just got back from the dealer
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoskim, Jul 24, 2008.
  1. Jul 24, 2008 at 11:56 AM
    tacoskim
    tacoskim [OP] Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    so i took my truck in cuz i had a bad vibration while turning from a dead stop and while parallel parking. they checked everything and said it was cuz the cap wasn't lubed. so i guess he lubed it but i still feel a little bit of vibration just not as bad... can this really be cuz the cap wasnt lubed or can it be something else?
  2. Jul 24, 2008 at 12:19 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    What cap?
  3. Jul 24, 2008 at 12:20 PM
    tacoskim
    Los Angeles, CA
    Stock
    the wheel cap
  4. Jul 24, 2008 at 12:55 PM
    tacoskim
    Los Angeles, CA
    Stock
    anyone?
  5. Jul 24, 2008 at 1:03 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    when you say wheel cap? are you talking about the center plastic piece?
  6. Jul 24, 2008 at 1:07 PM
    tacoskim
    Los Angeles, CA
    Stock
    yea the hub cap
  7. Jul 24, 2008 at 1:07 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    thats what im wondering, if it is so, then sounds like a scam to me....
  8. Jul 24, 2008 at 1:10 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    are you sure it wasn't your muffler bearings?
  9. Jul 24, 2008 at 1:11 PM
    tacoskim
    Los Angeles, CA
    Stock
    all he said was that the cap wasnt lubed enough so he lubed it and no more vibration. but i still feel the vibration kinda when the tires are fully turned (locked)
  10. Jul 24, 2008 at 1:12 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Sounds like complete bullshit to me.
  11. Jul 24, 2008 at 1:13 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    they're probably rubbing on your wheel well.
  12. Jul 24, 2008 at 1:14 PM
    tacoskim
    Los Angeles, CA
    Stock
    i got stock tires on right now... theyve never rubbed in the past when they got rotated but now they rub after this rotation? i never had this problem till i picked up my truck from getting the 30k service done
  13. Jul 24, 2008 at 1:32 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    Thats wierd never heard about lubing a cap.
  14. Jul 24, 2008 at 1:36 PM
    tacoskim
    Los Angeles, CA
    Stock
    I KNOW! i was kinda weirded out when he told me, i was kinda confused but i was running late to work, he took awhile inspecting it so i took his word when he said no more vibration. so i drive here to work and feel it when im parking, i just called my service guy and hes at lunch so i will call back in a few...
  15. Jul 24, 2008 at 1:36 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    Take a little initiative before running to the dealer for every little noise/problem; get a good bright flashlight, and look under the front fenders, and check for spots where there has been any kind of contact. If that fails, get a friend to help you by standing to the side of ther truck while you drive slowly with the front wheels turned full lock in both directions, and try to reproduce the sound. Feathered tires can make noise, but it would have to be extreme before you would hear much noise, so I would not think that is your problem.
  16. Jul 24, 2008 at 1:39 PM
    tacoskim
    Los Angeles, CA
    Stock
    this is the first time i ever took it in for a problem.. and im sorry but i just got it serviced this past weekend had have never had this problem. i get my truck back from the dealer after service and i get this??? whatever it is the service department did this problem so they should fix it, i have every right to go back to them for this, its their fault not mine
  17. Jul 24, 2008 at 1:41 PM
    tacoskim
    Los Angeles, CA
    Stock
    and we did do the stand outside and hear test, and the mechanic definitely heard something while the tires were locked, he also felt it when test drove it
  18. Jul 24, 2008 at 1:43 PM
    nermalgod
    nermalgod Well-Known Member
    Bend, OR
    Offroad boat hauler
    Not going to brag.
    Could it be drive shaft vibration? and you only feel it because of the slop speeds involved?
  19. Jul 24, 2008 at 1:47 PM
    tacoskim
    Los Angeles, CA
    Stock
    i only feel it on dead stop, then turning all the way or parallel parking.
    so just got off the phone with my service guy and he said what was lubricated was the steering stop cap on the suspension.
    can someone fill me on this cap?
  20. Jul 24, 2008 at 1:53 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    I remember them on my older toyota trucks, you had to lube them or the truck would make a horrendous metal on metal noise when turning sharp into a parking space (kinda like what you are describing). I didn't realize the newer ones had them. Now I am going to go look, it is hard for me to explain. Usually there was a plastic cap too if I remember correctly, its been a while since I heard the god forsaken noise. :eek:
