Just installed the OPT-7 32" light bar! (Pic heavy)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tasnowma, Nov 29, 2016.
  1. Dec 23, 2016 at 4:13 AM
    Mike G
    Mike G Well-Known Member
    2020 SR5 Tacoma DCLB 4x4 Red
    Nice setup. Do you know if its possible to tap into the high beam switch so the light bar comes on with the high beams?
  2. Dec 23, 2016 at 5:33 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
  3. Jan 3, 2017 at 9:00 AM
    NC_Mtn_Taco
    NC_Mtn_Taco Member
    Jordan
    2017 White Tacoma DCOR
    Do you think a bolt and a nut would work? I'm guessing you would need to go all the way trough the aluminum but I'd imagine that would be the most secure.
    tasnowma[QUOTED][OP] likes this.
  4. Jan 3, 2017 at 10:09 AM
    Corneeeeelius
    Corneeeeelius AMERICA!
    Cory
    MIssion Viejo, CA
    2017 TRD Sport 4x4 DCLB W/Tech
    What a fun truck!
  5. Jan 3, 2017 at 1:37 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Hopefully you don't run those fogs in traffic seeing how they throw much more light up past the the headlight cut offs.
  6. Jan 3, 2017 at 6:06 PM
    NC_Mtn_Taco
    NC_Mtn_Taco Member
    Jordan
    I'm trying to figure out how the heck you got the light bar in there!! I took the two plastic pieces that need to be trimmed off and still can't get the bar to fit in there. Also how did you get a drill in there to drill them in? Can't seem to get straight above where I need to drill! Didn't realize this would be so difficult :/
  7. Jan 9, 2017 at 10:36 AM
    tasnowma
    tasnowma [OP] Well-Known Member
    David
    MA
    06’ DCSB SPORT. 16’ DCLB SPORT. 14’ DCLB SPORT
    Premium tech package with JBL, 2" Rough Country lift, 265/70/17 BFG Rugged Terrains, AVS in-channel rain guards, all weather floor mats, bed mat...
    I bought one of those coil bits that let's you predrill at different angles and such. Worked out pretty good. It was this - http://m.homedepot.com/p/Ryobi-11-in-Flexible-Shaft-Bit-Holder-A10FB1G/205193137
    I removed the plastic shield panels all together first, got the light bar mounted and then cut away what I needed with a jigsaw and reinstalled them.
    And yes I would imagine mounting a bolt all the way through the aluminum support would be much stronger but I believe there are wires and general important things running through there. That's why I didn't use a crazy long bolt.
    Thing is still holding up fine!!
  8. Jan 9, 2017 at 10:39 AM
    tasnowma
    David
    MA
    Of course I do. The LEDs aren't bright enough on their own. I run them full time and have been flashed 2 times in a year. I click them off as a courtesy when I pull up behind low vehicles in traffic and drive thru's and such.
