K&N Cold Air?
Discussion in '4 Cylinder' started by StormTrooper, Feb 1, 2012.
  1. Feb 1, 2012 at 3:23 PM
    StormTrooper
    StormTrooper [OP] Well-Known Member
    Ron
    Maryland
    08 Base Flowmaster Super 44 w/ K&N drop in
    Bed Cap,K&N Air Filter,Chrome Pieces,Flowmaster Exhaust,Neon on inside, Heavy Duty Custom Floormats ( Tacoma ), Tint 20%, Blue license plate lights, Various decals, LED Projector Halos headlights, JVC head unit stereo
  2. Feb 1, 2012 at 3:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You wont get a gain. More noise, but thats about it.
  3. Feb 1, 2012 at 3:27 PM
    StormTrooper
    Ron
    Maryland
    Thats fine.. just better flow. Like i said, im not expecting much. But more my question is is this an exact fit with the sensor and everything
  4. Feb 1, 2012 at 3:29 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    you wont get better flow. you will get absolutely nothing. maybe "looking pretty" if that is what you are after.
  5. Feb 1, 2012 at 3:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks like it. You wont get better flow either. The OEM intake is pretty good. Unless you are going to do more mods, to work in conjunction with the intake, your better off saving your money.
  6. Feb 1, 2012 at 3:30 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  7. Feb 1, 2012 at 3:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Ron......skip the k & n intake. wont do anything for ya. get a good dry flow filter like the afe pro dry s and you'll be good to go.
  8. Feb 1, 2012 at 3:32 PM
    StormTrooper
    Ron
    Maryland
    Okay thanks guys
  9. Feb 1, 2012 at 3:34 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Found Gadgets full write up:
  10. Feb 1, 2012 at 3:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you bother to read the OP has the 2.7??
  11. Feb 1, 2012 at 3:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    It has no affect on the throttle response. THe throttle will still open the same speed, regardless of the intake you have. If an engine has poor throttle response, thats most always a fueling issue, rather than an air intake issue.
  12. Feb 1, 2012 at 3:47 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    :anonymous: Nope, missed that..
  13. Feb 1, 2012 at 3:50 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Also, as far as the faster throttle response thing, it's not that your throttle body "responds faster" but the added power always your engine to rev up faster. Commonly called faster throttle response.
  14. Feb 1, 2012 at 3:51 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I also have the URD TCAI you know :rolleyes:
  15. Feb 1, 2012 at 3:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Alot of people think that, as they can now hear the intake, vs. not being able to hear it as much when stock. Ive had 2 1GR's side by side. 1 stock, and one with headers, exhaust, intake. They both reved the same. The way (speed) and engine revs is mostly determind by the reciprocating mass inside the engine. A lighter flywheel can increase the speed at which the engine responds to throttle inputs, but other wise, aside from major tuning, and corisponding mods, any difference isnt going to be perceptible without the use of some computer monitoring device.
  16. Feb 1, 2012 at 3:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The URD design is a good design. Personally, I think its how a "COld air" intake should be for our trucks.
  17. Feb 1, 2012 at 3:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :rofl: Its the URD COld air AIR CONDITIONER intake!!! :p
  18. Feb 1, 2012 at 3:53 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    I could definitely do without the wind buffeting effect though...
  19. Feb 1, 2012 at 3:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sure cutting the air flow will choke an engine. However, the new intake isnt forcing air into the engine. The pistons still have to suck it thru the same valves. The intake simply doesnt creat the amount of parasitic drag required to make it rev that much different. I can only asume the placebo affect is what makes people think throttle response is increased.
  20. Feb 1, 2012 at 3:59 PM
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Agreed
    Yea I have one now, and its not an issue for anyone who doesn't drive over highway speeds..
