just can't figure it out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobder41, Apr 4, 2009.
  1. Apr 5, 2009 at 7:59 AM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    yeah i get like 19-20. im fine with it though
  2. Apr 5, 2009 at 8:59 AM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    That's because Canada uses the Imperial gallon in their measurements and not the US gallon. The imperial gallon works out to 4.56049 litres while the US gallon works out to roughly 3.78541 litres. As a result, you can't compare Canadian MPG to US MPG without doing the conversion first.
    As to the question from the original poster, I'd suggest a few things:
    - Definitely need to Taco to break in more. Fuel consumption will be noticeably worse for a new vehicle. It's been that way on every vehicle I've ever owned.
    - For their respective size, I'm pretty sure that the 4.0 is a higher output engine per litre so perhaps it does require more fuel to get those higher output numbers. I don't imagine this is a big issue though.
    - Are the rear ends the same? Is the Chevy maybe geared for better fuel economy?
    - Similar tires, air pressure and tread design?
    - The odomoter shouldn't be off like the speedo. They are two independent systems. This means that the mileage calculation for the Taco may be off.
    - The Taco is basically brand new and we are coming out of winter. Winter usually results in the worst mileage because of temps and winter blend gas. Are you comparing the Taco mileage from this period with the Chevy mileage from the same period OR the Chevy's overall average (which would be better than it's average in the winter)?
    Good luck!
  3. Apr 5, 2009 at 9:28 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    ^Everything he said.
    Exactly.
  4. Apr 5, 2009 at 9:32 AM
    TheTacoManChach
    TheTacoManChach I AM THE GREAT CHACHOLIO!!!
    Brian
    Fayetteville, TX
    2006 Toyota Tacoma Double Cab Prerunner SR5
    Halo Headlights Black W/ LED LED TailLights Bermuda 3rd Brake Black Pioneer/Alpine System Debadge Entire Rebadge Driver Side Door Black Volant CAI Tool Box ARB Front Bumper Flat Black Painted Grill Surround
    they get better gas mileage probably cause they have that new option where they can switch to 4 cyl 6 cyl or 8 depending on what they need
  5. Apr 5, 2009 at 9:33 AM
    TheTacoManChach
    Brian
    Fayetteville, TX
    damn canadians
    always gotta do more than the US
    we gotta have 1 more man on our football line and a larger field
    we gotta have a little more gas in a gallon
    jeez whats next
  6. Apr 5, 2009 at 4:37 PM
    jsr813
    jsr813 Well-Known Member
    Cranberry Twp., PA
    2022 Tacoma SR5 V6 DCSB 4x4
    None yet
    My 09 Std cab 2wd gets about 24 mpg (only 1200 miles so far).
    The odometer is off about 1% (measures 20.2 miles in 20.0 actual miles).
    The speedometer is off about 7% (measures 60 when doing 56).
    Other than putting bigger tires on it, is there a mod to the computer that the service techs can do to correct the speedometer ?
  7. Apr 5, 2009 at 6:40 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    theirs the You already know how off it is mod
    where you just go faster than what it says by 7%
    that seems to work out good for me...
  8. Apr 5, 2009 at 6:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Dont worry. American Girls are WAY hotter than theirs. :D
  9. Apr 5, 2009 at 7:42 PM
    A.D.
    A.D. Desert Riding Ninja
    SoC♠l 4 life but stationed in Utah
    Low and Slow Mini
    I also have a full size Z71 Tahoe with everything on it, and i don't get anywhere near what i get in my Taco. I have had it since it was new, and have had it for a few years now, still not to many miles on it though, and I also have an 08 DC Taco, drive them both about the same, both go in the dirt and hit the highway pretty hard. I get about 14 mpg hwy in the Tahoe and about 22-23 in the Taco, so it doesn't even compare. I wish i got the mileage your bosses do, cuz it would make summers alot easier with the $5 a gallon we see here.
  10. Apr 6, 2009 at 6:28 PM
    bobder41
    bobder41 [OP] Active Member
    Bob
    Florida
    2023 Tacoma Limited SB
    My wife drives an Avalanche and gets 15-18. My 04 Silverado does not have the cylinder control but has always turned in over 20 mpg. Our 99 with the v6 turned in 19 mpg
    Even the Tundra is rated at 21mpg now on the highway with the v-8.
    Could it be that a v-6 is an ineffient design and engine compared to the v-8 or straight 4
  11. Apr 6, 2009 at 6:53 PM
    rick
    rick `
    I just replaced 3 NGK's and 3 Denso's with 6 Denso iridiums, and in 2 weeks i have seen no increase in mpg. same 280ish miles from full tank to low fuel light on. I think thats about 18 gallons.
  12. Apr 6, 2009 at 7:35 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    The Tundra has a six speed auto. That will help big time with highway mileage. Is your 04 Silverado a 4x4? Mine never got 20 mpg. It got the same as your Avalanche, 15-18.
  13. Apr 6, 2009 at 7:51 PM
    bobder41
    Bob
    Florida
    all of them are 2 wd
  14. Apr 6, 2009 at 8:07 PM
    Boomer34
    Boomer34 Active Member
    Pensacola, FL
    07 DC TRD Sport
    My brother's full size 03 Silverado got about 15 mpg. My last truck, which I can't believe i let my friend who was the salesman sell it to me, was a Ford Sport Trac - THE WORST PIECE OF CRAP i've ever owned. It was a V6 and only got about 15 mpg - I quickly sold it after 6 months.
    But I think your right, the newer Chevy's are much better on fuel economy - guess having Congress bitch you out for lagging behind on hybrids and CAFE rules helped...
