Just want to add a little lift & Need some pointers
Discussion in 'Suspension' started by testedone, Oct 15, 2009.
  1. Oct 15, 2009 at 10:57 PM
    testedone
    testedone [OP] Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Not looking for a full 3 inches...
    So tell me what things I would need to do if I go this route.
    Planned Lift
    • Bilstein 5100 Series both front and rear
    • Toytec AAL on the rear
    Do I need to drop the diff?
    Will I need UCA's??
    Will I need shims on the rear?
    Assume I will still need an alignment?
    Thanks, I want to keep it as simple as possible... It's 1:00 am and I think I read most suspension threads but want to be sure before I drop the cash..
    Thanks
  2. Oct 15, 2009 at 11:30 PM
    Kenny650
    Kenny650 Well-Known Member
    At what setting do you want your 5100's?
  3. Oct 15, 2009 at 11:36 PM
    testedone
    Rick
    U.S.A.
    I think I would put them at the 1.75 setting...just want a little more room for the tires I just put on, I figure the 5100 up front with the AAL in the rear should give me a decent look and a good ride.. I am told I don't need the Bilsteins in the rear but I figure I might as well do it...
  4. Oct 16, 2009 at 12:01 AM
    testedone
    Rick
    U.S.A.
    Also since I do not have the rear leaf spring TSB installed, if I went with the AAL that si designed for the TSB (1.5 inches of lift) this might give me the desired lift I want (2 inches or under)??
  5. Oct 16, 2009 at 12:50 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
  6. Oct 16, 2009 at 12:52 AM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    I think if you set them at 1.75" the tsb aal will be great. You will not need new uca's. And you should get an alignment afterwards.
  7. Oct 16, 2009 at 6:09 AM
    testedone
    Rick
    U.S.A.
    thanks, I think I will drop the hammer on the TSB Spring set and the 4 Bilsteins...
  8. Oct 16, 2009 at 6:34 AM
    testedone
    Rick
    U.S.A.
    Thanks, thats a nice setup he has
  9. Oct 16, 2009 at 7:02 AM
    testedone
    Rick
    U.S.A.
    Will I need to do the diff drop?
  10. Oct 16, 2009 at 9:52 AM
    testedone
    Rick
    U.S.A.
    ok, so here is what i am finally going to go with
    1. Bilstein 5100's up front set at 1.75
    2. Bilstein's on the rear
    3. Toytec AAL (2 inch)
    4. Shims for the rear axle (Darrick said it might be wise)
    5. Diff Drop kit in case I ever adjust up to 2.5 inches on the front..
    Anything I am missing??
  11. Oct 16, 2009 at 10:23 AM
    testedone
    Rick
    U.S.A.
    Is there any advantage to going with the Toytec 5100's with Coliovers? versus using my coils and the 5100's?
  12. Oct 16, 2009 at 11:02 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    If you're talking about the ultimate kit, they'll allow you to lift up to 3.5" (I'd keep it at 3). Plus, they're independently adjustable so you can correct the Tacoma Lean issue. However, at the 3" height, you'll probably want new Upper Control Arms (UCAs) and a diff drop kit.
    It does ride better with the Coilovers than with the Bilsteins and the stock coils (mine were set at 2.5 before I added the coilover).
  13. Oct 16, 2009 at 11:10 AM
    testedone
    Rick
    U.S.A.
    I only plan to run it (Ultimate kit) at 2 inches or so for now, not the 3 inches...
    I guess my biggest question I have after reading all the articles is everyone talks about lifting the front, but with a 2 inch AAL in the back why are you going 3 inches up front, is that so it is balanced (Level)?
  14. Oct 16, 2009 at 12:17 PM
    Evil Monkey
    Robert
    Escondido, CA
    Generally our trucks are higher in back than in the front. So lifting higher in front levels the truck.
  15. Oct 16, 2009 at 12:20 PM
    testedone
    Rick
    U.S.A.
    Ok cool...
    So if I go with the Toyec Ultimate kit I get the advanyage of a completly adjustable front coil over, for a hefty increase in price, if I only plan to do the 2 inches then I might be better off (financially) with just going with the stock springs and the 5100's up front??
  16. Oct 16, 2009 at 12:58 PM
    NumbNutts
    NumbNutts Well-Known Member
    Josh
    New Mexico
    08 Tacoma DC 4X4 Silver Streak
    5100's all 4 corners, Front ToyTec adjustable Coils set at 2", Rear TSB, FJ gun metal wheels, BFG A/T 265/75-16D, custom Sock SR5 decals, Weather Tech floor mats, AFE Pro Dry S, Wet Okole seat covers black and charcaol, Color matched grill
    I was kind of in the same boat as you when I was looking at lifting my Taco 2 inches. I had the TSB done and the rear sat about 2.85 inches higher in the rear so I thought about lifting the front to level things out but felt the 2.5 setting on the 5100"s would be to high once TSB settled and I didn't really want to compress stock spring on the billy"s and get a harsh ride. Some say it's not harsh at all but I didn't have the time or money to be experimenting with different set ups. So I had already purchased the 5100"s from DownSouth with intentions of setting them at 1.75 inch but I felt 2 inches would have leveled perfect so I chose to buy the adjustable coil kit from ToyTec to go with my 5100"s so I could level it out to my liking and adjust for the Taco lean and no need for new UCA's. I only wanted to go 2 inch lift cause I am only running 265/75-16 tires an really don't need anything bigger. The ride is really nice with the 5100's and ToyTec coils. Spent a little bit more now and you will save more in the end.
  17. Oct 16, 2009 at 1:04 PM
    testedone
    Rick
    U.S.A.
    Come on man only 17 posts and you gave me the answer I was looking for :) Thanks!!
    My plans sound the same as yours, I am running 265/70/17 tires and want a little more lift 2 inches is fine..
    So yeah the adjustablity of the Toytec coil overs will do it..
    Did you change out your rear shocks?
    I don't have the TSB and plan to install the AAL with the 5100 Coil overs but not sure about changing out the rear shocks, i do virtually no off roading here in IL
  18. Oct 16, 2009 at 1:20 PM
    NumbNutts
    Josh
    New Mexico
    Yeah I changed out the rears just because the shocks when bought with the front 5100"s are maybe $90 more from DownSouth. They ride a little better than the stock TRD shocks. Like I said in the last post "Spend a little bit more now and you will save more in the end". Don't have any regrets man you'll kick yourself later for it.
  19. Oct 16, 2009 at 3:14 PM
    Black Rock Taco
    Black Rock Taco Well-Known Member
    Winnemucca and Reno, NV, Oakland CA
    2011 DBL Cab Tundra
    None, yet
    I recently got Toytec adjustable coilover kit and 2" AAL for non-TSB springs, and 5100's all around. My truck is a new DC LB, had less than 4000 miles when I did the install. I don't know if the new truck springs had an effect, but the 2" AAL's lifted the rear 3". also, the front red coils settled prob 3/4" to 1" over the first 1000 miles or less. I re-adjusted them twice in the first 2 weeks, they're now appearing stable at just a hair under 2 1/2 ". The rear has not settled at all, but I haven't carried much weight yet. the ride is very much improved over stock. Much firmer, but not uncomfortable. No more mushy car ride.
    I have not seen mention of either the front settling nor the rear 3" height before. Maybe most are putting the AAL's on saggy older springs? I was surprised at the degree of sag in the front. I suggest driving a good 1000 miles before finalizing the front and getting an alignment. No sense spending money to align just to crank the CO's again.
  20. Oct 16, 2009 at 3:16 PM
    testedone
    Rick
    U.S.A.
    Good point and thanks for the info, your the exact setup as what I am going to except for the long bed..
    Got any pics?
    Thanks
