Just got my toytec lift installed have couple ?????
Discussion in 'Suspension' started by jordando89, Feb 20, 2012.
  1. Feb 20, 2012 at 11:51 AM
    jordando89
    jordando89 [OP] Well-Known Member
    jordan
    idaho
    2008 white double cab long bed sport 4x4
    3in lift painted sport wheels
    5100 all around and add a leaf front set at 1.75. but the coils are rubbing on the stock ucas. i have stock rims with 265/70/17 bfg at they didn't rub before lift and now they do in a couple places. new rims wheel help I'm sure but would it be better to go to .85 or get new ucas? can't get new ucas for awhile. it drives fine just a little stiff and u can hear it rub on bumbs sometimes.
  2. Feb 20, 2012 at 12:08 PM
    98regstick
    98regstick Well-Known Member
    Maryland
    '11 DCSB SR5
    OME 90021 with 885s and top plate spacer, 2" AAL, OME rear shocks, Camburg Uniball UCAs, OME CB Drop, 285/75/16 BFG AT's on Level 8 Guardian wheels
    Looks like you have eibach coils. If this is the case, I believe it is not a good idea to exceed the .85" setting on the 5100s when using the eibachs.
    Maybe reset the c clip to the .85 setting and see if you're still having contact with the UCA. There are numerous people running the 5100/eibach combo and 265s without issue.
    Hopefully some experience will chime in. Good luck!
  3. Feb 20, 2012 at 12:13 PM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Holy phuck, yea dude you are wayyyyy too high
  4. Feb 20, 2012 at 12:14 PM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    drop a down a clip, and get some new uppers, you are gonna destroy those nice tires if you don't.
  5. Feb 20, 2012 at 12:19 PM
    jordando89
    jordan
    idaho
    i had the toyota dealer install it and thats how they did it I'm going to go ask they to drop it down.
  6. Feb 20, 2012 at 12:21 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    What's your hub to fender up front ?
  7. Feb 20, 2012 at 5:30 PM
    jordando89
    jordan
    idaho
  8. Feb 20, 2012 at 5:33 PM
    OZ-T
    Peter North
    British Columbia
    That's almost an inch too high for a 4x4
    Pics of your cv's ?
  9. Feb 20, 2012 at 5:34 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Yeah, I thought you were supposed to keep it at 0 with the Eibachs? I had my 5100's set at 1.75 with stock coils and it killed my tires. I would definitely drop it down.
  10. Feb 20, 2012 at 5:36 PM
    OZ-T
    Peter North
    British Columbia
    Some guys run eibachs / billies at .85 , which would be almost an inch lower than where the OP is
  11. Feb 20, 2012 at 5:47 PM
    jordando89
    jordan
    idaho
    if i drop it down to .85 i have to get another alignment right? it does sit a little bit front high. should toyota do it for free cause they never even asked they just did what they wanted.
  12. Feb 20, 2012 at 5:49 PM
    OZ-T
    Peter North
    British Columbia
    Yes
  13. Feb 20, 2012 at 5:50 PM
    OZ-T
    Peter North
    British Columbia
    In your pics , is that water or fluid on your LCA's ?
  14. Feb 20, 2012 at 5:53 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    It looks like your CV is already puking.
  15. Feb 20, 2012 at 5:55 PM
    OZ-T
    Peter North
    British Columbia
    That's what I was thinking
  16. Feb 20, 2012 at 5:56 PM
    jordando89
    jordan
    idaho
    its just water its raining and i just got done driven
  17. Feb 20, 2012 at 5:58 PM
    OZ-T
    Peter North
    British Columbia
    Drop it ASAP
  18. Feb 20, 2012 at 6:03 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If the OP had simply set the 5100s too high, should the Toytec Eibach coils hit UCA? This would mean, even with a "correct" install, the coil would hit the UCA at full suspension droop.
  19. Feb 20, 2012 at 6:04 PM
    OZ-T
    Peter North
    British Columbia
    Is the UCA not being put at an extreme downward angle by the exsessive height , effectively narrowing the space for the coil ?
  20. Feb 20, 2012 at 6:06 PM
    jordando89
    jordan
    idaho
    i think its because the extra height
