Just installed AAL and Billys...anyone have this problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mainewoodsballer, Dec 22, 2012.
  1. Dec 23, 2012 at 6:21 PM
    #41
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    If you read teamlombardo's post here it shows that after he installed a top plate spacer on the drivers side it actually lowered the rear passanger side measurment, he had tacolean in tw front though so i am not sure it would apply to you OP
    I am also looking to solve this issue, i have over 1/2" of taco lean in the rear, and just under 1/2" in the front
  2. Dec 26, 2012 at 5:32 PM
    #42
    mainewoodsballer
    mainewoodsballer [OP] YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    Well I got the front on today. Had the guys loosen up the Ubolts in the rear and re-tighten them..with the front spacer in the truck looks pretty level as far as I can tell. I will post pictures soon
  3. Dec 26, 2012 at 6:42 PM
    #43
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    not true
    If you're a 2nd gen. there is no "longer side to the back"
    If you were a 1st gen. then yeah, but 2nd gens are equal length from centerpin to eyeletts...
    You may have swapped sides by accident, driverside main leaf is slightly more ARC'd than pass. for the whole "taco lean" issue
  4. Dec 26, 2012 at 7:58 PM
    #44
    JNome
    JNome Made in Maine.... Yessah bub!
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    WeatherTechs, TRD Skidplate, Hidden Hitch Reciever, Tractor Supply Toolbox, Bedmat, Hayden Transmission Cooler, Leer 100R cap, yakima roof rack, Bilstien 5100's all around, Eibach lift coils, Toytec AAL w/ TSB springs, All Pro Flip Kit w/ Timbrens, Line X'd Rocker Panels, Magnaflow 17115 Exhaust, Cobra CB w/ PA Horn, Hi-Lift Jack w/ custom mount, Relentless Fab Sliders, Satoshi Grille w/ Hella 700's HID mounted behind
    ^I agree with this.... I installed this same lift last friday and measured the leafs from center hole to end.... they are exactly the same length on each end so there is no long side or short side. I'm guessing the misalignment might come from slightly different arches in the AAL's as mentioned earlier. I also had a bunch of sand in mine from these Maine roads and I made a point to clean out the leafs before reinstalling to prevent binding.
    I noticed that when taking mine apart and reinstalling that I had to pay special attention to lining the spring back up with the axle... maybe you are misaligned slightly here as well, or have some sand in between the spring pack and bracket on the axle on the high side causing it not to seat inot the bracket properly????
    I don't know... sounds to me like you should just let it settle out and see what happens
    Different tire pressure? :D
    Sub'd to see the results
  5. Dec 27, 2012 at 9:08 AM
    #45
    mainewoodsballer
    Ol' Waltah
    Maine
    well the ones I received were directional. For my 2011.
    Here is it:
  6. Dec 27, 2012 at 10:46 AM
    #46
    JNome
    Jake
    Pace, FL
    '10 BSP SR5 4wd
    Seems fine now.... mine were for the tsb pack so maybe the other leafs are different.... where in maine are yah
  7. Dec 27, 2012 at 11:32 AM
    #47
    11TRD
    11TRD MERICA
    Jay
    Everett, WA
    2011 TRD SPORT 4X4 DC
    RHLM (Red Headlight MOD), Cobra 29 WXNWBT, Devil Horns, ARB Bumper, Avid Stepbars, Homer Taco Satoshi thin lip grille, ICON UCA's, ICON EXT Travel up front with King 700# springs, Toytech 2 inch AAL with ICON VS 2.0 shocks in the rear, K&N Drop In, AVS Ventshades and Bugflector, Whelen SPS 660 emergency strobes, Redline Hood struts and tailgate EZdown, Illuminated 4X4 Switch, TRD Floor mats, Flyzeye LED lighting, Kragen 7" HID behind grille, Kragen 4" HID back up lights, Rigid SR Series 10" LEDx2 Elusive elements Lightbar, Firestik antenna, Rear Diff breather mod, Fogs anytime, Hitch Safe, OEM door sill strips, mryo mirror relocate bracket, Prinsu designs roof rack, Tepui Autana RTT, ARB Awning,Engo 10k winch synthetic, Blue seas fuse block and breaker,
    Non TSB AAL are directional.
    Looks GOOD!!!:cool:
  8. Dec 27, 2012 at 11:38 AM
    #48
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
    Yea my TSB aal's are directional. Looks good OP.
    edit: I think mine are directional. It was a few beers ago when I installed them so I could be mistaken.
  9. Dec 27, 2012 at 11:54 AM
    #49
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    A little confused, what is meant by directional ??
    EDIT: Ok did a little looking , is this a shim we're talking about ??
  10. Dec 27, 2012 at 2:02 PM
    #50
    ajohnson
    Andy
    Charlotte, NC
    The center pin hole is offset. One side is longer than the other. The long side goes to the rear IIRC to fight axle wrap.
  11. Dec 27, 2012 at 2:35 PM
    #51
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Oh, I know that, 1st gens are eliptical (offset) but 2nd gens aren't, their equal, wonder why they put an eliptical spring on a 2nd gen...
    Dont know why they did, but at least that clears up my confusion...
  12. Jan 2, 2013 at 7:41 PM
    #52
    mainewoodsballer
    Ol' Waltah
    Maine
    Near Skowhegan you?
