Just installed Block Heater
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgaudet7, Oct 12, 2008.
  1. Nov 12, 2011 at 1:50 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Remote start will have a warm car for you faster than a block heater.
    If you need a block heater though, you need it. Not remote start.
  2. Nov 12, 2011 at 2:00 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  3. Nov 12, 2011 at 3:40 AM
    Manwithoutaplan
    ID
    Ok cool. I though I was going to get a post saying iwas retard becuase I posted that :$. Pretty insightful. With living in a warmer enviroment did not know if one was better than the other.
  4. Nov 12, 2011 at 5:55 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Don't know where U R from. Southern CA or northern CA if U R far enough north, yes. The 6 cy 4.0 has a spot already built in the engine block for the heater. It's so simple and easy why not if it gets below 30F. As others have said you don't have to let the truck idle for ever in the AM.
    For those with 2.7 it's a lot more work.
  5. Nov 12, 2011 at 6:29 AM
    shawnd2
    shawnd2 Well-Known Member
    Shawn
    Toronto, Ontario, Canada
    08 Tacoma Access Cab 4x4 TRD Offroad
    Personally I don't bother to plug in my block heater unless the temperature is below 15 deg F.
    I also have remote start and to me a block heater is used to keep the oil warm to help with wear when first starting up. I've lived places where it gets colder then -40 and a block heater is almost a necessity. I remember one christmas morning when 7 out of 8 cars wouldn't start because the temp got below -55 F and we had to put spot lights underneath the oil pans to help thin the oil.
    At 30 F the oil will have no problems flowing.
    I use my remote start almost all the time, not as a benefit to my truck (as idling for several minutes is probably harder on it) but as a benefit to me as my truck is nice and warm/cold when I get in.
    Shawn
  6. Nov 12, 2011 at 6:53 AM
    george3
    New Jersey
    "At 30 F the oil will have no problems flowing." I'm sure you are right but my motor use to tic when it started below 30F so I switched to syn and put on a oil pan heater and no more tic. I ass-u-me the tic is valves - can't be good for the motor. No more tic.
  7. Nov 12, 2011 at 8:09 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    My remote start kills the engine if you step on the brake without the key in and turned to ON.
    Additionally, if you shift gears with the alarm on, the truck will try to turn off.
    That's my belief between the two, too. Block heater to make initial starting nicer, remote start for warming it the rest of the way.
