Just had Flowmasters installed. Smoke in bed?
Discussion in 'Performance and Tuning' started by QBowman17, May 9, 2011.
  1. May 9, 2011 at 2:37 PM
    QBowman17
    QBowman17 [OP] New Member
    Knoxville, TN
    07 DoubleCab TRD
    Hard Cover, Bull Bar
    I just had Flowmasters put on my truck, looked at it when i got home and there is a small amount of smoke coming up between the cab and the bed of the truck. I was just wondering if this was normal?
  2. May 9, 2011 at 2:39 PM
    RPain
    RPain Well-Known Member
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    did you just have your muffler replaced or the full exhaust? did you look under the truck and see if it was coming from the muffler?
  3. May 9, 2011 at 2:40 PM
    thebikeguy
    thebikeguy Well-Known Member
    VA
    07 DC/SB TRD OR PreRunner
    Bilstein 5100 set at .85, Satoshi grill
    i have a flowmaster on mine, but i dont remember any smoke. i have just a muffler on mine tho
  4. May 9, 2011 at 2:42 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
    its normal, i think new mufflers come oiled or something to prevent rust (I think), it should stop doing it after a while
  5. May 9, 2011 at 2:42 PM
    Ptowntaco
    Ptowntaco Camburg :)
    Bryce
    Petaluma Ca.
    2000 Prerunner TRD
    Tint, Socked, Deck Plate mod, Camburg 2.5 coils, Camburg UCA, 5100's in the rear, Custom Deaver leaf pack, Micky Thomson Classic Locks, BFG KM2, CB
    Could just be the baffling in the new muffler burning away?
  6. May 9, 2011 at 2:42 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    well it depends did you have it welded on? if you did then they didnt weld it all the way.
    if it was clamped on then there is a leak also or it might just be breaking in. is the smoke coming out when trucks running or after you shut it off?
  7. May 9, 2011 at 2:42 PM
    Frostbyte
    Frostbyte Well-Known Member
    Northern Utah
    03 Black SR5 4x4 TRD Off Road
    RIP - 07 Radiant Red SR5 4x4 TRD Sport Fabtech 6" lift, 33x12.50.18 Toyo M/T on All black XD Hoss wheels
    burnng of the factory oil on the exhaust pipes maybe... crappy comparison, but when i replaced my yfz450 exhaust, it smoked for a bit till the oil coated on the pipes were burned off.
  8. May 9, 2011 at 2:44 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    It could be residue on the new muffler that is burning off. They do smoke and smell sometimes when they are brand new. I would still visually inspect it though to make sure its not making contact with something it could melt or if there are any leaks.
  9. May 9, 2011 at 3:02 PM
    RPain
    Chandler, Arizona
    yeah its most likely the residue burning off i wouldnt worry about it
  10. May 9, 2011 at 3:08 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    no smoke on mine.
  11. May 9, 2011 at 3:25 PM
    QBowman17
    Knoxville, TN
    07 DoubleCab TRD
    Its welded on and its just when the truck is running. Ill keep an eye on it, hopefully it'll go away after awhile
  12. May 9, 2011 at 3:34 PM
    johnw
    john
    orlando florida
    yeah or just get under there and look when its running the welder might have missed a spot ant its got a leak or like others have sid the coating on it might be burning off but i say atleast look at it and see if its touching things it should and generaly inspect it right quick
  13. May 9, 2011 at 6:11 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    It's definitely the oil burning off from when it was manufactured. 100% normal.
