Jlee's BAMF expo trailer build
Discussion in 'Other Builds' started by JLee, Mar 18, 2014.
  1. May 4, 2014 at 7:06 PM
    #201
    avw4x4
    avw4x4 Well-Hung Member
    (M)Andrew
    Rochester, NY
    2003 Yota
    ...loading....
    Looking real good man! Plating really pulls it together!
  2. May 4, 2014 at 7:13 PM
    #202
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Looking great Jerry!
    I ran the controller this weekend on the way to Jambo towing a 3300lb trailer. I only had one complaint about the controller. When you completely let off the brakes at low speed the trailer brakes would releas slightly after the truck brakes. That makes for a small bump forward from the trailer.
    The controller is extremely easy to adjust to the trailer. If you change the weight you can easily adjust the amount of brake pressure. I'd say you can't go wrong with it.
  3. May 4, 2014 at 8:00 PM
    #203
    JLee
    JLee [OP] The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Sweet thats the one I went with.
  4. May 5, 2014 at 7:08 AM
    #204
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Jerry I'm wondering why you skinned the inside rather than the outside?
  5. May 5, 2014 at 7:16 AM
    #205
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I was wondering the same thing actually. Looks great regardless, just curious as to why you made that decision.
  6. May 5, 2014 at 7:18 AM
    #206
    V5ioV
    V5ioV My drinking team has a wheeling problem
    V5ioV
    Out n 'bout
    '13 Pewp Water Slut
    King 2.5 Rem Resi Ext Travel w/comp adj w/700# springs, TC Uni-Ball UCAs, ARB/OME Dakar Leaf Springs w/ King 2.5 Rem Resi w/comp adj and custm eyelets, Stealth Custom Series F-5 Wheels wrapped on: 285/75/16 Fierce Attitudes, BORA 2.25 wheel spacers, GOODRIDGE extended Brake lines, Triple-6" Double Row LED Light Bars behind lower grill, ATFL MOD, TRD Ball Type Shift Knob, Husky WeatherBeater Floor Liners, 60'' HiLift Xtreme, 4xInnovations Bolt-On Sliders w/Kickout, Spring Hanger Skid, Custom BlackPipe Fabs CMC and custom FYL Bed Rack, CVT Mt. Shasta RTT, Trasharoo, 4xInnovations HiLift Bedside Mounts, 4xInnovations Front Skid Plate, TOYWERX Ghost Raptor thin-lip Satoshi Grill, RedLine Hood Struts, 4xInnovations Transmission Skid and T-Case Skid Plates, Wheelers Rear SuperBumps Bump Stops, All-Pro Off Road U-Bolt Flip Kit, UltraGauge, ARB OBA, Pelfreybilt HC rear Bumper, Rotopax system (Single Mounting Plate and Bed Rail Mounting Plate both with LOX handles.
    Maybe to have flat surfaces
  7. May 5, 2014 at 7:26 AM
    #207
    JLee
    Jerry
    Grass valley CA
    I planned no skinning the outside when I put it up there i just didn't like it. I think it was just too long of one flat piece it looked odd to me I liked it much better with the tube exposed and the sheet on the inside. Maybe if the sides had a bend or two it would of looked good to me but i just didn't like it. Also having the tube on the out side leaves more options for mounts. And no matter how careful you are 16 gauge will ripple some from welding and this hides the slight ripple that's in the sheet after welding.
  8. May 5, 2014 at 7:28 AM
    #208
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    what are your planns for seal meaterial on the door?
  9. May 5, 2014 at 7:29 AM
    #209
    JLee
    Jerry
    Grass valley CA
    Automotive door seals i just need to find the right style.
  10. May 5, 2014 at 7:41 AM
    #210
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    how do you plan to attach them to the tube? hardest part on my trailer is keeping the door watertight. looking for ideas for when the rebuild comes. i was thinking aor marine door seals, but their attachments methonds can make it tough to use depending on the type.
  11. May 5, 2014 at 8:04 AM
    #211
    JLee
    Jerry
    Grass valley CA
    Just a strip of sheet metal attached to the tube to slide over like you would a pinch weld on a car.
  12. May 5, 2014 at 8:46 AM
    #212
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I like that you skinned the inside for that very reason. Your trailer is a lot taller and the tube breaks it up nicely.
    FWIW, I just stitch welded the skins. No ripples. Just ran seam sealer inside and out to keep the elements out.
  13. May 5, 2014 at 9:16 AM
    #213
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I agree. Plus, inside, you still get the sense of badass whereas a giant box is just a giant box.
  14. May 5, 2014 at 9:30 AM
    #214
    JLee
    Jerry
    Grass valley CA
    Yeah I really like it like this it's all about contrast!
    I staggered single tacks on the panels at least a foot apart. I could touch the first tack with a bare hand by the time i got back to it. I panels didn't warp too much I mean I can see it but most wouldn't and I'm coating it with a matte silver texture so it will be even less noticeable. The tube is what moved a lot seeing how the top is not attached they just moved in as I tacked. If I can't push it back out I'll just weld the top on and say fuck it!
  15. May 5, 2014 at 9:43 AM
    #215
    romeo
    romeo Wombat
    Luis
    Lacey, Wa
    Silver 4x4 DC Sport
    Are you going to paint it any special color?
  16. May 5, 2014 at 9:46 AM
    #216
    JLee
    Jerry
    Grass valley CA
  17. May 5, 2014 at 10:03 AM
    #217
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    I expect nothing less from Jerry. lol trailer could survive the apocalypse.
  18. May 5, 2014 at 8:24 PM
    #218
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    So sick... she looks like a beast!
  19. May 6, 2014 at 7:42 AM
    #219
    Lil'Taco
    Lil'Taco Well-Known Member
    Scotty
    Wilsonville
    2010 PreRunner Sport DCSB
    Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Decked Drawer system, aFe CAI, Borla Cat-back exhaust, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts, Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights... It has more stuff done to it now.
    So no sort of fenders on it at all?
  20. May 6, 2014 at 8:24 AM
    #220
    JLee
    Jerry
    Grass valley CA
    One thing at a time man I haven't got to them just yet.
