Just received TRD seat covers..have a question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Gorilla_97, Dec 25, 2009.
  1. Dec 25, 2009 at 7:35 AM
    Gorilla_97
    Gorilla_97 [OP] Once a gorilla always a gorilla
    Thomas
    Fort Worth, TX
    08 FJC Black Diamond
    I just received the Toyota TRD seat covers, however, I have an SR5 model.
    I know there is a difference between seats, but how much difference between the base SR5 and the TRD sport seats?
    I'd prefer the TRD seat cover because of the red "TRD" logo, however, I want the covers to fit nicely.
    Any suggestions? I can easily return and get the correct covers, just looking for some friendly input.
    Merry Christmas!!
  2. Dec 25, 2009 at 7:38 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I'm not an expert but I know the TRD seats have more side and lower support for sure. I'm not sure if the overall dimensions are similar or diffrent as well. Seing as they're diffrent fit, they probably won't work to well on base. However, you could go ahead and give it a shot :D Or get some Wet Okole's and put the Red TRD logo on those :D
  3. Dec 25, 2009 at 9:23 AM
    Gorilla_97
    Thomas
    Fort Worth, TX
    Thanks for the reply Kyouto42!
    Anybody else have a comment? I don't have side air bags so that shouldn't be an issue.
    Will the TRD covers just not fit tightly on the SR5 seats? I could always try it out I guess...but it's damn cold outside right now.
  4. Dec 25, 2009 at 9:29 AM
    Good351
    Good351 Well-Known Member
    Ames, IA
    03 4Runner V8
    U could try them and see if they fit to your liking.
    I had the TRD covers (got them free from toyota)...didn't like them at all! The back and bottom rubber felt like cheap plastic when cold..and boy were they cold! I sold them and bought a full set of wet okole's...great investment, never second guessed it after I got them.
  5. Dec 25, 2009 at 9:39 AM
    crittergitter
    crittergitter Proud to be Canadian Navy
    Stu
    Shearwater, NS
    '06 Tacoma 4WD Double Cab
    Bugger, skid plate, colour coded cap, bed mat, AFE Air Filter, Rear diff breather mod, Chirp on door lock;unlock, ABS mod, Weathertechs front and rear, 60" Hi-lift jack, LED light mod in rear bed, 12V accessory in bed, n more stuff.
    How cold is "Damn cold" in Texas? Just wondering.
  6. Dec 25, 2009 at 10:33 AM
    Gorilla_97
    Thomas
    Fort Worth, TX
    Well, I'm stuck in KS right now visiting family and it's about 20 deg F with 2ft snow drifts! The truck is at home in Texas, driving the wife's mini-van so the roads should be alot of fun getting home.
  7. Dec 25, 2009 at 11:12 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I have those seat covers. I really think you need the correct seat because the fit is extremely tight. If you try them, use a hammer handle or something like that to force the tube between the seat and back to get the tightest fit possible. On my covers one had a solid pvc tube, and the other tube was 2 piece. I ended up cutting the solid one in half to be able to wedge it into the crack between the seat and the back...made the installation alot easier.
  8. Dec 25, 2009 at 12:20 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    They will be baggy... thats what I heard
  9. Dec 25, 2009 at 9:41 PM
    Gorilla_97
    Thomas
    Fort Worth, TX
    I'll put them on and see how they turn out. If they're baggy I'll take them back to the dealership and get the SR5 ones. Thanks for all the replies.
  10. Dec 26, 2009 at 9:01 AM
    Good351
    Ames, IA
    03 4Runner V8
    To get the tube through the seat top/bottom...Fold the seat forward, this creates a gap and it'll slide through easier.
