Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. Jun 14, 2019 at 8:57 AM
    #461
    Stagarm
    Stagarm Well-Known Member
    Trev
    Fj
    Me behind the wheel
    Reinstalled my stock leafs and shocks last night to measure stock angles. Test drive with NO VIBRATIONS.
    TC- 2.3* down
    1st shaft 7.9* down
    2nd shaft 5.7* down
    Pinion 5.2* up
    Drove over to my buddies house who has a 2015 4wd Tacoma sport. Bone stock.
    Measured his driveline angles. Almost the same. He says he has not vibes.
    TC- 2.5* down
    1st shaft 8.0* down
    2nd shaft 5.5* down
    Pinion 5* up
    Drove over to my parents house and measured their 2007 4wd Tacoma bone stock. Again another Tacoma with no vibes.
    TC- 2.9* down
    1st shaft 8.0* down
    2nd shaft 5.5* down
    Pinion 5* up
    All three trucks with stock rearsuspension. All measurements with a Johnson level magnetic digital angle locator. Took measurements off the flat part of the Tc outputshaft, flat part of the pinion output shaft.
    rollin904 likes this.
  2. Jun 14, 2019 at 9:02 AM
    #462
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Those numbers dont mean much... you need to work with joint angles, not shaft angles.
  3. Jun 14, 2019 at 9:20 AM
    #463
    Stagarm
    Trev
    Fj
    Me behind the wheel
    What are you talking about? You use those number to find the working angles.
  4. Jun 14, 2019 at 9:25 AM
    #464
    Stagarm
    Trev
    Fj
    Me behind the wheel
    This video has been posted hundreds of times but here you go. Only one mistake in video. I’ll let you all find it...
    https://youtu.be/f1m-Fh5kiRU
    wi_taco and Mully like this.
  5. Jun 14, 2019 at 9:28 AM
    #465
    nd4spdbh
    SoCal
    but what are the numbers referenced against? There is a zero out function on the digital gauges for a reason. Set on one side of the joint, zero, set on other, boom instant joint angle number.
  6. Jun 14, 2019 at 9:37 AM
    #466
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Measure both sides of the joint. Add if opposite angles. subtract is similar. Boom working angle.
  7. Jun 14, 2019 at 10:47 AM
    #467
    nd4spdbh
    SoCal
    so you are telling me you have a 5.5* angle at the tcase down, 2.2* angle up at the 2nd joint, and a .5* angle up at the pinion?
  8. Jun 14, 2019 at 12:10 PM
    #468
    Stagarm
    Trev
    Fj
    Me behind the wheel
  9. Jun 14, 2019 at 1:35 PM
    #469
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Yup. And all three trucks drive smooth with no vibration.
    Did you measure your angles before you installed the aftermarket parts?
  10. Jul 22, 2019 at 5:10 PM
    #470
    op9nf
    op9nf Well-Known Member
    Nilo
    Bothell,Washington
    2013 Tacoma TRD DCLB 4X4
    Bilstein 5100’s With OME 288. 2inch blocks with freedom off-road extended shocks.
    Flip the carrier bearing 180 degree and I’m vibe free.
  11. Jul 23, 2019 at 8:17 AM
    #471
    Blue Truck
    Blue Truck Well-Known Member
    I chased my vibration around and around then looking under the truck one day I could see the problem, flipped the center support bearing and all was good.
  12. Aug 25, 2019 at 6:48 AM
    #472
    Stagarm
    Trev
    Fj
    Me behind the wheel
    Tried the carrier bearing flip and no luck.
    cedarpangolin likes this.
  13. Aug 25, 2019 at 4:19 PM
    #473
    ImBillT
    ImBillT Well-Known Member
    2010 4x4 base
    My wife’s ‘06 4-Runner appears to have come from the factory with traction bars.
  14. Aug 25, 2019 at 4:20 PM
    #474
    nd4spdbh
    SoCal
    LOL.... those arent traction bars... the 4 runner has an entirely different rear suspension. A parallel 4 link with panhard and coil springs.
    mojojojo78 and wheeliest like this.
  15. Aug 25, 2019 at 4:27 PM
    #475
    ImBillT
    2010 4x4 base
    Well there ya go. I had been dealin with axel wrap in my Taco, and when I was putting air in the tires of a recently purchased 4-Runner(which I’ve not yet had reason to do any work on) I said “well dang! Wish that was on the Taco”
  16. Sep 23, 2019 at 9:28 AM
    #476
    Ladebakk
    Ladebakk Well-Known Member
    JB
    TN
    2008 AC cab
    Hello all. I installed new heavy duty leafs (slight lift) and developed vibes from 10mph to 35mph and minor 55 to 65. Replaced every U joint and carrier bearing, all of which where fine. Got alignment. Learned how to use angle finder and had everything canceled out on paper. Dropped carrier/center bearing. STILL VIBES!! After hours of reading and super frustrating week of trial and error(out of options) I figured what could it hurt to flip the center bearing. All vibes gone!! so happy. I dont understand why because angles dont match what all the videos and forum talk say but give it a try.
  17. Sep 23, 2019 at 3:03 PM
    #477
    op9nf
    Nilo
    Bothell,Washington
    Did you leave the carrier drop shims on when flip the center carrier bearing?
  18. Sep 23, 2019 at 3:31 PM
    #478
    Ladebakk
    JB
    TN
    2008 AC cab
    No shims. Straight flip. Magic:)
  19. Sep 23, 2019 at 4:01 PM
    #479
    hammertaco11
    hammertaco11 Well-Known Member
    East Bay, Ca
    2014 Tacoma SR5 Pyrite Mica
    OME lift w/ HD Dakars Pro Comp 17" 7069 BFG KO2 275/70
    can someone explain how to flip the carrier bearing? It sounds pretty easy, but I guess I'm not understanding what exactly to flip. Is it the U-bracket that is holding the driveshaft?
  20. Sep 23, 2019 at 4:05 PM
    #480
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    you lay under your truck, remove two bolts on a center drive line support bearing, rotate it 180* and re-install the bolts.
    hammertaco11[QUOTED] likes this.
