Just Sea Foamed!
Discussion in 'Performance and Tuning' started by Bambigular, Feb 17, 2009.
  1. Feb 17, 2009 at 9:12 PM
    Bambigular
    Bambigular [OP] Well-Known Member
    Corona, Ca
    04 Double Cab SR5
    Just Sea Foamed the taco with 88K. It was pretty easy I just follows the instruction from another member post (don't remember who). I added whole bottle in gas tank, half in crank and just a little through the break boost. The reason I only added a little in the break boost was because my taco sounded like it was about to die. I put the Sea foam in a cup and suck it up through the break boost but as someone said, if you go too fast the motor will die out. So I just skimmed the top but the motor sound like it was going to die. I got scared so I stopped. However the little bit of Sea Foam produced tons of smoke it was like I was at Rave party, when my neighbors drove by the look on their faces was price less, they looked at me like I was crazy! Anyway I changed the oil and put new plugs in and this truck has never drove better, really smooth now. Don't think I'm going to use this again through the intake, but over all my truck is much more responsive.
  2. Feb 17, 2009 at 9:42 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    NIce job :thumbsup:
    Probably too early to tell but I would be curious if there is an increase in milage.
  3. Feb 17, 2009 at 9:49 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    gonna post it once I find out
  4. Feb 17, 2009 at 9:52 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    well for the brake booster your supposed to add 1/4 can, as fast as you can without it dieing, it is the main help because it get's injected straight into the engine.
    if you just go bit by bit it wont die right out. if you do it again, in 10k or whatever, try do do 1/4 in the brake booster
  5. Feb 18, 2009 at 3:56 PM
    Bambigular
    Corona, Ca
    04 Double Cab SR5
    After you do that are you suppose to turn off the engine or let it run? I read some post in which some members let it sit for a few minutes and then turn the motor over. I just let it run.
  6. Feb 18, 2009 at 4:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    after you do it.........cut the truck off for about 10 minutes, then crank her back up. and the way i seafoam my truck.....i usually run about half a can thru the brake booster line, then the rest in the tank,never in the oil.
    when you are adding to the brake booster line....go slowly.......if you go too fast, it will begin to choke down.....even if it does begin to choke down..........slide the line outta the can and let ithe motor catch back up, then do it again.
  7. Feb 18, 2009 at 4:03 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Is it ever to early to do this? I'm at 27,500 and thought about doing it at the 30,000 DIY service.
  8. Feb 18, 2009 at 4:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah man..................you can do the seafoaming whenever, but its better to do it when you are close to your oil change time. we can seafoam your ride at the meet if you want to.
  9. Feb 18, 2009 at 6:08 PM
    jolayiv
    Jim
    Hertford NC
    Thanks. That's what I thought just wanted to make sure. :woot:Sounds like a plan man. If we have time between all of the :drunk: and:mudding:
    I had to use some of the new smilies!
  10. Feb 18, 2009 at 7:03 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it'll take about 15 to 20 minutes......we can do that during camp set up time!:D
  11. Feb 18, 2009 at 9:25 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    yea might as well give it a shot! i did it twice first time left it for 5 mins, second time left it for 20. i did gas tank and pcv valve which does the same as brake booster.
    i then changed my fuel filter and oil.
