Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. Jan 26, 2015 at 3:25 PM
    #361
    judgeman6970
    judgeman6970 Well-Known Member
    Bob
    Long Island, NY
    Mine vibrates around 20-25 mph, but not 100% of the time. It's not "un-bearable", but it's bad enough to annoy me. I can reduce it by "easing up on the gas" for a few seconds, but I definitely prefer that it didn't do it at all. :(
  2. Jan 26, 2015 at 6:29 PM
    #362
    bilstein man
    bilstein man New Member
    tacoma
    Its probably not even noticable to anyone other than me. It feels like a minor pulse. Alsmost as if the tires were slipping traction.
  3. Feb 9, 2015 at 8:35 AM
    #363
    TNTramair
    TNTramair Well-Known Member
    2015 TRD OR SPORT
    ok...so i just got done lifting the Tacoma with Icon 2.5 coilovers up front and Icon 2.0 with res. out back and Dakar springs. i did install a carrier drop. the Icons are set at Factory setting which is 2.5". before install i had zero vibrations or shutters with the factory suspension.
    i notice now i have the take off shutter, but get no vibrations at higher speeds. ive had it up to about 65-70 and its pretty smooth but id like to address the low speed shutter. whats my next step here...axle shims i assume? wat i would hate to happen would be addressing one issue and creating another....i rather deal with a low speed shutter than a high speed shake...so what would everyone recommend?
  4. Feb 9, 2015 at 9:08 AM
    #364
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Your in the same boat as me. Just the take off shutter (although I have a little vibe coming from the front diff also - but that's another story). Anyway 3 years later I still have it but its very minor and it hasn't gotten any worse. I think I have a 1/4" CB shim and it is the least noticeable like that. So I've just been living with it because its smooth at speed. Someone posted a little while back that a 2deg axel shim fixed it for him. Others have said a more rigid CB also fixed it or some have installed a one piece DS to cure it but to me that's not worth all the trouble to fix a minor take off shutter. Try the 2deg shim and let me know how it goes. That is my next move if I do any work in the rear again. I tried dropping the CB at different levels and it just got worse as I dropped it more! Good Luck!
  5. Feb 9, 2015 at 9:10 AM
    #365
    68vert
    68vert Well-Known Member
    AZ
    DCSB 4X
    Pretty much the same experience here after my Dakar install. Ended up taking out the 3rd leaf in my Dakar pack to eliminate the raked stance and my take off vibe is almost gone. I still have a slight driveline hum around 40-45MPH though.
  6. Feb 11, 2015 at 6:36 AM
    #366
    jhcole
    jhcole Well-Known Member
    Hunter
    Birmingham, AL
    '15 DCSB 4x4 TRD-OR MGM
    ToyTec 3" w/ Bilstein 5100's
    I'm currently dealing with very minor take-off vibes, however I want to get rid of all vibes. I'm running a 3" ToyTec kit (2.5" coils + 0.5" top-plate, 2.0" AAL) and BFG AT KO2 265/75/16. I have installed the OME CB drop kit, they may have helped a little, the take-off vibe is still there though.
    I just received a ToyTec 3deg rear axle shim kit, and have been thinking about putting it on this weekend. Is there a risk that I can do more harm than good? I do not want to create any additional vibes.
    Also, please note my 2015 TRD Off Road has FACTORY rear axle shims (see page 18 of this thread for pics), and they came pointing in the direction disadvantageous to diff-input angle (narrow end pointed towards REAR). I'm not sure what degree they are, but this will be a big change in diff-input angle, as I'll be going from some degree one way, to 3deg the other way. Any input?
  7. Feb 11, 2015 at 6:41 AM
    #367
    68vert
    AZ
    DCSB 4X
    maybe try turning turning the factory shims 180 degrees?? If it feels worse then its relatively quick to change it back. let us know if the shims help
  8. Feb 11, 2015 at 10:56 AM
    #368
    jhcole
    Hunter
    Birmingham, AL
    I thought about trying that as well, but I really only want to drop the axle once if I can help it.
    I bought the recommended digital angle gauge, so maybe I can figure out all the numbers before taking anything loose.
  9. Feb 11, 2015 at 1:55 PM
    #369
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    You gotta measure angles first.
  10. Feb 11, 2015 at 2:10 PM
    #370
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No vibes here, but bumpily for those that do. I believe the problem seems to inherently affect the pre runner 2WD models if it hasn't been mentioned already because the 4X4's have the T-case to act as the median, which lessens the severity of the chance of bad angles. I could be wrong here though. I haven't done much digging into it because I never had the issue to begin with.
  11. Feb 11, 2015 at 4:42 PM
    #371
    nd4spdbh
    SoCal
    if anything the tcase makes things worse by lengthening the engine/trans/tcase that shortens the first part of the driveshaft making for taller angles at the output u joint.
    The real problem of the vibes is all centered around the REALLY weak rubber surrounding the center carrier bearing.
  12. Feb 11, 2015 at 4:57 PM
    #372
    !TacoTaco!
    !TacoTaco! TACO LOVER!
    Felix
    PSL, FL
    09 Prerunner TRD SR5 Sport
    Removed coal filter, Also installed AFE air filter. Roof rack with custom diamond plate air diverter.
  13. Feb 23, 2015 at 11:09 AM
    #373
    smurf taco
    smurf taco Well-Known Member
    Brian
    Hobe Sound, Fl
    speedway blue 09 prerunner sport 2wd
    brite ass led headlights and fogs, fuel hostage wheels, mellow tone dual exhaust, black westin bull bar, go rhino nerf bars, toyota neoprene black and blue seat covers, image dynamics door speakers all around, Bilsteins 5100s all around set at 0 with maxtrac spindles and eibach coils and total chaos UCAs with OCtaco brakelines all around and all pro expo leafs in the rear running 295/70/17 cooper ST Maxx, cobra cb radio w/ 3ft fire stik, bed lights, jvc double din head unit, AC in cab mod, AFE CAI...more mods to come
    Can anyone tell me the correct place to check the angle on the tcase for a prerunner TRD sport. I only see pictures for a 4x4
  14. Feb 23, 2015 at 2:33 PM
    #374
    IowaToyotas
    IowaToyotas Well-Known Member
    Matthew
    San Diego
    13 TRD Super Charged
    Super Charger, 2 In lift, TRD pro 17in Rims, 285 Toyo all country tires
    I have 5100 all around with 2.5' in the front with the rear diff dropped. Before and after the diff drop I had/have the vibration on take off. Its whatever now, now that I have lifted the front Toyota is uselss. Pretty funny to considering its CPO used haha.
  15. Mar 22, 2015 at 11:04 PM
    #375
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Santa Rosa
    2015 Supercharged Taco
    Mostly whatever sweet stuff I can find at Vatozone
    Installed ome 3" lift w/progressive aal. Also have cb drop. Now I have vibrations at around 60ish. Hopefully I can get it figured out and fixed with the help of this thread!
  16. Aug 3, 2015 at 7:54 AM
    #376
    jhcole
    Hunter
    Birmingham, AL
    Just for fun I'll throw this out there, my take off vibes are basically non-existent on cool mornings!
    This morning was 65deg F, little to no vibes. Versus in the afternoons its usually around 100deg F, and I have annoying vibes.
    I may be over analyzing this but I think this issue is so sensitive even a relatively small change in temperature affects the stiffness of the CB bushing enough to create an issue.
    Anybody else notice a similar trend?
  17. Aug 3, 2015 at 8:20 AM
    #377
    nd4spdbh
    SoCal
    Yup. This is why when i get time the CB rubber is going to get filled with some good quality silicone of some sort to stiffen it up.... cus when its warm out its like a floppy dick.
  18. Aug 3, 2015 at 12:13 PM
    #378
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    Looking foreword to seeing how that works, I'd like to try something similar. Mine only has vibes from around 5-12 mph and I've always wanted to try something more to fix/ minimize it.
    Also, anyone else with the axle shims from Toytec: Does it seem like orienting the skinny part towards the front of the truck is backwards to anyone else? Its how Toytec says to install them but in my head I keep thinking they should face the other way.
  19. Aug 3, 2015 at 1:37 PM
    #379
    nd4spdbh
    SoCal
    The way you orient the shims all depends on how you want your angles setup and the rest of your driveline / your lift. etc etc. FYI the TSB for driveline vibration fix which included new leafsprings from toyota tilted the pinion down via shims with the fat end facing forward.
  20. Aug 3, 2015 at 1:55 PM
    #380
    Nighthawk
    Levi
    Casper Wyoming
    Gotcha, I must have been thinking about this backwards. Also, to what years/ models does the TSB you are referring to apply? with an aal in the back would Toyota even touch it?
