JL Stealthbox 2005+ install
Discussion in 'Audio & Video' started by mr smitty, May 20, 2010.
  1. May 20, 2010 at 6:42 PM
    mr smitty
    mr smitty [OP] Well-Known Member
    Tennessee
    09 prerunner sport
    Westin Chrome running boards Rough Country 3" lift 17x9 motometal 951 chrome mickey thompson baja atz 285/70 17
    Hey guys I just got my jl stealthbox in today it looks great. I plan on doing this install with the help of my dad and doing a write up on it. Il be adding the stealthbox with 2 10" w1v2 8 ohm speakers wired to 4 ohm and 600w rhm power 1200w max. Il be putting an alpine pdx-m6 amp with 600wx1 rhm power and 1200w max at 4 ohm to match the subs just right and not major drain the battery. Il also be adding a bass knob for easy control in the driverseat and using a stinger amp wiring kit and the lineoutput from the radio and stinger wire to reach the amp at the back. Pics will be up when the install is under way but iv got to get everything in first
  2. May 20, 2010 at 8:48 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
  3. May 21, 2010 at 12:29 PM
    mr smitty
    Tennessee
    09 prerunner sport
    So today I got my stealthbox in from florida and the alpine amp in from california. Still 6 days before the wires to hook it up will come but im making the preparations for the install right now just pulled off the back plastic that il have to cut for the box and im figuring out how I want to mount this amp to look clean behind the rear driver side seat
  4. May 21, 2010 at 1:03 PM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
  5. May 21, 2010 at 1:18 PM
    toyotacoma
    toyotacoma Member
    Fort Collins
    07 Prerunner SR5
    Kenwood Excelon X-592 Custom TRD Badges
    +1
  6. May 21, 2010 at 1:19 PM
    Maintenance Man
    Maintenance Man Well-Known Member
    Justin
    Atlanta, Ga
    05 Tacoma Pre-runner SR5 2.7L
    Leer camper shell; afe stage ll intake; 265's bridgestone dueler tires; rockford's power series 6.5's; tint on all windows; semi de-badged; weathertech digitial mats; grillcraft grill; blacked out headlights with eyelids; blacked out badges; and more to come.
    +2
  7. May 21, 2010 at 1:20 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    damn...that set up must have cost you an arm and a leg!
    Can't wait to see it done
  8. May 21, 2010 at 1:22 PM
    mr smitty
    Tennessee
    09 prerunner sport
    im working on it haha
  9. May 22, 2010 at 8:58 PM
    mr smitty
    Tennessee
    09 prerunner sport
    1. First thing i did was remove the backs of the rear seats.
    The bolts holding the backs to the fold down seats are located under the plastic cover on each corner
    to do this you will need a 14mm socket
    remember that the middle seat seat belt is bolted down also
    2. now be gentle and slowly pull the plastic snaps off from both sides of the plastic
    3. unfasten the two plastic pieces in the middle this is the challenge because it requires force but not too much because it is plastic and could damage the plastic
    4. you are left with the bare metal and two individual plastic pieces
  10. May 22, 2010 at 9:05 PM
    mr smitty
    Tennessee
    09 prerunner sport
    i decided that the metal hooks might get in the way so i removed them from the middle support bar
    each bracket is welded on in three visible spots
    the cleanest way to remove these is to get a drill bit larger than the spots and drill out the weld
    once you drill out these three holes they are easily removed
  11. May 22, 2010 at 9:10 PM
    mr smitty
    Tennessee
    09 prerunner sport
    the next thing to do is to follow the jl audio instructions on trimming the passenger side plastic piece.
    i took a cutting wheel and made the specified cuts to make the box fit
    once i went back over and smoothed the edges i test fit the box and it fit just right
  12. May 22, 2010 at 9:17 PM
    mr smitty
    Tennessee
    09 prerunner sport
    to attach the box to the truck a bolt is attached to the truck
    a hole must be drilled through the back metal wall
    to mark the spot wax paper is applied to the right of the second bracket and the subs are pushed against the wall to mark the drill hole
    once the hole is drilled, insert the subs
    now that you have the bolt sticking out of the cab, get under the truck and put the 3 washers and nut on it and tighten until firmly attached
    to insure this will not slip or rattle i applied a dab of silicon over the connection and in the gap before the washers and nut were put on
  13. May 22, 2010 at 9:28 PM
    mr smitty
    Tennessee
    09 prerunner sport
    so now i have the stealthbox in and ready to go and im making the preparations to mount the amp and still have room for a second amp for the future speaker improvement
    today i only had time to put the first metal bracket onto the truck behind the driverside seat to hold the amp
    tomorrow i should have the plastic trimed and the amp mounted
    still waiting for all of the wiring to come in
    some will come monday and the other wires are expected thursday
    more to come
  14. May 24, 2010 at 9:00 PM
    glandnut
    glandnut Reserve Squirrel Hair
    Florida
    16' 4Runner TEP, 01' Ext cab 4x4
    secret stuff.
    Interesting, I never knew JL had you drilling a hole through the back cab wall in order to secure that Taco box. Crazy. Nice PDX, I'm waiting for the second gen PDX-5 to surface myself.
  15. May 24, 2010 at 9:27 PM
    mr smitty
    Tennessee
    09 prerunner sport
    so i finished up the metal brackets and covered them in felt on front and back and screwed them in and put silicon over the ends to ensure they wont rattle any
    on the brackets, the top screws just mounted into the bottom of the top back brace
    the screw into the middle bar was cut to be flatter and i cut partially into the brace with a larger drill bit in order for the screw to sit more flush agaisnt the brace
    now that the braces are down, i mounted the amp with metal screws into the braces
    the amp is mounted securely down and the plastic is put back in place over it
  16. May 24, 2010 at 9:39 PM
    mr smitty
    Tennessee
    09 prerunner sport
    today in the mail i got my pac 35 line output converter and my stinger dual 17ft RCA wire kit
    the first thing i did was remove the driver side wiring pannels that include:
    the drive door floor, driver side rear floor, head unit, and kick pannel next to the plastic foot rest
    i ran my wire from the head unit to the rear using a metal wire hanger that i bent into a hook to pull the wire through this was fairly easy it just took some time
  17. May 24, 2010 at 9:41 PM
    mr smitty
    Tennessee
    09 prerunner sport
    thanks man i really like the looks of it but i cant wait to hear how it sounds once i get it all going
  18. May 24, 2010 at 9:48 PM
    mr smitty
    Tennessee
    09 prerunner sport
    so here was the speed bump, the line output converter to a stock head unit
    i did some research and didnt find much specific information about the exact wiring on the plugs running into the radio, but i did find some general toyota plug information and it matched my plugs perfectly so i went with it
    to the line output i spliced into the right rear +, right rear -, left rear +, and left rear -, and also the ground
    locating these wires was easy once i found the proper information on the specific wires
    although it looks messy, it will work, is secure, and is easily undid for when i decide to go on with a new head unit
  19. May 24, 2010 at 9:49 PM
    mr smitty
    Tennessee
    09 prerunner sport
    now tomorrow my stinger 4 gague amp wiring kit should come in and il be able to power everything up and put things back in their place until the bass knob comes in
  20. May 25, 2010 at 6:52 AM
    hookedontronics
    Jake
    Glenville, NY
    You should use connectors made for 12v. Replace those with some splices.
