K&n Oil Filter
Discussion in 'Performance and Tuning' started by tacomaclay, Aug 30, 2007.
  1. Aug 30, 2007 at 2:32 PM
    tacomaclay
    tacomaclay [OP] Well-Known Member
    SR5 4x4 04
    Flowmaster exhaust, K&N 77 series intake, kobalt aluminum toolbox
    Are K&N oil filters worth the extra dough?
  2. Aug 30, 2007 at 2:41 PM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    yes:D
    but you should switch to synthetic too.
  3. Aug 30, 2007 at 9:27 PM
    tacomaclay
    SR5 4x4 04
    Why Do You Say That?
  4. Aug 31, 2007 at 9:32 AM
    SLOTaco
    06 TRD Sport
    Synthetics generally have better flow properties than conventional, but this doesn't do much good if your oil filter restricts the flow rate. K&N filters have a much higher flow rate, and filter to smaller micron measurement than most filters. Also, they have an anti drain back valve that keeps oil in the filter so when you start your truck it will lubricate and circulate oil faster.
    All of that = good
  5. Aug 31, 2007 at 9:41 AM
    kngharley
    kngharley Well-Known Member
    Corona, Ca
    I have a K&N on my 07 4.0. I also switched to Mobile 1. The filter is a little pricey as is the oil. But as the old saying goes "You get what you pay for". If you plan on keeping the truck I recommend the combo but if you lease or trade in quickly then I think it's a waste of your money.
  6. Aug 31, 2007 at 9:42 AM
    SLOTaco
    06 TRD Sport
    Well said, the trucks will last a long time anyway, so if you don't keep it forever then synthetic and k&n are a waste, but if you want it to last you a couple decades then the switch is a good idea.
