Just fixed driveline vibration!!!For free!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hvacbmac, Apr 21, 2011.
  1. Feb 24, 2012 at 8:29 PM
    #161
    badger
    badger Well-Known Member
    07 SR5
    I don't know what you have read, but I'm not surprised the pinion is off in that direction. I am surprised it's that much, but now your numbers make sense. This whole thing really makes me curious as to why these differences occur. You'll see a bunch of trucks with numbers very similar, and then a flyer like this. Weird. It's still all fixable but a bigger PITA because of the axle shim.
  2. Feb 24, 2012 at 8:38 PM
    #162
    badger
    07 SR5
    You are right in a sense. You can get a momentary shudder just from the axle wrap that is not a true vibration. A takeoff vibration usually lasts as long as you stay on the gas accelerating. That's the difference. The vibration happens when the pinion is too high to begin with, and then gets twisted higher till the Ujoint starts to sing. It's a combination of mismatched pinion angle and axle wrap. The pinion doesn't drop back down until the power comes off and the vehicle speed stabilizes. A momentary stutter at take off is probably just the springs tweaking. This problem is a lot worse on the 4.0 because of the higher torque.
  3. Feb 24, 2012 at 11:51 PM
    #163
    KingMoo
    KingMoo Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    just 2.5" billy 5100s (set at 0.85) all around and 2" AAl
  4. Feb 25, 2012 at 9:03 AM
    #164
    KingMoo
    Calgary
    Tacoma TRD Sport
    if my pinion angle is so wrong would that be something that Toyota would fix under warranty or will they just say my lift did it?
  5. Feb 25, 2012 at 1:20 PM
    #165
    badger
    07 SR5
    No idea about that. The lift may have caused it. People should ask when they buy a lift whether it is designed to maintain proper pinion angles. Pretty much nobody thinks of that. All-Pro says theirs does and mine was perfect.
  6. Feb 25, 2012 at 1:43 PM
    #166
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I think I should have gone with a better rear lift, the toytec 2"AAL tilted the Pinion up alittle, making about 1.6* off from the TC... But with just lowering the CB about 3/8's it has made my take off shutter almost gone. Its tolerable and Im done messing with it. :)
  7. Feb 27, 2012 at 12:47 AM
    #167
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
  8. Feb 27, 2012 at 8:37 AM
    #168
    KingMoo
    Calgary
    Tacoma TRD Sport
    I've been trying to figure out what my angles will look like after I fix the rear diff problem with a shim. It looks like shimming the rear diff will increase my rear shaft angle further. So once that is done it will require a large CB drop in which will increase the TC shaft angle. It's already at 3.5 degrees and going higher frowned upon, am I right?
    here's a BEFORE and AFTER (presumed) pic:
    EDIT: all measurements were done from zero-ing the angle finder on the TC
  9. Feb 27, 2012 at 9:52 AM
    #169
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
  10. Feb 27, 2012 at 1:56 PM
    #170
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    OK , on my phone , the values above in the diagram are not mine .
    If you read left to right on the above diagram my angles are
    0 , 3.9 , 3.3 , up .65
    What / where do I shim ?
    I have a vibration at 40 mph that is similar to an unbalanced tire , but it is not tires
  11. Feb 27, 2012 at 2:00 PM
    #171
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    Your first and second shafts are within 1* of eachother which is good, and I'm assuming you zeroed your phone once it was placed on the TC and then got the rest of the angles. In this case, you should get a .5 degree shim from Summit Racing and you'll be within .15 of perfect.
  12. Feb 27, 2012 at 2:02 PM
    #172
    OZ-T
    Peter North
    British Columbia
    I actually used a digital inclometer for the angles , and yes , zeroed on the TC , the rest of the angles are relative to that .
  13. Feb 27, 2012 at 2:47 PM
    #173
    KingMoo
    Calgary
    Tacoma TRD Sport
    my post totally got hijacked by a cell phone post! :eek:
    BTW I noticed that a lot of people on the thread are getting rid of there vibes but not with the recommended measurements. I recall someone posting that even if you don't have the vibes, you could still be doing harm to your vehicle.
  14. Feb 27, 2012 at 2:51 PM
    #174
    mrw3685
    TX by way of KS
    08 Prerunner TRD
    Then what I'm saying should be correct, it's simple math...you want the TC and the Pinion to be "equal but opposite." Visualize what a shim will do, it's going to tilt your rear axle forward a certain # of degrees when placed "fat end towards the rear." That being said, you need .65* of "tilt" in-order-to get things parrallel. Badger has done all the work, given all the advice, now all we have to do is go measure and $hit and figure it out. Understanding what needs to happen conceptually is much easier in my mind that looking at #'s and figure out what's going on. You need a 2 shafts nearly the same, within a degree or so, and you need your TC and your Pinion to be "equal but opposit" or darn close.
    RayCantu53 likes this.
  15. Feb 27, 2012 at 3:15 PM
    #175
    KingMoo
    Calgary
    Tacoma TRD Sport
    Yeah that wasn't my post. My pic was used but numbers changed. Here's mine:
  16. Feb 27, 2012 at 3:29 PM
    #176
    OZ-T
    Peter North
    British Columbia
    With the shim in " fat end to the rear " it will tip the pinion up more making it worse , no ?
    My pinion is tipped up .65 already
  17. Feb 27, 2012 at 3:38 PM
    #177
    KingMoo
    Calgary
    Tacoma TRD Sport
    yeah that's the way I see it
  18. Feb 27, 2012 at 4:14 PM
    #178
    mrw3685
    TX by way of KS
    08 Prerunner TRD
    Sorry misspoke, reverse the direction! Point is you understand what needs to be done, so fix it!
  19. Feb 27, 2012 at 7:15 PM
    #179
    OZ-T
    Peter North
    British Columbia
    Well maybe now , sorry for asking questions in this thread I guess ? :confused:
  20. Feb 27, 2012 at 8:16 PM
    #180
    badger
    07 SR5
    Quote OZ:
    Oz, Have you shimmed your CB? How much lift do you have? I'm asking because it's unusual for the second shaft to have an angle less than the first. That's especially true since your first angle is just 3.9. Let's make sure we have correct numbers first. That seems to be the biggest challenge.
