KB Voodoo AluMax Rack Install with Diamondback Cover - Photo Heavy
Discussion in '3rd Gen. Tacomas (2016+)' started by Papadave418, Oct 1, 2018.
  1. Oct 1, 2018 at 9:49 AM
    Papadave418
    Papadave418 [OP] Well-Known Member
    Dave
    Livermore CA
    2018 TRD Off-Road Premium Package DCSB Silver Sky
    Kings and a Pull Kitchen!
    AluMax Tall Long Bed Rack Install On A Short Bed Diamondback Cover
    When I bought my 2018 in Feb I ordered a Diamondback SE cover as I was signing the papers and I love this thing. Keeps my work equipment clean and dry and this light version can still hold about 500lbs. I started with KB Voodoo’s high bars (which are for sale) and recently just purchased @kbvoodoo AluMax tall long bed rack for my DCSB truck.
    I wanted a system that worked with my cover, gave me a ton of strength and mounting options, plus my roof top tent. As this truck is my DD I needed it to come off and on easily and with the tonneau brackets it’s just 4 bolts. Plus I also purchased the cargo tray which is awesome! Here’s how it looks now from the front
    In order to do all this I had to relocate the front lock 1.5 inches backwards to make room for the cargo tray crossbar. I sealed with two 1.5 inch washers. I moved the tie downs as well.
    Locking arms are easy to adjust
    The DD profile is minimal leaving the tonneau brackets in place. I also have fork mounts and D rings on my cover for my mountian bikes
    The rack is light! 55 pounds and the cargo tray is 49 pounds
    I looked at all these hoist and pulley options and realized the easiest solution was 4 binding style tie downs. $30 for the straps and eye bolts. They each can hold 300lbs and the rack is 104lbs and once I put my tent on then it will hoist the rack and tent together. It’s easy to lower down and 4 bolts later I’m ready to roll.
    I opted for the KB Voodoo bike mounts which are solid!
    I regret not getting KB Voodoo’s Hi-Lift mount, I struggled with this one but love having it on the inside and yet accessible. Nice to have though I hope not to use it.
    5E6DB4B3-9042-47C7-B05D-A9626B5AE2CD.jpg 8DD846EB-8FAF-4078-A593-A2F0DA883276.jpg
    I also added 2 extra side boards to double them up for looks and mounting options. Each side has a 3 gallon Rotopax and I did not want the Rotopax lock for a couple reasons. I don’t need another key in my life, they are almost twice as much as a standard mount, and they can rust up. So I got a 3 pack of combo gun locks. Easy and the perfect length to keep my gear safe. Obviously no lock is 100% safe.
    FSDC 14" California-approved Combination Cable Gun Lock 3-Pack https://www.amazon.com/dp/B071412HWC/ref=cm_sw_r_cp_tai_WBKSBb7G9ZNTP
    723C1A1F-B5B9-419D-8D48-813A399C9BB2.jpg 27B010BA-1952-407A-AFEB-3CC8CAF27F59.jpg
    I bought 2 small Plano Sportmans Trunks and they fit EXACTLY PERFECT in the tray, seriously like they were meant to go there. I’m doing 2 as the center would be hard to fit, plus gives me room for my water jugs. Cargo net for smaller items. Such a great use of space.
    Plano Molding 1719-01 68 Quart Tote (OD Green) https://www.amazon.com/dp/B007TOHIJQ/ref=cm_sw_r_cp_tai_0CKSBbNNT63VT
    185E2B74-9020-467E-A60F-4C009CE0C802.jpg 9441033C-CB3B-479E-AB2B-3C775BC7378E.jpg
    The cargo tray slides out nicely for access
    BD52BD28-F3C3-44DF-BCDF-EB36CE09E3BD.jpg 6A3BA698-1B2B-4B4F-B2A8-1D631FEF22AF.jpg
    Here is how the tall rack lines up with the roof
    I added crossbars under the main supports for my style of roof top tent.
    Overall the powder coating seems more durable than my previous high rise bars.
    One last shot of the clearance for the front lock relocation. Just remembered those 2 holes I need to seal haha
    Thanks for reading along and I hope the photos help answer questions you might have and inspire you dream a little for your set up. :)
    https://youtu.be/Qike5D_Msjk
    Not directly related to the rack and cover, but I upgraded my off-road kitchen. The response has been strong so I’m thinking about doing it as a side hustle now. Minute 3:30 the kitchen comes out, for reference I have an iKamper now and I made a low profile slide to get my Dometic 75DZ under the cover next to the kitchen
    https://youtu.be/UmMUiLCtzKg
    June 2021 edit*******
    I LOVE MY RACK STILL!! I added full extension 56” locking sliders and added to the rear portion of the tray for more cargo space. I get asked A LOT about how I mounted my iKamper to the rack. My rack and tent stay together as a package so I drilled through my cross members and used a single bolt at each corner through the track hardware they provide. Each bolt has a nylon lock nut and they have never come loose, it’s been super solid. You’ll see I added a black square tube under the tent as a spacer to lift the tent a little so the tent clears my shark fin better when hauling through Baja! :D
    74736330-1843-416D-856B-DC24B0CC08F2.jpg 409C5EEE-95E4-46C5-98A3-647C7EA5A75E.jpg 67D51522-E036-4894-9478-010A81B25BDB.jpg
    https://youtu.be/kmXNPBMyW_U
    Crosbaugh, =JSG=, Hutch72 and 48 others like this.
  2. Oct 1, 2018 at 10:49 AM
    ebertdav
    ebertdav Member
    David
    2017 Tacoma TRD Offroad
    Nice. Looking good.
  3. Oct 1, 2018 at 10:57 AM
    WMDtech
    WMDtech Well-Known Member
    Nate
    TN
    2018 TRD OR 4X4, White, DCSB
    None... sigh
    I dig it... a lot
  4. Oct 1, 2018 at 11:35 AM
    Sharkfrog
    Sharkfrog Well-Known Member
    Cameron
    Modesto, CA
    2013 DCLB Sport Magnetic Grey
    She ain't stock anymore.
    I dig it!
    Papadave418 [OP] likes this.
  5. Oct 1, 2018 at 11:41 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Looks great!!
    A rag with WD40 will clean that anti-seize off.
    zcweisman and Papadave418 [OP] like this.
  6. Oct 1, 2018 at 11:46 AM
    roguegs
    roguegs Well-Known Member
    Angelo
    3rd Gen 4Runner
    Went from 3rd gen taco to 3rd gen runner
    Much clean. Very like.
  7. Oct 1, 2018 at 11:55 AM
    CalTacoma09
    CalTacoma09 Well-Known Member
    Manteca, CA
    09 TRD Sport DCLB 4x4 Barcelona Red
    A lot of crap and too much money spent
    that looks good. :thumbsup:
  8. Oct 1, 2018 at 12:20 PM
    Papadave418
    Dave
    Livermore CA
    That stuff is hard to get off black, I will use your tip for sure!
  9. Oct 1, 2018 at 12:31 PM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
  10. Oct 1, 2018 at 12:32 PM
    Aggiesdm
    Aggiesdm Well-Known Member
    San Antonio
    17 TRD OR 4X4
    SnugTop topper, WeatherTec mats, thats all for now
    Nice looking rig for sure. I'm jealous and interested in checking out this rack!
  11. Oct 1, 2018 at 1:51 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The WD40 cuts right through it.
  12. Oct 1, 2018 at 3:24 PM
    tommy_tacoma
    tommy_tacoma Member
    Nice job! I was looking for a solution to the tent crossbar issue with the long bed rack. Currently I have my tent opening backwards over the tailgate so it could be mounted to the rack, but I see you added some crossbars underneath. What did you use for the crossbars?
  13. Oct 1, 2018 at 3:43 PM
    Papadave418
    Dave
    Livermore CA
    I bought and cut some 1” steel bars, drilled and bolted them to each other, then drilled and bolted them to the main support. I opted to mount my homemade crossbars under to reduce the height of the RTT. I currently have a soft top RTT but next month hoping to move to a hardshell like an iKamper. More aerodynamic and ease of set up.
    The steel bars work and much cheaper and more customizable than a Thule bar or something similar.
  14. Oct 2, 2018 at 12:04 AM
    Hawaiianwargod
    Hawaiianwargod Member
    2018 TRD OR
    Very nice!
  15. Oct 2, 2018 at 5:02 AM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    Very well thought out. I like your ideas. :thumbsup:
  16. Oct 2, 2018 at 10:28 PM
    Papadave418
    Dave
    Livermore CA
    Worked really well!
    Thanks I am pretty happy with how it’s turning out
  17. Oct 4, 2018 at 8:29 AM
    Papadave418
    Dave
    Livermore CA
    FYI when building the cargo tray the bolt direction is very important. I had 2 bolts reversed and it was limiting the cargo tray extension. I reverse their direction so the slides would clear and it pulls out 32” which is really nice to access the gear.
    Landpirate likes this.
  18. Oct 5, 2018 at 9:30 PM
    Papadave418
    Dave
    Livermore CA
    Camping up by Bald Mountain CA. Rack is awesome. I loaded all my gear and with the cargo tray I had extra room. Never happened before.
    F926EEA9-5CA5-45D8-BA65-02CEB7A452C5.jpg CC77D38C-9BFB-4E14-B222-CEC421751F8A.jpg A9336291-862B-41EA-B680-729239363C22.jpg DFB11516-2649-4B4A-8A67-5C00CD977986.jpg DA6A0D55-0F58-4049-B17B-DB94312AEDC9.jpg
    Landpirate and KB Voodoo like this.
  19. Oct 11, 2018 at 8:55 PM
    Papadave418
    Dave
    Livermore CA
    8200’ up in the Sierras where only 4x4’s can go. No parking lots, no crowds, no worries
    34603830-2383-411F-A476-0D40C056F199.jpg 06027367-2F4E-4232-8EBF-4595A861F6BF.jpg
  20. Oct 13, 2018 at 8:02 PM
    Papadave418
    Dave
    Livermore CA
    Just did a rig walk around with Michael from Overland Bound today on a DD that converts to an overland rig. Gave some in-depth props to @kbvoodoo for his rack and cargo tray which Michael geeked out on. I hope it helps with sales for a great product. Your AluMax is a next level rack my friend.
    The video will post Sunday night on Overland Bound’s YouTube channel A8D3508A-48A9-4721-9696-94352D451013.jpg
