K+N Intake HELP!!?!?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gaert09, Aug 5, 2008.
  1. Aug 5, 2008 at 2:26 PM
    gaert09
    gaert09 [OP] Member
    Hurlburt Field Air Force Base
    07 Tacoma
    Window Tints, Eyebrow Tint, Bug Deflector, Rain Deflector on windows, K+N Air Filter, under cover over bed,
    I need serious help.
    My 2007 4 Banger has ran terrific until 2 weekends ago...I installed the K+N Air Intake just to boost my HP alittle bit and maybe see a difference in gas mileage. When Im at Red Lights, Stop Signs or just idle in Drive....my trucks RPMs go soooo low to where the truck putters and sounds like its going to stall out...sometimes actually stalling out. Its pissing me off!!! I brought it to a mechanic and he told me everything was installed correctly...he didnt know what the problem was....Pleaseee somebody out there help a brotha out!!
    Thanks in advance
  2. Aug 5, 2008 at 2:29 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    I know whan I stop my Rpms drop down to below 1000 but I never had the feeling of stalling, I have the Full cold air k@N intake
  3. Aug 5, 2008 at 2:29 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Did you reset the Brain??
    unplug you neg batter terminal for about 30 mins then reinstall and drive normal... see if that will fix it...
    It should do it over time but this might speed the process up.
    worth a shot.:confused:
  4. Aug 5, 2008 at 2:37 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    weird... never had a problem with mine, 2 years old and still runs like new
  5. Aug 5, 2008 at 2:39 PM
    gaert09
    gaert09 [OP] Member
    07 Tacoma
    I just disconnected the terminal...im gonna leave it for awhile...well see if that works...if it does, im in debt to you!!
  6. Aug 5, 2008 at 2:40 PM
    tacoskim
    Los Angeles, CA
    Stock
    it takes a bit for the ECU to adjust to ur new system... give it a little time and u should be all good
  7. Aug 5, 2008 at 2:47 PM
    gaert09
    gaert09 [OP] Member
    07 Tacoma
    Thanks...I hope this works...It stalled out the other day and I was very angry...I called K+N and of course, they never heard of this issue...
  8. Aug 5, 2008 at 4:20 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    When I put the K&N on my Corolla the filter came over-oiled. Got on the MAF sensor, idled like poo. A couple careful shots of MAF cleaner fixed it right up. Did have to reset the ECU after cleaning.
  9. Aug 5, 2008 at 4:24 PM
    tacoskim
    Los Angeles, CA
    Stock
    ive never heard of the filter coming over oiled before from the factory... im sure u could of had a lawsuit if u wanted too
  10. Aug 5, 2008 at 4:27 PM
    HerNameIsLucy
    RIP Lucy.
    Well, I'm assuming it was over-oiled. Maybe it had just pooled inside the filter from sitting on the shelf at the store for a while and the pool got sucked up when I first started it. In any case, cleaning the MAF fixed it.
  11. Aug 5, 2008 at 4:40 PM
    tex
    tex Well-Known Member
    Arlington, TX
    2015 4 Runner Trail
    x2 on cleaning the MAF.
    I had a cold air kit on my old mustang and 1 of the vacum lines slid off the piece on the intake tube and it caused it to run like crap.
    If the problem continues install your factory parts and see if it runs like its supposed to.
  12. Aug 5, 2008 at 5:20 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Definitely try cleaning the MAF. This is, unfortunately, part of owning an oiled filter. I ran them for many years and I've run into this situation many times. IMO, oiled filters are dinosaurs being used on new tech.
  13. Aug 6, 2008 at 7:09 AM
    gaert09
    gaert09 [OP] Member
    07 Tacoma
    Ok....
    well i tried the battery idea...left the neg off for about an hour...didnt do anything...
    i tightened all the clamps on the filter...
    the maf sensor isnt really dirty, i checked it out last night...
    any other suggestions??
    again, i appreciate all of your inputs...I dont know what to do!!
  14. Aug 6, 2008 at 8:35 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    What octane gas are you using? I had the inline 4 in my 95 Tacoma. If I ran regular gas in it and had the A/C on it would almost stall at stop lights. I started using plus gas and everything was fine. Try running higher octane gas and see if this helps.
  15. Aug 6, 2008 at 9:56 AM
    gaert09
    gaert09 [OP] Member
    07 Tacoma
    ok, ill try the higher octane...will that negativly affect my truck if i go from lower to higher, back to lower?
  16. Aug 6, 2008 at 10:00 AM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    Run some MAF cleaner through it. A little oil on the MAF may not be visible but will impact performance.
    Just installing a CAI should not cause these problems.
  17. Aug 6, 2008 at 10:25 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    clean the maf sensor with maf sensor cleaner or an electronics cleaner.....it will fix the problem.
  18. Aug 6, 2008 at 11:05 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Clean the MAF and replace the K&N filter with an AEM if you want to keep the CAI. I know a few people have done a K&N/AEM hybrid intake to get the CAI from K&N and an oil-free filter from AEM. So you get a CAI and don't get the MAF problems from an oiled filter.
    Or just do an AFE Pro Dry drop-in like many of us. :D
  19. Aug 7, 2008 at 9:20 AM
    gaert09
    gaert09 [OP] Member
    07 Tacoma
    Thank you all for answering my questions!!
    Yesterday after work i went and purchased the MAF cleaner, cleaned it and the truck still rough idled...so i took off the CAI and replaced the stock filter...truck is back to normal!!
