 2010 at 5:47 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    Hmm, I thought you said you had IDQs but I just saw a pic with JL subs...
  18. Dec 16, 2010 at 5:57 AM
    hmasonb34
    hmasonb34 Well-Known Member
    Heath
    Jax, Fl.
    98, ext cab and 2015 LB dbl cab 4x4 sport
    My 98 has 4 in.beefed blocks, QA1 up front, turbo. My 15 4x4 stock looking for lift and tires.
    wow that looks good just make a 1/4 inch baffle board to cover everything and carpet it and use some screws or velcrow to hold it down and your done they fit perfect.
  19. Dec 16, 2010 at 6:02 AM
    montgomery_30824
    montgomery_30824 Well-Known Member
    Lee
    Guyton, Ga
    '06 prerunner 4dr
    K & N airfilter, custom built 10" sub boxes, pioneer head, mag-lite mod, Blue LED dash lights, custom painted engine cover, mud flap removal mod, alarm/remote start installed,
    this is a great looking install. X100 on the trim piece to make it look neat.
  20. Dec 16, 2010 at 6:02 AM
    mrmumbels
    Land O Lakes, fl
    09 prerunner
    none
    surrounding the tops of the amps you mean? I'll probably have to put fans if I do that. I'll pick some up today and test it out once I get it all finished.
