Just finished spark plug change...they were...
Discussion in 'Technical Chat' started by Masada, Sep 27, 2009.
  1. Sep 29, 2009 at 5:08 PM
    #41
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    In the owners manual, it tells you the 2 plugs to use. The NGK's or the Densos. they come with both from the factory.
  2. Sep 29, 2009 at 6:09 PM
    #42
    tacobale
    tacobale Well-Known Member
    Right, that still does not tell you to use 3 of each on each bank. It says either or. There IS a reason Toyota does this during assy. and then tells you to use either or for replacement:) If it was something that was NEEDED then we would do the same at 30K.
  3. Sep 29, 2009 at 11:28 PM
    #43
    Masada
    Masada [OP] Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    Don't argue with the man he has 31,196 post, oh wait make it 31,197 hold ont 198 (dang it Chris stop posting so much!) :eek:
    :ohsnap:
    :D
  4. Nov 22, 2009 at 3:38 PM
    #44
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    I had to get on ths forum and find out why I found 3 different factory installed plugs in my truck. I was thinking it was a mistake or something. But after reading everyone else's reply, I think I know why they do it.
    Toyota is gathering data on the plugs and comparing the findings. When the dealership changes the plugs they collect a ton of data: mileage of vehicle, the final gap on the plugs and they keep the plugs.
    It is a perfect test. Toyota has leading edge manufacturing techniques. It makes perfect sense to compare plugs at 30K miles after real world testing.
  5. Nov 22, 2009 at 3:53 PM
    #45
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They have been doing this on every V6 in their trucks. They always have NGK's and Denso's in them from the factory. Thats a good thought though. AND it could be true. I mean....Seems just as viable as my idea (and some friends) who think its due to the NGK's being a little cheaper, and that side being able to use a cheaper plug.....
  6. Nov 22, 2009 at 5:19 PM
    #46
    misterquad
    Shawnee, KS
    Couple of things that also come to mind and make me think.
    First thought, they quit putting 100k plugs in the vehicle because it costs their dealerships lots of service work. Most people don't have the tools nor skills to change their own plugs. (I hear that dealerships make more money from service than sales. I don't know that to be true but it sounds good.) Back to my point, assume a 200k life on a Toyota with 30K mile plugs and there are 6 service trips for plug changes, with 100K mile plugs you only need to get 1 service trip for a plug change. These plugs earn the dealership 5 service trips.
    My next thought, in college we learned how to design equipment to meet a specific lifecycle. Those classes are the first thing I thought of when I realized that Toyota puts differents plugs in every truck. Sounds like they are looking to find that 30k mile plug.
    When you connect the two points together it seems to make a lot of sense to me. Especially knowing that there are books based on Toyota being a World Class manufacturing model. They do everything for a reason.
    Side note, when I usually change plugs, I normally inspect the condition and throw it in the trash. But for some reason, I laid these out on the bench in order and then I noticed three different models. I inspected their gaps and checked their resistance. Two models were consistent but one model had lower resistance and a larger gap. I don't know what to do with the information but I did observe that.
    When I noticed the different models, I was initially upset. I would not expect that Toyota would make such a mistake. How could they screw that up? So I came here. Since they do it to everyone they must have a very specific reason.
  7. Feb 24, 2010 at 10:52 AM
    #47
    cm1al
    cm1al New Member
    franklin,ny
    Sorry new toyota, but I have a thought, are these on distibuer less systems? or wired?
    my thought is if they have ignition wires, they might be compensating for restance in the wires.
  8. Feb 24, 2010 at 11:25 AM
    #48
    98tacoma27
    Ben
    Not Beech Creek
    The early V6's had distributors, the newer ones utilize coil packs.
