Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. Nov 18, 2011 at 10:01 AM
    #81
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    That's how I understood it. N ot sure what a 180 shove is. Just use the driveshaft as the rotation axis.
  2. Nov 18, 2011 at 10:28 AM
    #82
    mgrande
    mgrande iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
  3. Nov 18, 2011 at 10:54 AM
    #83
    blair
    blair Well-Known Member
    Blair
    Tampa, FL
    2015 PreRunner
    The carrier bearing looks like this: -O-
    Except that the mounting tabs aren't perfectly centered on the "O"
    You basically just unbolt both ears, the driveshaft will drop a few inches, rotate the bearing on the driveshaft and bolt back up. However, the most important step is to measure the angles and adjust the height of the carrier bearing to equalize the angles of the front and rear driveshafts. That might require only flipping the bearing or shimming it to a height to equalize. I don't think flipping the bearing alone will fix many vibration problems
  4. Nov 18, 2011 at 11:25 AM
    #84
    Relik
    Relik Well-Known Member
    Eddy
    Thousand Oaks, CA
    '11 TRD Sport PreRunner-Auto-Magnetic Gray
    Bilstein 5100s (Front & ext. Rear), Eibach coils @ 0, MaxTrac 4" Spindles, Light Racing UCAs, 1/4" lean spacer, All-Pro 3" Standard leafs, u-bolt flip kit, SpiderTrax 1.25" wheel spacers, 33" (285/70/17) TreadWright Warden A/T tires, extended lines
    Cool thanks guys...my first thought for flipping was removing it and turning it front to back, but now I get it. I do have a CB drop that looks like 3/4"-1", thats when my sound got worse. I did order a digital gauge to check my angles just waiting on it. Might try this flip tho cause the vibration don't sound good to wait till mon/tue.
  5. Nov 18, 2011 at 11:27 AM
    #85
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    As I mentioned in a previous post, for my setup, flipping the CB then dropping it about another 3/8 of an inch, probably just a hair less than 1/2" gave me the best angles. Yours might be different depending on how much lift you have in the rear.
  6. Nov 18, 2011 at 11:28 AM
    #86
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2023 Double Cab 4x4
    Subbed. Getting lifted toady (Icon pack in the rear). Mine came stock with with driveline vibes. Hoping they don't get too much worse.
  7. Nov 18, 2011 at 11:50 AM
    #87
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Need to save this thread. Great info!
  8. Nov 18, 2011 at 1:13 PM
    #88
    lundy
    Justin
    Reno, NV
    2023 Double Cab 4x4
    BTW, what are everyone's thoughts on a one piece shaft? More likely to solve this problem?
  9. Nov 30, 2011 at 6:51 PM
    #89
    TacomaChris
    TacomaChris Well-Known Member
    Are you sure? According to this http://www2.dana.com/pdf/J3311-1-DSSP.pdf Page 14, the rear axle/pinion should be parallel to the first shaft, not the output of the transmission. That's how I interpret it...thoughts?
  10. Dec 22, 2011 at 3:02 PM
    #90
    jrzyshore
    jrzyshore Well-Known Member
    Scott
    SNJ
    2010 Toyota Prius TRD Offroad
    Icon extended travel coilovers and rear shocks, Dakar leaf springs, Toytec U bolt flip, extended length Icon 2.0 rear shocks, Timbren Bump stops ,TC UCAs, Street Taco (Beefedtaco) 1 1/2" CB drop, 4x Innovation DOM tube sliders with kick outs, some extended brake lines,ATO front skid plate, ATO trans skid, ATO Hi Lift brackets, 60" Hi Lift jack and a pine tree air freshener.
    I have the same vib after I put my lift on. Tried the cb drop it made it a little better. I am going to give it a try this weekend and see how it goes.
  11. Dec 23, 2011 at 8:56 AM
    #91
    jrzyshore
    Scott
    SNJ
    So I tried to flip the Cb and I left the OME shims in and it fixed the 25 mph vib but then created a shutter off the start. I put back the original way. I am going to order the shims for the rear then I will go from there.
  12. Dec 28, 2011 at 10:14 PM
    #92
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    Thought I'd share my results so far as well...
    Lift is OME w/ Dakar springs, which created vibes @~20-30mph.
    Installed 3 deg shims in the rear and returned the CB to stock position. Vibes are totally gone, and only sometimes have a slight shudder when pulling forward from stopped.
    I'll measure my angles this week and maybe play with the CB height a little, but this seems to be a totally solvable problem if people take their time and think it through.
  13. Feb 17, 2012 at 11:19 PM
    #93
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I have tried almost everything to try and get rid of my stupid take off shudder..
    Tomorrow Im getting a degree finder and playing around with it some more.. I got 2* axle shims I may need to use, but need new center pins if I do need it..
    So to my understanding, the pinion angle should match your trans. angle?
  14. Feb 18, 2012 at 12:30 AM
    #94
    badger
    badger Well-Known Member
    07 SR5
    On the Tacoma, yes. Then adjust the carrier bearing so that the difference between the 2 shafts is about a degree. You need a slight angle in that joint to lubricate it properly and keep it rotating for even wear.
  15. Feb 18, 2012 at 9:16 AM
    #95
    ETaco23
    Evan
    PNW
    k. So I just read some where that the pinion/axle angle should match the first drive shaft angle (coming from trans.)
    or should it match the trans. angle?
    and that the first shaft angle needs to be around 1-1.5* off of the trans.?
    am I correct on this or what?
    thanks for any help...
  16. Feb 18, 2012 at 9:42 AM
    #96
    badger
    07 SR5
    What you are describing is a typical truck set-up, but not what Touota did. The first shaft is not at 1 degree so you cannot align to it. You have to align the pinon to the TCase output, if need be. Most 3" lifts don't require much if any axle correction. Once that is confirmed, you can adjust the carrier bearing to achieve a 1 degree at that joint.
  17. Feb 18, 2012 at 11:52 AM
    #97
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
  18. Feb 18, 2012 at 5:40 PM
    #98
    ETaco23
    Evan
    PNW
    Spent all day trying to fix my take off shudder, and I think I made it worse! :(
    Installed the 2* shim I had and then played around with the CB. spacing it down spining it and what not. Nothing seemed to help..
    Not sure what to do next. Im almost tempted to take it to a driveline shop!
  19. Feb 18, 2012 at 5:41 PM
    #99
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Have you looked into the Beefed Taco CB drop ?
  20. Feb 18, 2012 at 5:48 PM
    #100
    ETaco23
    Evan
    PNW
    Got it and tryed that too. With no luck..
    My angles right now arent bad and are where they should be. from what I read.
    My pinnion angle and 2nd shaft are within 3 degrees of each other.
    and my 1st. shaft and pinion angles are about the same. (very close)
    not sure what else to try!
