K and N filter install question
Discussion in '1st Gen. Tacomas (1995-2004)' started by jjsask, Apr 23, 2011.
  1. Apr 23, 2011 at 11:14 PM
    jjsask
    jjsask [OP] Well-Known Member
    Regina, Saskatchewan, Canada
    2002 XtraCab 4x4 TRD
    My 02 v6 came with a K and N when I bought it but I can't figure out which way to install the filter in the airbox. There is a frame thing that you set the filter into and drop the assembly into the airbox. It will fit both with the filter side facing the incoming dirty air or with the frame side facing the dirty air. Anyone who has one will know exactly what I mean but the instructions say nothing about it. Can anyone confirm which way these filters are to be installed?
  2. Apr 23, 2011 at 11:27 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    San Francisco
    2001 prerunner doublecab limited
    2001 with; cat-back twin exhaust,elbow mod, Westin bullbar with Hella550's, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    If you look at that frame, it has two tabs protruding out-the filter has two "female" indentations on its own frame. You meet the tabs with the female slots and the frame side goes towards the front.
    On a side note-I have a K+N filter too-I don't use it because IMO it does nothing. I get better throttle with a stock filter as well as better filtration. K+Ns only make a difference IMO on high horsepower engines. Just food for thought:)
