K&N or TRD air filters. Worth it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jaymay82, Jan 20, 2013.
  1. Jan 21, 2013 at 8:21 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    They actually changed up their wording over the years. I know when I bought my last one 4 years ago it was stated differently. Sadly I no longer have the paperwork from back then. Here is the current claim:
    "The dirt particles collected on the surface of a K&N element have little effect on air flow during much of its service life because there are no small holes to clog. Particles are stopped by layers of crisscrossed cotton fibers and held in suspension by the oil. As the filter begins to collect debris, an additional form of filter action begins to take place because air must first pass through the dirt particles trapped on the surface. That means a K&N air filter continues to exhibit high air flow throughout the life of the filter while it is accumulating dirt. So as dirt accumulates, the performance advantages of a K&N air filter can increase!"
    Reference: http://www.knfilters.com/filter_facts.htm
    Exactly....K&N claims their filters have tested no lower then 96% so it means 4% of the crud makes it past (worst case). No more for me, but I have a used one if anyone wants to buy it.
    Wix OE type paper filter #46888 Case of 6 shipped for $83.13 or $13.86 per unit.
    Your price does not include the filter cleaner and oil so tack on another $25.00 to your costs.
    Also I can swap my filter out in 5 minutes on the trail if it gets damaged or full of moisture or full of dust. You must wait hours for yours to dry after cleaning before you can even oil it and that can not be done on the trail unless you carry a kitchen sink with you :D
  2. Jan 21, 2013 at 8:26 AM
    Gabe911
    Gabe911 Well-Known Member
    FLORIDA
    10 PreRunner MGM
    Debadged, Rear TSB, Blue LED dome and Bright White Map Lights, Hard Top Tonneau Cover, OME885 coils (no top plate spacers)OME shocks and struts, 1.5" AAL for TSB Rear,285/70/17 Trail Grapplers, 17x9 XD Addicts with 4.5 bs, Black 4" exhaust tip, Bed pocket lights, rear diff breather Mod
    PUROLATOR
  3. Jan 21, 2013 at 8:50 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Anyone with a K&N can carry a spare filter - just as you do. So - they can change it out in 5 minutes also. I kept my OEM filter as a spare.
  4. Jan 21, 2013 at 8:57 AM
    XXXX
    sKiP
    05 Prius
    Yea, but you have to buy 2 K&N's to swap them out for the same filter.
    How are you swapping in a used old filter? Isn't it used and old? Then you wait for the K&N to dry and re-install that? So you have to actually do 2 swaps for each cleaning? I know I used to hate waiting for the dam filter to dry so I could drive. :D
    I get what your saying.
    Just breaking stones as usual. :)
  5. Jan 21, 2013 at 9:24 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    I'm torn . . . I hear/read the negative comments on K&N filters - especially in the motorcycle world. I personally would not run one on my Suzuki DR-650 because I gave it the opened-up "air box mod" and the bike sees its fair share of off road. However, I currently have a TRD gen 1 CAI on my 4.0L V6 Tacoma and that filter is pretty much the same as a conical K&N. I cleaned my throttle body, MAF sensor, and CAI intake tube about 6 months ago and they were all very clean upstream of the throttle body butterfly before I even touched them with cleaners (downstream - on the backside of the butterfly and inside the intake cover -was a slightly different story . . . an oil catch can is now on the mod list). I've been thinking about taking the TRD CAI off and going back to the stock intake/filter simply to see if I can get better MPG - not for the sake of supposed better filtration over the conical cotton media TRD filter (since my own experience with the TRD filter, and a Volant CAI/filter prior to that, has been fine thus far in approx. 6 years / 45,000 miles). However, how can I ignore the abundance of negative feedback and user-beware warnings associated with the permanent filters?
  6. Jan 21, 2013 at 9:55 AM
    miniceptor86
    miniceptor86 Well-Known Member
    Jim
    McGregor,IA
    07 Speedway Blue Prerunner Dbl cab
    TRD sport exhaust and cold air intake, nerf and bull bar, RideRide, ProEFX towing mirrors, BakFlip F1 trifold tonneau
    Sorry, different uses, I'm not on the trail, no need to swap out for me. The $25 for cleaner/oil has lasted me 10+ years so hardly a factor.
    This debate can go on and on I happen to have had good results using a gauze type filter and will go on using them. Like I said, sorry your results have not been the same. I'm sure that if I were off roading and needing to change my filters more often than I do the convenience of a paper filter would be appreciated.
    I personally don't mind cleaning or having the vehicle laid up while it is drying for a couple of hours. Plenty of primping to do on BluTaco during that time. Naps are good also.
    Jim
  7. Jan 21, 2013 at 10:44 AM
    Janster
    Jandy
    Lancaster, PA
    Who said you had to buy a second K&N? Buy a bobo cheapo air filter as a spare and clean the K&N when you get home from the trails.
    My stock filter came out within the first year. I still have it and use it when I clean the AFE. It's still pretty clean
  8. Jan 21, 2013 at 1:39 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    That's funny because it is 180 degrees opposite what K&N claims IN WRITING. It is also counter to physics.
    They recommend cleaning the filters no more often than every 20,000 miles because the dirt piling onto the filter media improves filtration.
    Think about it. A clogged filter becomes more restrictive. If a clogged filter is going to pass dirt through, then it would pass that same dirt through when it is perfectly clean.
    A 50 micron mesh is going to pass a 49 micron particle and block a 51 micron particle.
    Stack a bunch of 51-100 micron particles on top of a 50 micron mesh and it's not going to suddenly start passing 51 micron particles, it just becomes more restrictive. Clogged air filters don't go into bypass like clogged oil filters, they just choke the engine.
    It is well documented all over the net (and not ONLY by Amsoil dealer hype, also look up "Spicer" who did an independent review on his own flowbench) that OEM filters are the most effective. They are among the more restrictive, but that's how filters work. Less restriction can be accomplished in only two ways: Increase filter area, or decrease filtration efficiency. K&N, AFE, and other aftermarket drop-in filters do not increase filter area, so the only way they can work is by not filtering as well.
    Restriction? How much improvement do you need? The stock intake can flow more than any normally aspirated 4.0 can draw. We simply don't NEED to reduce intake restriction, and dyno reports consistently show no significant improvement.
    TheCAPA1 likes this.
  9. Jan 21, 2013 at 1:48 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Exactly why I had a pair of filters for my motorcycle, both my Vulcan and dirtbike (dirtbike ran oiled foam).
    When it was time to clean, I'd just pull a clean one out of a zip-lock that it was stored in and move the dirty one into the cleaning rotation.
  10. Jan 21, 2013 at 4:00 PM
    Janster
    Jandy
    Lancaster, PA
    So, how many K&N's have you actually used and have experience with?
    If they are so horrible (according to your arguments), then why are they still in business?
  11. Jan 21, 2013 at 4:22 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I have them on my motorcycle... stuck with them because of the aftermarket intake design. I ran a drop-in on my '94 Toyota pickup. Traded it at 225k, it burned a quart or more every 3000.
    And if you'd read the fucking thread, you would see that I've already stated my personal experience with them.
    There are a lot of shitty products that sell quite well for any number of reasons.
    K&N and other cleanable filters have their legitimate use.... in racing applications where performance is a priority over durability.
    If your engine only has to last 500 or 1000 miles between rebuilds, the only reason you run an air filter at all is to keep out debris that is large enough to cause immediate damage.
    You don't see air filters on dragsters.
    But people are sheep and will buy whatever the marketing machine can persuade influential groups is "cool". Those stickers on race vehicles? Those drivers/teams are not using those products. They are simply being paid to put that label on their car or truck. Richard Petty did not use STP fuel or oil treatment, but Richard Petty sold a LOT of what is literally nothing more than a heavy weight oil.
  12. Jan 21, 2013 at 6:14 PM
    Janster
    Jandy
    Lancaster, PA
    Really? The F bomb? Was that really necessary?
    I read the thread and your ramblings. I've owned 4-5 K&N's over the years. I just wanted to see exactly how much experience you had with them. Obviously, you don't hate them that much since you still run them in your motorcycle?
    Does that make you one of the sheep?
  13. Jan 21, 2013 at 8:56 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    I use them on the Vulcan because I'm stuck with them due to the design of the intake.
    I use them understanding the damage to the engine that I am doing and accepting that. It's a V-Twin, it burns oil anyways.
    I do not use them on my dirtbike or my Tacoma.
  14. Jan 21, 2013 at 9:42 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Oh Gosh the F bomb!!!!!!!!
  15. Oct 3, 2017 at 9:15 PM
    #35
    PFD FIRE
    PFD FIRE Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I have a TRD CAI even though I haven't really noticed any real issues with the oil filter. Now that I do a lot more off roading I'm considering switching back to the stock air intake and filter. In addition I'm also looking into a Snorkel to help minimize dust accumulation to the filter. I have to admit I feel into the whole hype of having a CAI but then again I invested in the TRD way before I got into off roading.....wish I never sold my stock air intake:-(
  16. Oct 4, 2017 at 6:39 AM
    #36
    blu92in99
    blu92in99 Hates everyone, equally
    Elk Grove, Ca
    If you have the later version of the TRD CAI (the one with the big square panel filter), that airbox will take a 2010-2014 4.0L FJ stock paper filter. No need to sell the CAI.
    https://www.tacomaworld.com/threads/trd-cai-afe-filter-replacement.508219/
  17. Oct 4, 2017 at 7:07 AM
    #37
    PFD FIRE
    David
    San Diego
    My 2011 Tacoma has one of these type of filter on my TRD CAI. Unless they make a paper version of this rectangular filter that will save me a lot of time and money from replacing the TRD CAI.
  18. Oct 4, 2017 at 7:16 AM
    #38
    blu92in99
    Elk Grove, Ca
    Yup, '10-14 FJ paper filter. Read the link I posted above...
    PFD FIRE[QUOTED] likes this.
  19. Oct 4, 2017 at 7:32 AM
    #39
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Ditching that intake will be beneficial, they cause lean conditions. Trd/k&n/aem screwed up that build.
  20. Oct 4, 2017 at 7:42 AM
    #40
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
