Just installed new mirror
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElderP, Aug 14, 2015.
  1. Aug 14, 2015 at 7:23 PM
    ElderP
    ElderP [OP] Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
  2. Aug 14, 2015 at 7:28 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Nice. Where did you tap power from?
  3. Aug 14, 2015 at 7:33 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    This is the first mod I will be doing to my 2015, I hate that Toyota took away Outside Temp and Compass.
  4. Aug 14, 2015 at 7:37 PM
    ElderP
    West Virginia
    I used an add-a-fuse in the block in the cab. Tapped off the AC fuse. Ran both sets of wires up the pillar (which was very easy to remove). Remove the driver sun visor and it's real easy to pull down the headliner just enough to run the wires to the mirror.
  5. Aug 14, 2015 at 7:39 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Thank you. I've wanted outside temp for a while ... just keep telling myself I can do without it, 5 yrs now ... $128 is tempting.
  6. Aug 14, 2015 at 7:43 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    One more question, did you have to use their "replacement wedge button," or does it fit on the existing mirror "button."
  7. Aug 14, 2015 at 7:43 PM
    Dogdad
    Dogdad Well-Known Member
    Metairie,Louisiana
    2015 Pyrite Mica Double Cab
    Looks like a nice mirror,,but looks to be low(?) kinda in the drivers view..
  8. Aug 14, 2015 at 7:44 PM
    ElderP
    West Virginia
    I was in the same boat as everyone. This mirror is actually made by Donnelly. Quality is very good, installation directions are excellent. At $128 it is a very good buy.
  9. Aug 14, 2015 at 7:48 PM
    ElderP
    West Virginia
    It's the angle I took the picture. Otherwise I was getting the phone in the mirror. The mounting arm is adjustable so you can actually put the mirror up to the overhead console. I have mine set higher than the stock mirror.
  10. Aug 14, 2015 at 7:48 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    ClammyPeach likes this.
  11. Aug 14, 2015 at 7:49 PM
    Dogdad
    Metairie,Louisiana
    :thumbsup:
  12. Aug 14, 2015 at 7:50 PM
    ElderP
    West Virginia
  13. Aug 14, 2015 at 7:51 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :cool: Thanks for the info on this ... I think you've sold me. I appreciate it. :)
    SpaceTrim likes this.
  14. Aug 14, 2015 at 8:02 PM
    ElderP
    West Virginia
    You won't be disappointed.
    Installation tip for going through the firewall :
    I pushed a Phillips head screwdriver through the main boot, top left, from the engine compartment. Then from the cab side, I pushed a stiff plastic straw over the screwdriver (using it as a guide), lubricated with Windex, until it showed on the engine side. Remove the screwdriver and slip the temperature sensor wire through the straw. When through , pull the straw out from the cab side. The temperature sensor wires have pins on them that you have to be careful not to damage. They are inserted into the mirror plug.
    Noslow100 likes this.
  15. Aug 14, 2015 at 8:05 PM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Good tip ... I've routed wiring for lights already, so I know the route, but I'll use the straw to protect the pins. :cool:
  16. Aug 15, 2015 at 4:05 AM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    nice job
    on my list of things to do
    does that have homelink as well ?
  17. Aug 15, 2015 at 4:23 AM
    ElderP
    West Virginia
    No homelink. I don't wear sunglasses so I keep the opener in the overhead console.
  18. Aug 15, 2015 at 11:41 AM
    mjackson92rs
    mjackson92rs Well-Known Member
    SE PA
    '15 TRD Sport
    One of the first things I did to my '15. Worth every penny
  19. Aug 15, 2015 at 2:04 PM
    Yoda's TRD
    David
    Haslett, MI
  20. Aug 15, 2015 at 4:11 PM
    Dogdad
    Metairie,Louisiana
    Which mirror is that? Looks different than OP..
