just got my 2.7 back rebuilt and installed
Discussion in '1st Gen. Tacomas (1995-2004)' started by donaldwagner, Nov 6, 2011.
  1. Nov 6, 2011 at 4:03 PM
    donaldwagner
    donaldwagner [OP] -Don-
    Donald
    College Park, Orlando
    2013 single cab 4x4
  2. Nov 6, 2011 at 4:05 PM
    ChamYota
    ChamYota Crash Bandicoot Or Groot AKA Cham "Scottalot" Yota
    Cam
    Columbia,South Cakalacky
    05' Taco 4x4 swapped/ 2007 Toyota Land Cruiser
    H1 Morimoto projector with XB35 4300K bulbs with Mini-gatling gun shrouds, BHLM. Debadged,OEM roof rack,TW sticker,Sockmonkey Beside decals,265/70/16 Nitto terra grapplers with dick cepek DC'2 wheels,weathertech floor liners(front/back),USA Spec Ipod reader,Scanguage II,Bestop Supertopper and more in the works...
    Good to know another taco is back on the roads. :thumbsup:
    What was the problem with it?
  3. Nov 6, 2011 at 7:43 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    how many miles before the rebuilt? my brother did his '02 over the summer at 245k miles.
  4. Nov 19, 2011 at 2:20 AM
    donaldwagner
    Donald
    2013 single cab 4x4
    i had a balance shaft bearing go bad, just reving it high while i had this insane bro lean going on, started ticking so i shut it off, big error on toyota for these motors, the front bearings on the balance shafts have oil galleries but the back bearing dont, just supposed to get splashed from the oil pan, so got the balance shaft delete kit from LC engineering along with a rebuild kit, had the block bored .30 and crank turned .10, fly wheel turned and stage 3 clutch and motor mounts, need to do some 4:88 gears and a locker now.
  5. Nov 19, 2011 at 2:25 AM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    What size tires you got under that thing? Looks good
  6. Nov 19, 2011 at 2:35 AM
    donaldwagner
    Donald
    2013 single cab 4x4
    38.5x11r15
  7. Nov 19, 2011 at 2:38 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    go 5.29 with that tire size. i have 4.88s wih 33s
  8. Nov 19, 2011 at 4:51 AM
    wolfgang123
    wolfgang123 Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    what gears do you have now i figured you already had like 5.29s
  9. Nov 19, 2011 at 5:45 PM
    donaldwagner
    Donald
    2013 single cab 4x4
    i have stock 4:10 gears, im gonna have 4:88s put in
  10. Nov 19, 2011 at 7:56 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    What type of lift does it have, and what's the total amount of lift?
  11. Nov 20, 2011 at 5:00 PM
    Cb2589
    Cb2589 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
  12. Nov 25, 2011 at 5:42 AM
    donaldwagner
    Donald
    2013 single cab 4x4
    that could very well be it! mine had a wierd tapping couldnt tell if it was coming from the intake, exhaust, engine or transmission! but that bad bearing made the whole motor lag in power due to the secondary timing chain being in sync with the main timing chain
  13. Nov 25, 2011 at 5:46 AM
    Cb2589
    Corey
    VA
    That's really weird. I put a stethescope on it and it sounded louder at the top end closer to the front compared to anywhere else. And when we pulled the motor one of the tensioners to the timing chain for the balance shaft was broken and the chain made a slap noise like in the video which is why we replaced them. After reading what you described I feel like that could very well be what's wrong with my truck. I've driven mine with the noise for over 30k and no problems and no lack in power.
  14. Nov 25, 2011 at 6:03 AM
    STRYTLR
    STRYTLR Member
    GT
    Central FLA
    '96 Taco 4X4 4.5" Lift CoilOvers 2.7L // 5spd
    Fabtech Coil Overs,Add -a- Leafs,2" Body Lift,33" A/T's
    nice truck!! what did the rebuild end up costing? i've got a '96 w/a bad 2.7 motor and i think it's the same issue, it broke two harmonic balancer's and the oil pump before the timing chain seized up (not even sure if it's rebuildable), i found a 2.4 for 500.00 w/88k miles on it, but not sure if there interchangeable
  15. Nov 25, 2011 at 6:17 AM
    donaldwagner
    Donald
    2013 single cab 4x4
    i think the 2.4 internals are different, just the block itself is the same. i paid $500 to machine shop for putting in new freeze plugs, counterbalance delete bearings, boring .30, turning the crank .10, and turning the fly wheel. then the engine kit was $400 from LC Engineering, and the counterbalance delete kit was another $100, and $500 labor to the mechanic for doing it on the side, plus 2 motor mounts $80 and a new clutch $160, right around $1800 :(
  16. Nov 25, 2011 at 7:06 AM
    STRYTLR
    STRYTLR Member
    GT
    Central FLA
    found this on eBay,,
    reman 1195.00 plus 195. shipping
    http://www.ebay.com/itm/Toyota-2RZ-...Parts_Accessories&vxp=mtr&hash=item1c208ec64a
  17. Dec 4, 2011 at 8:24 AM
    donaldwagner
    Donald
    2013 single cab 4x4
    if i had to do it again, i would go the ebay route, with a warranty, rather have a motor thats never been opened up
  18. Jan 10, 2013 at 7:32 AM
    BamaToy1997
    Bill
    Navarre, FL
    Actually the rear bearing IS internally lubricated (I know, commenting on an old thread, but still on subject of the balance shaft delete).
    The balance shaft itself has a center-line hole drilled in it, and lubrication oil that is forced into the front bearing passes into the center-line, then out a small hole in the shaft to lubricate the rear bearing.
  19. Jan 10, 2013 at 7:39 AM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Good work on this...I would much rather rebuild an existing motor than buy a used or rebuilt with unknown history and problems.
    Now, at $500, did the mechanic really make any money off the job? Normally I would have the machine shop reassemble the motor for me and I would do the install.
    Howard
  20. Jan 10, 2013 at 8:56 AM
    makou99
    makou99 Well-Known Member
    Marc-Andre
    Edmundston
    96 Tacoma
    nice truck bro what lift do you have on that?
