K & N
Discussion in 'Performance and Tuning' started by cockyockyfree, Nov 2, 2006.
  1. Nov 2, 2006 at 2:39 AM
    cockyockyfree
    cockyockyfree [OP] Member
    Well, I did it. The mod went fine, took my time, took it out on a test about 3 hours later. The bottom end picked up quite a bit. And the sound, I don't exactly know what happened, but it sounds like a race car when you get on it. I mean the exhaust is different, and of course you can hear air now, but man am I glad I did this. I tooled over to TC to read all the doom and gloom, but I still put it on. I took some pics.
  2. Nov 21, 2006 at 10:56 PM
    MapMasterG
    MapMasterG Active Member
    Did you do the install yourself? Any hints? Will adding a cold air intake like that void the warrenty? i'b be interested to hear what it does to your mpg.
    Thanks
  3. Nov 22, 2006 at 1:19 AM
    cockyockyfree
    This is a truck with under 7,00 miles. It isn't even broke in. The directions were easy to follow. I get my oil changed in the morning, and I am going to ask the dealership about the warrenty. K&N says it does not, we shall see. The performance and sound changed radically, at least it feels like it did!
  4. Nov 22, 2006 at 12:21 PM
    flatboy
    flatboy Member
    Edmonton, Alberta, Canada
    FASTACO
    Turbo, meth, Nitrous, w/a intercooler.
    I never got any better milage with any mods I did, infact it always got worse. If it sounds better I tend to stuff my foot in it a tad bit more:)
  5. Nov 22, 2006 at 6:17 PM
    ChrisLaTraille
    ChrisLaTraille New Member
    Hey Greg O. Did the Magnaflow exhaust make any difference in performance? I just bought an `06 Prerunner and am thinking of an identical setup as yours, except I may add headers as well.
  6. Nov 23, 2006 at 4:51 PM
    cockyockyfree
    I never have had it on a dyno. If you read the forum here, as well as other sites, you will find that headers (usually) require dyno work. The computer gets confussed. And as FLATBOY states, your foot will be in it for the sound. I like the sound, but it is not an 8 cylinder sound, in which it can't, it is a six. But it does sound good when you stick it to it, and it does go.
  7. Jan 21, 2007 at 11:43 AM
    Andrew83
    Andrew83 Active Member
    Andrew
    Orange County, CA
    07 PreRunner DCSB
    I have gotten a k&n intake system, the tube is plastic which I hear is better because then you dont hear the air, I am going to install it soon.
  8. Jan 28, 2007 at 10:19 AM
    Andrew83
    Andrew
    Orange County, CA
    07 PreRunner DCSB
    Does it give better MPG?
  9. Feb 5, 2007 at 6:30 PM
    yotaman502
    yotaman502 Well-Known Member
    New bern, NC
  10. Feb 5, 2007 at 7:04 PM
    Ldytaco05
    Ldytaco05 it's all about me
    Orlando, Fl.
    2005 PreRunner,Enkei Wheels
    Does the noise from your k&n interfere with your media sound?
  11. Feb 6, 2007 at 1:54 AM
    cockyockyfree
    No the noise isn't that loud. On the exhaust I just had the local exhaust shop cut out the stock muffler and put in a magnaflow. It DOES NOT sound like a V-8, but does make the V-6 it has in it sound much better. I have a stock stereo system and just turn it up when I am getting on it if i don't want to here it, but that sound, there is just something terribly addicting to it at about 3500 RPM in third gear and mashing the gas.
  12. Feb 22, 2007 at 1:20 PM
    TRDeity
    TRDeity Well-Known Member
    ATX
    2017 TRDpro
    Will you let us know if you do put headers on, that is something I have thought about doing to my Taco. I have long tubes on my mustang but now it will not pass inspection due to the check engine light is on, wasn't sure if the that would happen with the shorties for the Tacoma.
  13. Mar 26, 2007 at 12:58 PM
    Andrew83
    Andrew
    Orange County, CA
    07 PreRunner DCSB
    Just installed my K&N intake and it sounds awesome!!! Didnt take too long to do it either. Totally worth it!
  14. Mar 26, 2007 at 2:36 PM
    06tacoma
    06tacoma Well-Known Member
    Tampa FL
    06 PreRunner SR5 XS-P Trd Longbed Double Cab
    20" enkei wheel,BFG G-Force tires, BHLM, Smoked tail lights, 2 RE Audio 10s, Quantom 900watt amp,10000K HIDs headlights and fog lamps,Borla exhaust, Borla drop in filter,Debadged tailgate,Painted black tacoma badges
    so which k&n intake did you use i was looking and there are a quite a few to choose from
  15. Mar 26, 2007 at 3:25 PM
    Andrew83
    Andrew
    Orange County, CA
    07 PreRunner DCSB
  16. Mar 26, 2007 at 4:01 PM
    06tacoma
    Tampa FL
    sounds good thanks for the info i was thinking about getting the k&n intake along with the tornado and see how it goes
  17. Mar 26, 2007 at 4:03 PM
    Andrew83
    Andrew
    Orange County, CA
    07 PreRunner DCSB
    I was thinking of the tornado spacer also, let me know what you think when you get it installed.
  18. Mar 26, 2007 at 4:15 PM
    06tacoma
    Tampa FL
    i defenitly will i have heard alot of good things about it
  19. Jun 3, 2007 at 12:34 PM
    robert
    robert Active Member
    Yes it does, unless you go with a Toyota TRD air intake. Preferibly installed by Toyota. Save the original parts in case of problems!!!!!!!
  20. Aug 30, 2007 at 9:40 PM
    tacomaclay
    tacomaclay Well-Known Member
    SR5 4x4 04
    Flowmaster exhaust, K&N 77 series intake, kobalt aluminum toolbox
    I got one and it looks cool sounds cool and runs awsome.
