just a little lift....
Discussion in 'Suspension' started by crytesy, Oct 11, 2008.
  1. Oct 11, 2008 at 6:55 AM
    crytesy
    crytesy [OP] Weekend Warrior
    Alberta
    2006 SR5 Tacoma
    Skid Plate, Undercover Tonneau Cover, PIAA FogLights, AIR RAID CAI
    Hello All!
    I would like to lift my Tacoma just a moderate amount (2" max). Are the levelling kits a good idea for the front end? I simply want enough room to put some larger tires on the vehicle but I am not sure what size would look and work the best?
    Has anyone completed light modifcations with regards to lift and tires??
    I am mostly a city dweller looking for a sharp appearance - I am not looking to intall mudders'.
    thanks
  2. Oct 11, 2008 at 7:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Check out the adjustable Bilsien 5100's. :)
  3. Oct 11, 2008 at 7:24 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You basically want to do the the same as I'm looking to do. The Bilstein 5100's are one option I'm considering but I'm also looking at top mount spacers like Hell Bent Steel: http://www.hellbentsteel.com/toyota_tacoma_leveling_kits.html They're cheap, easy to install (no spring compressor needed), and keep factory ride quality. So we'll see, I haven't decided yet but I definitely need to level no matter what. I hate the factory rake. Rakes are for leaves, not vehicles.
  4. Oct 11, 2008 at 7:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Those top load spacers can be hard on your upper ball joints.
  5. Oct 11, 2008 at 7:29 AM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
  6. Oct 11, 2008 at 8:04 AM
    rwcfrank
    rwcfrank Well-Known Member
    08 SR5 Prerunner
    For normal types of driving are spacers (2") really a bad idea? I am thinking of doing the same...
  7. Oct 11, 2008 at 11:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A top loading spacer is affectivley makeing your shock/spring longer. When going over a speed bump, or large dip in the road, it will put stress on your upper ball joint. The stock UBJ's are strong, but under repeated extensions, they can fail.
    Check this thread out:
  8. Oct 11, 2008 at 1:50 PM
    Neubs
    Maryland
    Holy cow that is a long and heated TTORA thread. :eek: My take from reading it is that any suspension lift that allows for too much down travel can cause problems with the upper ball joints. This is why people should consider upgrading their UCAs at the same time they install a lift. It would solve the problem and correct alignment issues as well.
  9. Oct 11, 2008 at 5:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This is correct. Long travel shocks, or top load spacers cause too much down travel for the stock UCA's
    Absolutly! :D
  10. Oct 11, 2008 at 5:51 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    Rakes are for leaves, not vehicles.[/quote]
    :rofl:
    so you would strongly recommend 5100's then? Is all around necessary or just for better ride?
  11. Oct 11, 2008 at 5:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl:
    so you would strongly recommend 5100's then? Is all around necessary or just for better ride?[/quote]
    You can get a good deal on them when you buy front and rear. Personally, If I were to get the 5100's I would get all 4. Way better shock than the OEM TRD Bilstiens.
  12. Oct 11, 2008 at 7:51 PM
    Neubs
    Maryland
    +1 what he said!
  13. Oct 12, 2008 at 6:20 AM
    crytesy
    Alberta
    2006 SR5 Tacoma
    Thank you all......I will investigate the Bilstein 5100's....
    This is a great Forum!!!!!
  14. Oct 12, 2008 at 6:28 AM
    crytesy
    Alberta
    2006 SR5 Tacoma
    If I install the adjustable 5100's.....do I require a change in springs or any other components? Are they difficult to install?
    thanks
  15. Oct 12, 2008 at 7:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It uses the stock springs. You shouldnt need anything else.
  16. Oct 12, 2008 at 8:10 AM
    rwcfrank
    08 SR5 Prerunner
    I absolutely dont want to restart the spacer vs (insert option here) lift debate. I am more interested in the mechanics of the modification. If the truck is being lifted by effectively lengthening the shock (spacer coil over or 5100) you are still going to increase the angle of the upper ball joint and potentially cause it to bind. Thats what I deciphered from the 2 million posts I have read so far. Am I missing something basic here? For a truck that will see regular on road driving and an occasional dirt lot It seems that UCA would not be madatory.
  17. Oct 12, 2008 at 11:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    5100's do not lengthen the shock/spring. It preloads the coild thus giveing lift. A top load spacer DOES lengthen the shock/spring, thus beating the ball joints like they owe money. When lifting, you generally lift at the expens of down travle. The shock is the limiting factor. Say you have 8" of travle and you lift 3". You now have 1" of down travle if your stock suspension was in the middle of the range. This may cause your shock to "Top out" creating a "thunking" noise when going over big bumps. I recomend an UCA swap when lifting, if anything, to restore lost caster when you lift.
  18. Oct 12, 2008 at 12:32 PM
    rwcfrank
    08 SR5 Prerunner
    Thanks Chris, I wasnt able to picture it in my head until you described it...
