Just installed AAL and Billys...anyone have this problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mainewoodsballer, Dec 22, 2012.
  1. Dec 22, 2012 at 6:44 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    It's probably the "Taco Lean." Just get a 1/4'' spacer to put on the front. Not sure how to correct the rear though.
  2. Dec 22, 2012 at 6:44 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Dakar heavy springs, sumo bump stops, with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker, ARE Topper
    Odd... I installed my rear AAL and 5100's and my measurement was the same on both sides. I only had Taco lean on the Drivers side front after I installed 5100's a few weeks later. Corrected with a taco lean spacer but I never had a difference in the rear height.
    The link to the lift you ordered includes a top plate spacer for the drivers side. Im curious to see how this affects the left rear once installed.
  3. Dec 22, 2012 at 6:48 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    1/4 block on the rear driver side :cool:
  4. Dec 22, 2012 at 6:52 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    Like Dis?
    :D
  5. Dec 22, 2012 at 6:53 PM
    mainewoodsballer
    mainewoodsballer [OP] YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Il just throw a hockey puck under it....Puck IT!
  6. Dec 22, 2012 at 6:54 PM
    Joels98taco
    joel
    chino hills
    98 5 lug tacoma
    yezzir :D
  7. Dec 22, 2012 at 7:15 PM
    mainewoodsballer
    Ol' Waltah
    Maine
    Or I will just have to get a fat girl. That might help level things out
  8. Dec 22, 2012 at 7:32 PM
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    Fat girls need love to man! :cool:
  9. Dec 23, 2012 at 9:04 AM
    Badgtho
    Badgtho Well-Known Member
    Ben
    CT
    '13 TRD sport 6spd
    TRD exhaust, TRD beadlock wheels, moto xtender
    Put the front in and then re assess. It's amplified by the rake.
    Also. With any aal you should loosen up the u bolts and jump on the rear bumper a few times and the. Re tighten to make sure no spring bind is the cause.
  10. Dec 23, 2012 at 4:32 PM
    mainewoodsballer
    Ol' Waltah
    Maine
    Im drove it today and no change. I will have to ask the dudes about it when I get the front put on thursday.
  11. Dec 23, 2012 at 4:37 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Sounds like you got the taco lean. I have it pretty bad also. Do you have the lean in the front right now? Even with the stock suspension it might be there. I have heard if you correct it in the front it should help with the rear.
  12. Dec 23, 2012 at 4:43 PM
    mainewoodsballer
    Ol' Waltah
    Maine
    No there is no lean with the front...but its still stock. and it was never there before when it was all stock. I am 100% sure. I get a little OCD with my toys haha. Just have to put the front on and maybe loosen up the U bolts and bounce it around before tightening it.
    .....I will fix this mother! haha
  13. Dec 23, 2012 at 4:43 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    interesting issue. sub'd for post front lift results.
    :popcorn:
  14. Dec 23, 2012 at 4:52 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    Taco lean, even before my lift and with a full tank my passenger side was 3/4" higer than the drivers side. The difference can varie from Taco to Taco.
  15. Dec 23, 2012 at 5:14 PM
    #35
    evanmb31
    evan
    connecticut
    09 trd off road
    Hmmm have someone jump in the bed and make sure your shackle is moving on the drivers side as much as the passenger side, maybe even loosen them. Well seeing as your in maine and it is winter it is always a good thing to have some sand. Throw 100 lbs of sandbags in the back of the bed on the passanger side lol. It might be possible that one add a leaf has more arch than the other? Just a theory.
  16. Dec 23, 2012 at 5:56 PM
    #36
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    /\ More arch than the other... very interesting idea! Never thought of this.
  17. Dec 23, 2012 at 5:58 PM
    #37
    mainewoodsballer
    Ol' Waltah
    Maine
    They seemed the same when I received them. They were packaged together one on top of the other.
  18. Dec 23, 2012 at 6:04 PM
    #38
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    I looked at the pics in your gallery and it looks TO ME like the truck was SLIGHTLY leaning to the driver's side, but I know you say you didn't notice it before. Until you finish putting the lift on, I would not worry about it. There is a reason the kit comes with a single 1/4" top plate spacer.
  19. Dec 23, 2012 at 6:14 PM
    #39
    evanmb31
    evan
    connecticut
    09 trd off road
    Well i know in the case of full leaf packs, like dakars, sometimes they are above or below spec and the arch might vary. If it did vary for add a leafs it probably wouldnt be enough to be noticable though.
  20. Dec 23, 2012 at 6:21 PM
    #40
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    I wouldn't stress until you but the billies on the front and then do damage control..
