just enough to fit 285's
Discussion in 'Suspension' started by tacosupreme54, Jul 7, 2010.
  1. Jul 7, 2010 at 11:03 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i'm early in the process of personalizing my truck and will take any advice offered. i have an 06 TRD Off Road double cab and am trying to figure out what i need to do to fit 285/75/16's. i don't plan on doing any off-roading or anything like that, so i don't need a huge or excess amount of room in the fender wells. i just want a tougher look with the 285's without much/any rubbing when fully locked. i already have a leveling spacer in the front and know that i will probably need an AAL or block in the back. i have read many threads about this and i am not completely sure about what to do because some people on here say you can run a 285/75/16 with the setup i have, even my tire and wheel guy said i probably could once i add something in the back. however, i have still heard a few people, just a few, that have said that you can't. they say you need to add wheel spacers. i'm new to this, so i don't know :confused:
    if you have this setup and/or know from personal experience, just let me know the minimum i NEED to clear 285/75/16 or what you used to clear them. also, could anybody let me know whether i should go with the AAL or blocks (again, i'm not off-roading) and whether i can use my stock TRD Off Road wheels with these 285's???
  2. Jul 7, 2010 at 11:10 PM
    ChompsterTacoma
    ChompsterTacoma Well-Known Member
    Chompster
    Fresno,Ca
    TRD offroad 4x4
    Bone Stock
    My neighbor has 285 on a two and half inch spacer up front and one and a half in the back with blocks. Only trimmed alittle on the inner liner where the mud flaps would be attached. No spacers on stock wheels.
  3. Jul 7, 2010 at 11:13 PM
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    uh no if you run 285s on stock rims youre going to need wheel spacers. otherwise the tires will rub on your UCA because of the backspacing and offset of the stock rim
  4. Jul 7, 2010 at 11:17 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    and he has no rubbing at all now?
  5. Jul 7, 2010 at 11:19 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    oh, ok. but you can run a 285/75/16 on a stock TRD OR rim as long as you have the wheel spacer??
  6. Jul 7, 2010 at 11:23 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    That's right. I have a 2.5inch leveling kit on the front only. I run 285/75/17's on stock rims with a 1/4 wheel spacer. It still rubs a little at full lock, mostly when backing up. I removed my mudflaps too, helps a little more.
  7. Jul 7, 2010 at 11:30 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    ok, so you have basically the same setup i do right now. i just need to look into getting wheel spacers when i get a bigger tire if i plan on using the same wheels. and you run a 285/75/17, that's essentially a 34, right? and it worked on a 2.5in leveling kit with nothing in the back?
  8. Jul 7, 2010 at 11:35 PM
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    he means a 285/70/17, thats the same size as 285/75/16, a 33' tire
  9. Jul 7, 2010 at 11:40 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    that's what i was thinking, because i don't know of anyone that makes a 34" tire. i just put 285/75/17 into the tire calculator and it came up to 34". i would like to have a 34" tire if somebody made it though.
  10. Jul 8, 2010 at 6:24 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    Im new on this site too and still learnning .Can I ask where can I get the wheel spacers . Im currently run TRD sport wheels with 275/70/17 without wheel spacers no porblem at all , but Im thinking to get 285/70/17 off road tires but I don't know to get those spacers at please tell me . Thanks
  11. Jul 8, 2010 at 7:12 AM
    subhunter
    subhunter Member
    New England
    08 tacoma double cab
    Get them from Spidertrax. I just ordered a set for the front and rear of my truck. They have one of the best reputations, however they are not the cheapest. I put a lift and level kit on and slapped a set of 285/70/17's on my factor rims, they rub on the upper arm, but the 1.25" spacers will kick them out about 2.5". it will stop the rubbing,I may need to trim some fender, and it will give the truck a more stable and aggressive stance.
