Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. Jul 25, 2011 at 3:42 PM
    #61
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Sleepy Hollow
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    OP do you have pictures, or could you take a few of where/what you did? What ring are you referring to?
  2. Sep 9, 2011 at 4:14 PM
    #62
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Very interesting. Can you explain what ring you are referring to and what does flipping it 180 degrees mean? Thanks for the great post. I'm trying to solve some vibe/shudder issues on my brother's tacoma. He has the take-off and deceleration shudder around 20 mph.
  3. Sep 15, 2011 at 6:07 AM
    #63
    SpaceMonkey
    Houston, Tx
    06 PreRunner
  4. Nov 3, 2011 at 7:12 AM
    #64
    upcountry
    upcountry Active Member
    Seattle
    07 Tacoma
    Very good thread. Subscribed. I had a driveline vibration after doing the TSB upgrade and Toytect AAL with OME Nitrochargers. I tried the shim, no luck. Then I tried the OME drop kit carrier bearing drop kit, worked OK, with small vibe left at 55-60MPH.
    Of speacial note: THE VIBRATION WENT AWAY A FEW MONTHS LATER AFTER THE SUSPENSION SETTLED.
    I have had the TSB packs with Toytec AAL for around 4 years now. No vibe after break in.
    I would say so often we are concerned about a small vibration immediately after we install a new spring pack but we dont acutally wait for the springs to pass a break in period. My suggestion is load up the truck with some sandbags and put around 300 pounds in the bed over the axle and then see if it gives you a vibe. If no vibe after it is loaded, then dont worry about it, go hit the trail and give the springs a workout and help them settle down a little. After a few months of abuse, if you still have a vibe, THEN measure the driveline and take corrective action. Now that is not to say if you have a really bad vibe, then of course fix it!
    I am upgrading to All Pro Expo Spring Packs this weekend or whenever it stops raining, so will be following this formula since I am sure my geometry will be all wrong. I may need to wait for the beefed taco drop kit since this will likely yeild around 3.5 inches of lift. But Iam going to keep around 400 pounds of sandbags in the bed for a few weeks to help break in these HD springs.
    I really want to say this is a great thread and I appreciate all the time and effort put into taking the pain and unknown out of this problem. Thank you to those that have contributed, both by providing a sollution and asking good questions.
  5. Nov 3, 2011 at 7:53 AM
    #65
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Props to the OP. You've sort of cleared up the questions I've been thinking about as I've been going down this path. I just ordered 2.5* shims and I have some CB spacers as well. I'll probably be flipping the CB in the next few days to see what kind of angles I get. I have the TSB leaf pack and an AAL as well.
  6. Nov 5, 2011 at 10:13 AM
    #66
    STLTaco09
    The part in here with the first 2 angles being equal and the pinion being 0.0 is grabbing my attention. I've been doing a lot of measuring (trying to get the most accurate measurements with sub-par tools), and I think the first shaft (front of CB) is 4.5* and the 2nd shaft is 4.5*, all off of the transfer case as 0.0. The pinion angle is 0.0, this was measured after I installed 2.5* shims.
    I have minor takeoff shudder now, and a bit of vibration right around 38mph. My next idea was to flip the CB 180* (raising it), measure and check for vibes, then drop it down a tad using my 3/8" spacers if I need to, still keeping it upside down from the way it came from toyota.
    Any thoughts on these angles and the vibes I'm getting?
  7. Nov 5, 2011 at 11:58 AM
    #67
    STLTaco09
    I flipped the CB 180* and installed 3/8" spacers dropping it back down slightly. This changed the first shaft coming out of the transfer case to 2.2*, the 2nd shaft is now 5.6*, and the pinion is 2.2*. Haven't taken it for a drive yet so I'll post back when I have done that.
    Figuring out where these numbers need to be is a bit confusing. If anyone has any input from what I've measured so far, feel free to post or PM.
  8. Nov 5, 2011 at 4:46 PM
    #68
    STLTaco09
    Took it for a drive, this is by far the best it's ever been. With the way people talk about a driveline shudder, it might be on par or even less than what some folks get with a brand new un-lifted truck - any vibe/shudder is almost non-existant. I've been dealing with it for so long that I can point it out when it happens otherwise I probably wouldn't notice. I had a steering wheel wobble when braking from 70mph to about 60mph, and that seems to all have settled out as well. Time will tell when driving it this week if the short trip I took tells the whole story or not, but I'll probably leave it like this until I have a reason to change it.
    Thanks for all the info on here, and for doing the leg work with the angles, etc.
  9. Nov 5, 2011 at 10:01 PM
    #69
    BRYLONATOR
    BRYLONATOR Building 06 Suburban K2500 with LBZ D-max and ZF6!
    Denver, Colorado
    Chillin in a 120!
    definitely sub'd for future fix!
  10. Nov 5, 2011 at 11:58 PM
    #70
    Toyota Man
    Toyota Man Toyota Man
    Oregon, Centeral Willamette Valley
    11' DCSB TRD super charged off road
    TRD super charger, TRD cold air intake, and exhaust. Downey coil overs coming soon
    sub'd good info.
  11. Nov 6, 2011 at 12:11 AM
    #71
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
  12. Nov 10, 2011 at 7:13 AM
    #72
    STLTaco09
    Seems as though the vibes were better, then they are back. So after all this, its not fixed even though the driveline angles look WAY better with the spacer and CB flip. I dont know if the vibes are getting worse, or they are the same and just haven't been fixed.
    I've been racking my brain trying to figure out how everything could be fine for so long, then after 30k with the lift (only maybe 1.75"), these vibes come up. I finally read a post that related their vibes to the colder weather, and thats about when they started for me too.
    The vibes at highway speeds when braking are better/gone. Just takeoff shudder and 25-40mph vibes now. Had the shudder to some degree before, never the 25-40 vibes though.
    Also read a post about someone preloading CB by pushing it forward a tad before tightening it down, any truth to that?
  13. Nov 10, 2011 at 8:49 AM
    #73
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    Toyota didnt fail at driveline 101....Their trucks drive just fine. You did, by altering the factory pinion angle and wondering why you have a vibration :confused:... Nice job tho by configuring a decent fix without having to reposition your leaf mounts. Hopefully others can follow on this who have the same problem :D
  14. Nov 10, 2011 at 9:12 AM
    #74
    STLTaco09
    Some people have take off shudder from the get-go, right off the lot.
  15. Nov 10, 2011 at 11:33 AM
    #75
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  16. Nov 16, 2011 at 11:48 AM
    #76
    blair
    blair Well-Known Member
    Blair
    Tampa, FL
    2015 PreRunner
    My truck had take off shudder since day one. I recently added a toytec 1.5" AAL. The ride was a vast improvement over stock and no more bottoming out. However, the shudder got worse. I bought the OME carrier bearing drop kit, but that alone didn't help things. I was pretty close to taking off the AAL and going back to stock until I saw this thread. I bought an angle gauge and tried flipping the carrier bearing and using the OME spacers. This equalized the angles between the two driveshafts. Now my take off shudder is 95-99% gone. It actually has less shudder now than it did stock! Very happy now.
    Anyone having driveline vibes, do yourself a favor... Print out the diagram posted in this thread and get an angle gauge. Measure your driveline angles before you start throwing parts at your truck. It will save you a lot of frustration.
    RayCantu53 likes this.
  17. Nov 17, 2011 at 4:22 PM
    #77
    Relik
    Eddy
    Thousand Oaks, CA
    Can anyone explain how to flip the carrier bearing? I can't find how to by searching, but quite a few try it...
  18. Nov 17, 2011 at 4:52 PM
    #78
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    unbolt it, turn it over, bolt back up?
  19. Nov 17, 2011 at 8:47 PM
    #79
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    Subbed
  20. Nov 18, 2011 at 9:47 AM
    #80
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    So youre just rotating it 180 degrees on a horizontal plane, like a 180 shove it on a skateboard?
