Just got my coil overs today from freedom off-road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808kalohi, Feb 7, 2017.
  1. Jan 24, 2018 at 4:25 PM
    #101
    Big 'O Taco
    Big 'O Taco Member
    It's a 98, but are you sure they measure about 20"? Mine are 27" with the weight of the truck on them.
  2. Jan 25, 2018 at 6:01 AM
    #102
    Pigpen
    Dan
    Northwest Montana
    Gen1 and gen 2 front shocks have different mounts. Make sure the product you buy fits your truck! Gen 3 uses the same mounts as gen 2.
  3. Jan 25, 2018 at 6:40 AM
    #103
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Yes 20" from the bolts on top to the bolt on the bottom.
  4. Jan 25, 2018 at 6:48 AM
    #104
    Big 'O Taco
    Big 'O Taco Member
    I'm aware of the upper mount has a different bolt pattern, I can figure that issue out. Unfortunately, I'm trying to figure out an option that does fit my truck. Currently all I'm finding are replacement shocks that came with my lift kit for something that will fit. I'm an upgrade, not replace kind of person. Seems like even though 2g coilovers are longer than my stock ones, they're still going to be too short for my application.
  5. Jan 25, 2018 at 10:16 AM
    #105
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Keep in mind I have a 6" spacer on top of mine due to my RC lift kit.
    808kalohi[OP] likes this.
  6. Jan 25, 2018 at 10:34 AM
    #106
    Big 'O Taco
    Big 'O Taco Member
    I was afraid of that, I'd need at least a 3" spacer if I used these. At that point, it's not really worth the work it'd take to put these on. Probably be best to just run the ones that came with my kit and deal with people making fun of my Tacoma lean until I figure another remedy for it.
  7. Jan 25, 2018 at 10:47 AM
    #107
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Or you could, dare I say it, not run a drop bracket lift.
  8. Jan 25, 2018 at 11:21 AM
    #108
    Big 'O Taco
    Big 'O Taco Member
    Take it easy buddy.
  9. Jan 25, 2018 at 3:18 PM
    #109
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    What does a drop bracket lift have to do with Taco lean?
  10. Jan 25, 2018 at 4:24 PM
    #110
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Did you read what he’s written? He’s trying to find a coilover to fit a lift that shouldn’t be on his truck anyways.
  11. Jan 25, 2018 at 4:29 PM
    #111
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Did you read what post you quoted?
  12. Jan 25, 2018 at 4:42 PM
    #112
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Has the cold gone to your head? I know your not used to it down there in the south so maybe your brains frozen. Let the grown ups finish talking.
  13. Jan 25, 2018 at 4:45 PM
    #113
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Grown ups? Ok *you're* It's 77 here by the way.
  14. Jan 25, 2018 at 4:45 PM
    #114
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Don’t correct Dad.
  15. Jan 25, 2018 at 4:47 PM
    #115
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    You'd be more of a really old man not a grown up to be my dad.
  16. Jan 25, 2018 at 4:47 PM
    #116
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    You got it skip.
  17. Jan 25, 2018 at 4:51 PM
    #117
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    72? That'd be roughly old enough to be my dad.
  18. Jan 25, 2018 at 4:56 PM
    #118
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
  19. Jan 25, 2018 at 5:19 PM
    #119
    Grey 2015
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Don't be a hater just cause I got a nicer truck than you. Lol!
  20. Jan 25, 2018 at 5:21 PM
    #120
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Rough country, freedom coilovers, and a badlands winch. Shit yea I can’t compete with that list of badassness. Whew your a real baller.
