Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. May 22, 2012 at 2:32 PM
    #321
    draddots
    draddots Well-Known Member
    Dan
    City of Champions
    03 DC TRD
    Grey wire mod
    Any idea how far I should drop my CB? Take the measurements and use those to adjust or do those less than 3* measurements not apply to the 1st Gens?
  2. Jun 15, 2012 at 3:15 PM
    #322
    Rez
    Rez Well-Known Member
    Vancouver BC
    TRD Sport
    Didn't want to start a new thread..
    Does anyone know the size and lenght of the CB bolts? I just made some spacer, need longer bolts.
    Cheers,
  3. Sep 10, 2012 at 4:27 PM
    #323
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Since installing my 885s and aal, I've had a vibration at about 22-28 and again at about 55-60. Oddly enough when I got new tires my 55-60 went away. However, the 22-28 got worse. I've been dreading trying different combos for a solution. I read the op's post and thought, what the hell, worth a try right? 5 minutes later I road test it and BOOM. No more vibration!!! I'm so f-ing happy right now. :woot:
  4. Oct 7, 2012 at 10:52 PM
    #324
    Midship909
    Midship909 Well-Known Member
    SocaL
    13 MGM 4x4 OR 6speed
    So getting a one piece driveshaft isnt necessary to lift are 2nd gen tacomas anymore?
  5. Oct 22, 2012 at 4:07 PM
    #325
    Rooster Feather
    Rooster Feather Member
    Oklahoma
    2007 V6 SR5 4x4
  6. Jan 20, 2013 at 12:22 PM
    #326
    TacomaMatt
    TacomaMatt Well-Known Member
    09 4x4 TRD OR AC 4.0L
    5100s x4; Front @ 2.5 & 1.5" AAL, Truxedo Lo Pro, WeatherTech window deflectors & floor mats
    If I did this correctly the difference between the two angles is only 1 degree. Therefore I should have no vibration. The vibes aren't as bad as when I first lifted it but they are still slight. Will I create future problems if I don't eliminate the vibes I have now?
  7. Jun 11, 2013 at 3:22 PM
    #327
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    Someone help me solve my vibes!!! I have a 1 inch toytec block in rear and 5100s set at 1.75 in front. Take off vibes and bad vibes at 40-70. Only showed up after installing 1 inch block. Double checked U bolts and everything is tight
    - See more at: http://s182.photobucket.com/user/20...df09.jpg.html?sort=3&o=0#sthash.hAPaROSK.dpuf
    - See more at: http://s182.photobucket.com/user/20...7f5b.jpg.html?sort=3&o=5#sthash.eaukmcXV.dpuf
    Stupid pictures aren't working but here is a link to pics of my angles measured with an angle finder off Amazon
    http://s182.photobucket.com/user/2006kj/library/Tacoma?sort=3&page=1
  8. Jun 12, 2013 at 7:43 AM
    #328
    2006KJ
    Front Royal VA
    Any advice??? If not I'm going to bit the bullet and order a Tom woods one piece double cardan
  9. Jun 12, 2013 at 7:47 PM
    #329
    2006KJ
    Front Royal VA
    I tried 1/4 inch of washers to space the carrier bearing down and it didn't work. Flipped the carrier bearing 180 degrees that didn't work. Spaced the carrier bearing down 1/4 inch while flipped 180 degrees that didn't work. Since my piñon angle is at 3.5 I ordered 2 degree shims from toytec. Hopefully they will work. If not I'm going the Tom woods drive shaft route. If I still have vibes after that ill change out the blocks for an AAL without the 2 degree shims. Then maybe try the AAL with 2 degree shims and 1 piece double cardan drive shaft. If that doesn't fix my vibes I'm trading it in on a raptor. Have had vibes since 9 miles on odometer!
  10. Jun 16, 2013 at 10:19 AM
    #330
    2006KJ
    Front Royal VA
    Any input?? Bump
  11. Jun 16, 2013 at 9:38 PM
    #331
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I fixed my driveline vibration a month ago: ujoint replacement.
  12. Oct 7, 2013 at 5:02 PM
    #332
    brochacho
    brochacho Well-Known Member
    Vancouver, WA
    2016 4Runner SR5
  13. Nov 21, 2013 at 8:17 PM
    #333
    tacomawhite
    tacomawhite Well-Known Member
    07 PreRunner White
    Subbing. Also, the only other time I've had vibration is when my front u-joint went bad (it was obvious by amount of play).
    I've got an 07 without TSB. Recently added 5100's and wheeler's 3 leaf prog. AAL. I just noticed a good bit of vibration and one common theme I've seen is that most vibrations start after either lifting the rear, whether it's TSB, AAL, or block. Since that significantly alters the angle of the rear driveshaft it certainly seems like that's the issue.
    Given that the angles of the shafts/u-joints have been altered, could this also negatively affect the balancing of the two shafts?
  14. Mar 13, 2014 at 3:03 PM
    #334
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    After getting a broken rear spring fixed and a leaf added to both sides, I am 2" higher. I had take off shudder and very noticeable vibes at 25-30mph. The CB looked to be crooked to the eye, so I moved it a bit to line it up square to the driveshaft and it definitely decreased the shudder/vibes greatly.
  15. Mar 13, 2014 at 10:47 PM
    #335
    J0HN_R1
    J0HN_R1 Well-Known Member
    Calgary, Alberta
    2014 Tacoma TRD Sport DCSB
    Bilstein 5100's @ 2.75" FR, Deaver 1.5" TSB leafs RR, SpiderTrax 1" spacers, custom LED interior & bed lights, 2005 4Runner Sport 17" wheels powder coated satin black
    So Toytec gave you shims for free ? :confused:
  16. Apr 16, 2014 at 11:09 AM
    #336
    lgrafto1
    lgrafto1 Member
    Lane Grafton
    Sewickley PA
    Tacoma Sport DCLB
    2" spacers on front. ome leaf pack with 3rd leaf removed. + size OME Nitro rear shocks Pro Comp 7032 rims General Grabber AT2 265 70 17
    Remeasure:
    Should be something like this:
    TC: zero
    1st shaft 3.3 ish
    2nd shaft 3.7 ish
    Pinion: zero ish
    In other words, your drive shaft should be straight and the tC and pinion are mirror angles like a parralogram .
    Use flat bar on the flange and stick the angle finder to it. You have the angle finder rotated. Practice to get concept before you go under truck.
  17. Apr 16, 2014 at 11:21 AM
    #337
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Holy thread bump !! No matter, look guys this is all i can tell you , I've done close to 100 lifts 75% have been 2nd gens,out of all of those I've had maybe 3 that developed vibes & 1 of them was mine, before you get yourselves wrapped up with shimming the axle try dropping the center/carrier bearing 3/4" no more no less, you can even flip the carrier, but do these things before you start with shimms, its a hell of alot easier, also make sure you lube everything up proper too....
    BandanaBerg likes this.
  18. Jul 14, 2014 at 7:55 PM
    #338
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
  19. Jul 15, 2014 at 9:18 AM
    #339
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Give your truck a female name. These trucks have proven that's where that came from. They are so sensitive to every minor change. I have slight take off vibe and I tried shimming the CB from 1/4-1". It changes it some but at 1/4 it is the least for me anyway. The front diff vibe is there (I have the ECGS bearing just haven't done it yet). The front has a very slight vibe from the overly sensitive balancing issue. I have gotten used to it's annoyances and learned to live with them - just like with my wife! I love her and I love my truck! They are not perfect - nor am I. Besides my Duratracs kind of drown all that out anyway. Good Luck trying to have a perfect Tacoma. Leave it bone stock and if your lucky you wont have any of these issues. Hopefully soon it won't be my daily driver, but she is a keeper cause she serves me well and has never let me down, and I ride her hard all the time.
  20. Jul 15, 2014 at 7:55 PM
    #340
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I have tryed everything, and have gotten my vibes 80% gone. But that seems to be the best it will be. Im done trying to fix them and have desided to just get a double cardon one piece from a local shop here in portland. Six States driveline shop
