K&N 63 Series AirCharger High-Flow Intake Kit?
Discussion in 'Performance and Tuning' started by Troyton, Mar 2, 2013.
  1. Mar 2, 2013 at 5:56 AM
    Troyton
    Troyton [OP] Well-Known Member
    Troy
    South Florida (Naples)
    06 DoubleCab PreRunner "Wanna be XSP"
    -Trd shocks -Clifford Alarm System -Kenwood Radio -Led bars -Green Fog Lights -2010 Head lights and Tail lights -2010 Tail gate with Back up Camera -White Dash Mod -2011 grill -Led Pods -Kicker Subs -PA System - Underglow
    I have a 2006 Toyota Tacoma PreRunner V6 TRD O.R. package.
    Do you suggest the K&N 63 Series AirCharger High-Flow Intake Kit? What are all of my benefits and downfalls of installing this? Need suggestions...
  2. Mar 2, 2013 at 6:09 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I can sell you mine. I am going to be installing a snorkel, and it's not compatible with FIPK.
  3. Mar 2, 2013 at 6:19 AM
    Troyton
    Troy
    Did you have any problems with the oil or sensors or anything?
  4. Mar 2, 2013 at 6:24 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    No problems at all. I've had this installed on my truck since I bought it new 3/14/2010, I put 80k miles on it, found a small, insignificant defect in the mesh of the filter when I was cleaning. So KN sent a new filter. So 85k on the assembly, 5k on the newer filter. I cleaned the MAF when I would clean the filter, clean the TB every 30k, and no problems to report.
  5. Mar 2, 2013 at 1:58 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Its gunna draw hotter air than stock I assume, k&n filter bad....high flow but bad filtering (u can't have both sadly).
    Be very very careful wit oiling.....I've had 3 or 4 maf issues on past vehicles.......clean ur maf sensor regularly if u go this route.
  6. Mar 3, 2013 at 4:00 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Only draws warmer air when sitting at idle. Once the vehicle is moving, the IAT drops to ambient. Over oiling will foul sensors and and put extra gunk on the TB.
  7. Mar 3, 2013 at 7:55 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    That's impressive....where does the cool air come in?
    Through the grill, past the condensor, radiator, trans cooler?
    What di u measure with?
    I've had mine very lightly oiled on a maxima and celica....both fouled the maf.....comically I seen a friend buy a used corolla and drove it for a year with no issues, then she had to have the maf cleaned....the car was only 4yrs ol at most.....the prior owner put an exhaust on it, rims, and the usual rice stickers...I always assumed he ran a K&N....funny how it got gummed up even though she only used factory filters (which filter much better and I bet allow enough flow to feed the lil 4 cylinder).
  8. Mar 3, 2013 at 8:18 AM
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    I would imagine the cooler than engine bay air, comes in through the same hole as the stock intake draws air from, and any where else. I measured using the IAT sensor through my OBD2 hook up. The temp drop was about 15*f from idle to moving. Ambient at the time was 45*f. Though, I have not checked the temp on a stock intake, I surely will once I remove the FIPK and re install my stock, then again when I install the snorkel. When I first read all of the debated Hot air intake vs stock, I had to find out for my self, so I did. Though there may be other factors involved, I will see if I can cover them all when I do my little road test. But I agree that an oiled filter will cause build up, and I took that in to account, and cleaned the sensitive parts that would be affected.
  9. Mar 3, 2013 at 9:13 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Gotcha.... let us know what u find.
