Job: Replacing Head Gasket
Discussion in 'Technical Chat' started by timberguy, Oct 8, 2009.
  1. Oct 8, 2009 at 5:21 PM
    timberguy
    timberguy [OP] New Member
    96 tacoma 3.4 4x4
    Howdy, I am gearing up to replace head gaskets on my 96 tacoma 3.4l. I would like to get some dos and don'ts from experienced people that have done this work in the past. Any information is helpful. Thank you.
  2. Oct 8, 2009 at 5:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can download the FSM for your truck .
  3. Oct 8, 2009 at 6:27 PM
    timberguy
    96 tacoma 3.4 4x4
    Super; thanks!
  4. Oct 8, 2009 at 6:32 PM
    timberguy
    96 tacoma 3.4 4x4
    What is a "valve grind gasket kit"? What does one of these kits include?
  5. Oct 8, 2009 at 8:40 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    It would be all the gaskets you need to pull the heads and replace the headgaskets since you have to pull the heads to grind the valves.
    It's not a complete overhaul gasket set, but it would be pretty close.
    Marc M
  6. Oct 8, 2009 at 8:48 PM
    timberguy
    96 tacoma 3.4 4x4
    Dang, wrekin I'll be needn one of these. Any places with good OEM prices?
