Just installed B&M sport shifter...but have some questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lunercrab, Feb 24, 2008.
  1. Feb 24, 2008 at 9:06 PM
    Lunercrab
    Lunercrab [OP] Well-Known Member
    Beth
    Lehigh Valley area, PA
    2019 off road cement
    Ok so i finally bought and installed my B&M sport shifter today and boy it's nice...the shifter is tight and the trucks seems to shift so much smoother...now i do have two complaints (which i guess are common problems) since the shifter is one solid piece there is more vibrations (which doesn't bother me that much) but there is a drastic amount of outside noise comming through...I know this is going to get real annoying, real fast...basically is there any suggestions how to maybe improve this? is there maybe some kinda of sound dampering i could do around the shifter?...after using this for only a few minutes, i definitely don't want to revert back to stock...plus one more thing, i'm not sure if anyone has this on their truck or not, but the instructions told me to make sure the cup is seated properly, when i installed it i'm guessing everything went together correctly...it did take some fussing to get it to sit properly, but i'm guessing if it wasnt together correctly i would notice it right away when i use it right?...like i said it's gunna take alittle getting used to, but it's a sweet piece [​IMG]
    sorry i don't have pics of the actual install, but here's what the shifter looks like if that helps 5397_1_e0eebf1293107c6ea160c62a9fdeb16a1e134360.jpg
