Just installed new mirror
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ElderP, Aug 14, 2015.
  1. Aug 15, 2015 at 4:40 PM
    mjackson92rs
    mjackson92rs Well-Known Member
    SE PA
    '15 TRD Sport
    Different model, but same idea. Mine is a Gentex, forget what model.
  2. Aug 15, 2015 at 6:38 PM
    Clittrell
    Clittrell Member
    2015 Tacoma
    The limited comes with fancy mirror. No hidden wires in the headliner to tap into? I just bought a sr5 2015 and want to mod the mirror
    Kyitty likes this.
  3. Aug 15, 2015 at 8:21 PM
    mjackson92rs
    SE PA
    '15 TRD Sport
    Power wires are in the headliner right above the mirror. Only thing you have to run is a wire for the temp sensor
  4. Aug 16, 2015 at 4:09 AM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
  5. Aug 16, 2015 at 10:01 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    From my understanding if you have a 2015 the wiring may or may not be in place above the headliner.
  6. Aug 16, 2015 at 5:58 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    Can someone confirm this for all the 2015 guys following this thread
  7. Aug 16, 2015 at 6:42 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Threads like this make me wish I was more of a DIY adventurous type. I'd love to have an autodimming mirror with temp and compass in it. Let alone a Home link!!
  8. Aug 16, 2015 at 9:30 PM
    mjackson92rs
    SE PA
    '15 TRD Sport
    My 2015 had it. See TW member RJP869. He sells a mirror kit with the correct power plug so the mirror harness plugs into the factory Tacoma power plug above the headliner. All you do is run the temp sensor wire up front.
  9. Aug 16, 2015 at 9:39 PM
    shakerhood
    Southern Ohio
    My 2015 is supposed to be in this week and I wanted to preorder the mirror before the truck came but Bob the mirror guy told me that some 2015s have the wiring in place and some don't.
  10. Aug 17, 2015 at 6:17 AM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    thanks for the info.
  11. Aug 18, 2015 at 4:23 AM
    ElderP
    ElderP [OP] Well-Known Member
    West Virginia
    15 Access 4x4 V6 SR5
    Installed Cooper At/3's (265/70R16) and ProComp 7089 Rims. Tinted front windows. Did the Fog Light Anytime mod. Did the tailgate mod. Added running boards. Adding sound Deadening from RAAMaudio. Replacing stock speakers with Polk Audio DB6501's.
    Looks like a Gentex 50-GENK20A. I think I looked at that one but it's more expensive and I didn't want the display in the mirror itself. Either way, stick with CIPA/Donnley or Gentex and you will be happy.
  12. Aug 18, 2015 at 4:37 AM
    ElderP
    West Virginia
    It's not that difficult. One hour job for me, maybe two for you. Plenty of people here to help you through the process. Homelink adds $$$$ to the equation. I just keep a $19 push-button in the overhead. Had a car once with Homelink in the mirror, didn't like it.... every time you pushed the button, you had to readjust the mirror.
  13. Aug 18, 2015 at 5:05 AM
    Soul Surfer
    Soul Surfer Was Last Seen: Roam’n Around.
    Jimi
    West Central Florida Coast
    ‘23 TRD Sport.
    I like it! nice job.
  14. Aug 19, 2015 at 3:48 AM
    ElderP
    West Virginia
    Thanks
  15. Aug 31, 2015 at 6:05 AM
    #35
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    awesome! thanks OP
  16. Aug 31, 2015 at 6:16 AM
    #36
    cabo wabo
    cabo wabo Well-Known Member
    billy
    virginia
    2019 dbc short bed trd sport
    Installed one in my 2015 several months ago, money well spent.
  17. Sep 6, 2015 at 10:09 AM
    #37
    sqa4life
    sqa4life Well-Known Member
    2017 SR5 4x4 DCLB MGM
    I just bought one from Bob for my new 2015 tacoma (which did not have the mirror pre-wired at all), but couldn't make it to work. Spent hours over the phone with Homelink support without luck. They told me to send it back for replacement.
    But I noticed yesterday that when I press and hold any Homelink button, it activates AC. And the mirror only get the red light when I turned the ignition pass the accessories mode.
    Does anyone know or have pictures/diagram of how to wire this plug and play Gentex Homelink mirror?
  18. Sep 6, 2015 at 6:22 PM
    #38
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    ^ Those are Prius install instructions....
  19. Sep 6, 2015 at 6:28 PM
    #39
    sqa4life
    Could someone please tell me how you wired this thing to get power for the Gentex mirror in our 2015 tacoma, the right way?
  20. Sep 7, 2015 at 3:03 AM
    #40
    ElderP
    West Virginia
    Mine's not a Gentex but is should be wired in a similar fashion. I ran the power wire along side the temperature sensor wire along the headliner, down the left column into the instrument panel. Then used an "Add-A-Fuse" to tap power from the AC fuse located in the cab. I attached the ground to a bolt I found under the panel. My truck was not pre-wired at the overhead console. If you want, I can take some pictures later today.
    ClammyPeach likes this.
