Jumpy transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PacoTaco801, Oct 20, 2016.
  1. Oct 20, 2016 at 7:35 PM
    PacoTaco801
    PacoTaco801 [OP] Member
    2008 SR5
    Hello, I'm new to this forum. Hopefully I can get some help. So about two weeks ago I installed a cold air intake in my 08. It was way jumpy between gears and the "Check engine light" turned on. I thought it was the mass air flow sensor connection because one of the wires was worn out so I replaced it and cleaned the mass air flow sensor. It got a bit better and the light turned off but still jumpy. I had my dad take my taco to a mechanic he know he says it's the transmission. When he brought it back I checked the oil and it's still pink. I'm no expert on automobiles. I'm learning as I go but can you still have problems with good transmission oil. I bought this Taco 2 years ago from a toyota dealership and I never had any problems with it until I installed this cold air intake. Should I put the stock intake back in? Is anyone else having similar problems? Is it a more serious and expensive job? Please help me out.
  2. Oct 20, 2016 at 7:38 PM
    eon_blue
    eon_blue Most Improved Member
    If you haven't had any transmissions issues before, and the CEL and lurching issues happened right after installing a CAI, I think it's safe to say it's something to do with the CAI. That mechanic sounds sketchy to me. I'd get a 2nd opinion for sure, but first I'd try putting the stock air intake back on and seeing if that alleviates the problem.
    Also, if you have a bad MAF then cleaning it won't do much good, sometimes they just need to be replaced.
  3. Oct 20, 2016 at 7:44 PM
    PacoTaco801
    2008 SR5
    Alright. Thank you.
  4. Oct 20, 2016 at 7:46 PM
    eon_blue
    Have you pulled the code from the check engine light? Hopefully the mechanic did, did he mention what it was?
    Pabloeeto likes this.
  5. Oct 21, 2016 at 9:19 AM
    PacoTaco801
    2008 SR5
    The mechanic did not take any codes. He resetted somethings, by what I was told, and be teat drived it. He just said it's the transmission.
  6. Oct 21, 2016 at 9:21 AM
    eon_blue
    Ehhh, definitely take it to another mechanic. Reading the codes is the very first thing any mechanic should and would do. Especially if the code popped up after you put the CAI on, it's gotta have something to do with that. I'm guessing maybe a P0171/2 code.
  7. Oct 21, 2016 at 9:23 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    First thing to do is hook up a OBDII scanner and pull the trouble codes. Sounds like you have a misfire. I'm thinking the intake filter had too much oil on it and gunked up your MAF sensor.
    eon_blue likes this.
  8. Oct 21, 2016 at 9:26 AM
    PacoTaco801
    2008 SR5
    Thank you so much you guys. I'm hoping it's not the transmission but I doubt that it is.
  9. Oct 21, 2016 at 9:26 AM
    eon_blue
    I highly doubt it's the transmission either.
    If you take your truck over to Pep Boys or O'Reilley's they'll read the code for you for free with their scanner. Out here in CA, AutoZone apparently just stopped offering that as a free service but they might still in other areas. Or you could just rent one from them on a deposit and get it back when you return the scanner.
  10. Oct 21, 2016 at 9:29 AM
    PacoTaco801
    2008 SR5
    I'll try that for sure. It's easy to get a scanner. Thanks again.
  11. Oct 21, 2016 at 9:30 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Easy enough problem to trouble shoot, just reinstall the stock intake. If the problem goes away, it's the intake. If it doesn't go away, it's something else. Problem solving 101..
    Vince the prince likes this.
  12. Oct 21, 2016 at 9:34 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    i hate these "mechanic buddies" my experience is they are just morons...
  13. Oct 21, 2016 at 5:29 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Don't call me a moron, buddy.
  14. Oct 21, 2016 at 7:34 PM
    wake100
    Syracuse, NY
    Buddy, I see what you did there
  15. Oct 22, 2016 at 1:39 PM
    Hugh Morron
    Bill
    Poor attempt at humor, sorry for interupting
    wake100 likes this.
  16. Oct 22, 2016 at 1:47 PM
    Vince the prince
    Vince the prince Well-Known Member
    2006 Tacoma
    Was having similar problems with mine after a hard stop for some reason when I went to take of it hesitating for a sec RPMS when up as if it was in neutral when it grabbed it was enough to chirp tires after cleaning MAF it got a little better but still was there then I was told it was a $200 solenoid in the tranny pan I haven't gone after it yet but will this week
  17. Oct 22, 2016 at 1:54 PM
    Vince the prince
    2006 Tacoma
    What is the P0171/2 code ?
  18. Oct 22, 2016 at 2:44 PM
    wake100
    Syracuse, NY
    It's all good :cheers:
  19. Oct 22, 2016 at 2:50 PM
    eon_blue
    'System too lean bank 1 or 2'
    Its common with a bad MAF sensor or vacuum/exhaust leak
  20. Oct 22, 2016 at 3:12 PM
    Vince the prince
    2006 Tacoma
    Oh ok thanks .. sorry for the silly question
