K & N Installed
Discussion in 'Performance and Tuning' started by caglezxj, Aug 18, 2007.
  1. Aug 18, 2007 at 10:42 AM
    caglezxj
    caglezxj [OP] Well-Known Member
    This was an easy upgrade. Found that everything fit very nicely and did not have to use the instructions much. I will not be able to give any real feedback on it till I take a road trip. But after the 35" tires I am getting around 15 miles a gallon. I will be flashing my ECU withen the next couple of weeks. I will take some pictures of the K&N install later.
  2. Aug 18, 2007 at 10:58 AM
    reid
    reid Well-Known Member
    Vancouver BC Canada
    2007 V6 Access Cab
    Magna Flow stainless cat-back, 3" Toytec Lift, 32" Mickey Thompsons
    I have heard others talk about flashing their ECU. What does this mean? Is it just re-setting it, if so how do you do it?
  3. Aug 26, 2007 at 8:02 PM
    caglezxj
    You have to have it flashed if you want the factory settings removed or changed. Most dealers around here can't do it. I work for Toyota and can have it done by a trained employee. All I want changed is the air/fuel mixture.
  4. Aug 26, 2007 at 10:20 PM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    If you go to larger tires, can you get your computer changed to make up the difference on the odometer and the trip meter.
  5. Aug 30, 2007 at 9:25 PM
    tacomaclay
    tacomaclay Well-Known Member
    SR5 4x4 04
    Flowmaster exhaust, K&N 77 series intake, kobalt aluminum toolbox
    I Got a k&n 77 seriers what kind did you get.
  6. Aug 31, 2007 at 8:13 AM
    caglezxj
    I believe it is the same thing, it is the black plastic tube, not the staineless steel.
  7. Aug 31, 2007 at 8:14 AM
    caglezxj
    yeah I know they can changne that, but when it gets to performance settings they can't.
  8. Aug 31, 2007 at 10:59 AM
    reid
    Vancouver BC Canada
    2007 V6 Access Cab
    caglezxj:
    By performance do you mean air/fuel ratio. I am only concerned with the speedo and odometer. I will eventually get the URD MAF for the performance.
