Just got my new Toytec lift in today
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rock4200, Nov 12, 2008.
  1. Nov 12, 2008 at 2:04 PM
    rock4200
    rock4200 [OP] Active Member
    Maryland
    SR5 TRD Off-Road 6spd manual w/ Towing Pack
    Black headlight mod, Sockmonkey's lower blackout grill
    :)Just received my new toytec lift in today 3" spacers w/ aal snd diff drop can't wait to install any advice on the install ?:)
  2. Nov 12, 2008 at 2:05 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    cant wait to see the pics!!
  3. Nov 12, 2008 at 3:06 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  4. Nov 13, 2008 at 9:23 AM
    mvega1969
    mvega1969 Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    Does your truck has the TSB (rear spring) installed?
    and if yes, are you going to add a leaf (fifth one)? is this one is long or short? Any other hardware required for this is included in the kit?
    Thanks,
    Regards.
  5. Nov 13, 2008 at 1:27 PM
    rock4200
    Maryland
    nope no TSB never needed it have 100,000 miles no sagging + my 80,000 miles are up yes longer center bolts come with the kit
  6. Nov 13, 2008 at 1:29 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    100k miles on your 05? dayum
  7. Nov 13, 2008 at 8:55 PM
    rock4200
    Maryland
    yep and the check engine light has been on for a year and Toyota can't even find the problem
  8. Nov 13, 2008 at 8:56 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    +1 Can't want to see pics.
  9. Nov 14, 2008 at 5:31 PM
    rock4200
    Maryland
    soon as this rain stops The lift will be going on
  10. Nov 14, 2008 at 9:34 PM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Why did u get the AAL instead of the 1.5inch blocks? Not criticizing I really dont know the difference as to why you would pick one or the other
  11. Nov 15, 2008 at 3:40 AM
    bryan83taco
    bryan83taco Well-Known Member
    Hawai’i
    2023 TRD Sport 4x4
    AAL's ride ALOT better than blocks
  12. Nov 15, 2008 at 5:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2.
    Blocks also tend to exagerate axel wrap, as they move the fulcrum point down a bit, they also can wear out the leaf pack sooner, AND, the coupe de gras, they are more likely to break.
  13. Nov 15, 2008 at 10:11 AM
    billas333
    Joel
    NorCal
    Are AAL's any more difficult to install versus the ease of a block?
  14. Nov 15, 2008 at 3:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think so. It may take a few minuets longer, but its a better set up.
  15. Nov 15, 2008 at 4:02 PM
    Justin626
    Justin626 Well-Known Member
    Palmer, Alaska
    2007 4x4 TRD Sport DC Super White
    Toytec 3" w/ AAL, N-Fab Nerf Bars, Lightforce 170mm Strikers, N-Fab Light Bar, Metra Ipod Adapter, Scosche Auto Start
    I didn't think that the AAL's would be a big deal, but they ended up being a bigger pain then the front shock assemblies. You are gonna need to be prepared to disconnect your rear brake lines, leading you to bleed your brake system when you are done installing the lift. With the rear brake lines still connected, there is not nearly enough room to squeeze the new leaf, overload leaf, and the longer center bolt between the old leaves ane the rear axle. Or you can remove your leaf packs all together and use a hydraulic press to compress them while off the truck.
    If you decide to go with the first choice, are gonna need some heavy duty c-clamps to keep the two long leaves held together.
  16. Nov 15, 2008 at 4:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I never had to disco my brake lines. If you remove the brake line braket, you should have plenty of room to do the install. And you can modify the braket to acomodate the lift. And yes, 2 6" "C" clamps make the job MUCH more easy. :)
  17. Nov 15, 2008 at 4:10 PM
    Justin626
    Palmer, Alaska
    I thought about removing the brakets, but I was afraid I would kink them. Chris, do you have pics of the modified braket, if you did yours? I still need to do something with mine.
  18. Nov 15, 2008 at 4:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont have any pics. I can get some, but I have to download a bunch of stuff off my camera first. I'll try to get some tomarrow for ya. Its really simple to do. When finished installing everything, just bend the braket to where it allows for the lift. Since the springs arent going to flex more than stock (unless you have longer shocks), you should only bend the braket an inch or so. Hardly noticable. :)
  19. Nov 15, 2008 at 5:49 PM
    Neubs
    Maryland
    +1 I never had to disconnect my brake lines either. I simply disconnected the brackets and I had plenty of room. Same is true with the e-brake lines, just disconnect the bolt that holds the line to the frame and you should be fine.
  20. Nov 15, 2008 at 10:24 PM
    bryan83taco
    Hawai’i
    2023 TRD Sport 4x4
    X2 Never had to disconnect my break lines. Just used the jack to lower the axle down enough to put the leaf in there.
