Just changed Transfer case fluid, now I've got a problem...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bythecoast, Nov 4, 2019.
  1. Nov 4, 2019 at 3:57 PM
    bythecoast
    bythecoast [OP] Member
    NH
    New truck owner of a 2015 TRD pro with 35K. I decided to change the Transfer case fluid and filled until it started to drain out. Now when I put the truck in 4High to test, I noticed when taking a tight turn while baking out of a parking space the the wheels wouldn't move, only if I take a less aggressive turn will the wheels move again.
    I've only had the truck a few months and haven't use 4 wheel drive very often this summer, but I don't recall the steering radius being this restricted in 4High and certainly I don't recall the truck acting like this. I used 75w-90 mobil one oil.
    When filling the Transfer Case do you fill until it over flows or measure out 1.1 Qts. ??
    I guest I can drain and refill making sure to re-measure 1.1 Qts. I thought I read to fill until it leaks out, but this is my first go around with the Taco so this could be a classic newbie mistake.
    Thanks.
  2. Nov 4, 2019 at 3:58 PM
    Sasquatch3153
    Sasquatch3153 Sassy Squatch
    Josh
    Illinois
    2010 ACLB OR
    Were you driving in 4HI on pavement?
  3. Nov 4, 2019 at 4:02 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    This may be the problem. Dry pavement and tight turns are not good.
  4. Nov 4, 2019 at 4:03 PM
    bythecoast
    NH
    Yes. leaving store I put the truck in 4Hi and then decided to back out of the parking lot and drive home which is less than a mile. Wanted to test before driving to work tomorrow, Work is a much longer commute.
    whatstcp likes this.
  5. Nov 4, 2019 at 4:04 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    Find a gravel road and test it there.
  6. Nov 4, 2019 at 4:07 PM
    bythecoast
    NH
    Thank you for the quick responses. First time truck owner, so good to know. The other 5 times I've used 4 wheel drive I was off road in the woods so didn't experience this.
    So when filling the transfer case do you measure out 1.1Qts. or fill until it drains out?
  7. Nov 4, 2019 at 4:08 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    Yeah....... Don't do that. You'll grenade your front end. CVs will get destroyed and the diff will get destroyed as well. What you need do do is go down a STRAIGHT road in 4HI and drive about 45 mph for a couple of miles so the diff and transfer case get lubed up
  8. Nov 4, 2019 at 4:11 PM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Fill it till it starts coming out
    Sasquatch3153 likes this.
  9. Nov 4, 2019 at 4:12 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Unless you’re trying to do circles with the wheel cut all the way or tight turns with high throttle you’re not going to grenade your differential in 4WH
  10. Nov 4, 2019 at 4:26 PM
    bythecoast
    NH
    Great!! Thanks everyone for the information. I feel like me and the truck are in good hands thanks to this site!!
  11. Nov 4, 2019 at 4:27 PM
    Sasquatch3153
    Josh
    Illinois
    2010 ACLB OR
    No problem man. And welcome to Tacomaworld :thumbsup:
  12. Nov 4, 2019 at 4:38 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    You are correct on the amount 1.1qts and yes you can fill till fluid comes out the top plug on the transfer case. Diffs are front 1.6qts and rear 3.1qts if you get to them all same 75w-90. Tacomas are part time 4wd as others stated as the transfer case does not have a differential/limited slip clutches to split front and rear axles turning at different speeds. Only 4wds that have an "auto" 4wd setting have the ability to run on paved streets due to the ability in the transfer case to vary front and rear speed/power output. Of course AWD vehicles are full time 4wd and always split power many based on wheel slippage and computer control.
    FYI: The e-locker can only be engaged in 4Lo which to engage you must put the transmission in N so the transfer case can shift to a lower gear. Then when in 4Lo you push the rear locker button it may not engage until you put in gear and began to go turning the steering wheel side to side to get the rear axle splines to align with the locker collar. Sometimes it goes right in other times it takes a few shakes. When you do engage the e-locker you will see the ABS, ATRAC, and engine management shut off as designed so you can dig out without the Tacomas ECU firing ABS and ramping down the throttle due to wheel spin. The owners manual kind of describes this but not well.
  13. Nov 4, 2019 at 8:37 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    You fill it until it drains out the fill hole on top.
