KB Voodoo AluMax Rack Install with Diamondback Cover - Photo Heavy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Papadave418, Oct 1, 2018.
  1. Aug 11, 2019 at 6:29 AM
    #161
    Papadave418
    Papadave418 [OP] Well-Known Member
    If I didn’t put the window poles for that side on I could, but I usually just pulled the bikes off since it takes just a minute or so
    Hextall[QUOTED] likes this.
  2. Oct 15, 2019 at 2:21 PM
    #162
    Papadave418
    Anybody build a freestanding hoist to remove their RTT/rack?
  3. Nov 13, 2019 at 11:53 PM
    #163
    Fletcher37
    Fletcher37 Well-Known Member
    PNW
    @Papadave418 Great thread. Lots of great build ideas and inspirations.
    I'm curious if you are running any bed stiffeners? I'm wondering if a bed stiffener and installing a long bed rack on my DCSB Tacoma will interfere with each other as they may share the same mounting area at the rear.
  4. Nov 14, 2019 at 4:50 AM
    #164
    Papadave418
    Personally I have not found a need for bed stiffeners. The rack locked into place creates a boxed in frame that should be stronger than a L bracket could ever be. As my rack goes on and off I’ve never noticed any issues with my bed sides bowing out.
    As to your question of interference, with the @KB Voodoo tonneau bracket I had to add about 1/4” of washers behind it as I screwed it into the rear off the bed so that the bracket would remain vertical when tightened down. I have not looked at stiffeners but perhaps given its thickness (and if they share the same mounting bolt) they might play nice together
  5. Nov 14, 2019 at 10:11 PM
    #165
    Fletcher37
    PNW
    Yup, looking at photos of the stiffeners and where you are attaching the tonneau brackets, I think they might play well. I appreciate your reply!
  6. Nov 20, 2019 at 12:15 PM
    #166
    Papadave418
    No problem!
  7. Dec 24, 2019 at 3:57 PM
    #167
    Fletcher37
    PNW
    Well... fuu....uudge.
    Putting a long bed Max Modular rack on a DCSB with a Diamondback HD bed cover. The tiedown handles are in the way.
    jookdoree likes this.
  8. Dec 24, 2019 at 4:00 PM
    #168
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Those are $2 plastic tie downs. Remove them and plug the holes, or you may be able to get a lower profile version online somewhere.
    Fletcher37 and Papadave418[OP] like this.
  9. Dec 24, 2019 at 5:10 PM
    #169
    Papadave418
    I moved mine, I figured the rack was more essential than the location of my cleats. I found my old photos D0BB4529-9D64-4706-AE49-72A6DCF7EBA8.jpg9BEC2E68-5F25-4A91-BEC2-9DA76920B7D2.jpg
    KB Voodoo likes this.
  10. Dec 24, 2019 at 7:43 PM
    #170
    Fletcher37
    PNW
    Yup, I just removed them and replaced the bolts/washers and added a little silicon to keep things sealed. Otherwise, the installation was pretty drama-free.
    I have Total Chaos bed stiffeners and attached the rear tonneau brackets to the top bolt against the stiffener. Works okay there with no spacers. I replaced the stock M6 25mm bolt with a longer M6 35mm. Wish I could use a bigger bolt but I can't move the bracket any more forward because the bed stiffener top mount would be in the way.
    Papadave418[OP] likes this.
  11. Dec 24, 2019 at 10:07 PM
    #171
    Papadave418
    I didn’t reuse the M6 bolt as it’s pretty small, I drilled out the M6 and put a larger bolt and nut in to make it stronger. I had put in an M6 but that was longer as well and it snapped
  12. Jan 12, 2020 at 2:07 PM
    #172
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
  13. Jan 12, 2020 at 2:51 PM
    #173
    Jdizzy92
    Jdizzy92 Beer.taco
    Bay Area, CA
    2017 Toyota Tacoma TRD Off-Road
    -BFgoodrich KO2 285/75/16 - SCS Ray10 16" - Fox 2.5 2.5" lift and Icon add a leaf springs - Camburg UCA - TRD Pro Skid plate - CBI Rear skid plate - BAMF rear diff skid plate - Heavy Metal Off Road rock sliders - KBVoodoo Cross high rise bars - Undercover flex tonneau cover - Smittybuilt RTT - Pop N Lock - Anytime Front camera - TRD Pro Grill
    Yep, I have one for my sideyard and I built electric hoist in my garage. Since you live near by. You can come by and I can show you my setup.
  14. Jan 12, 2020 at 7:03 PM
    #174
    Papadave418
    Glad that @KB Voodoo replied to your question about his rack systems because his is great. My rack goes on and off easily and quickly with a hoist, and my hard tonneau cover thing comes off in 5 minutes with a 9/16” socket so I can haul taller objects. Secure tonneaus like diamondbacks allow me to carry and store things of value in my bed, or haul on top of the cover with gear below. That’s how I use my truck as a truck.
  15. Jan 12, 2020 at 7:05 PM
    #175
    Papadave418
    Thanks I ended up building a pergola style hoist for my rack and kitchen drawer. So much nicer to quickly change up my truck
    xsf18cdf likes this.
  16. Jan 12, 2020 at 8:55 PM
    #176
    Jdizzy92
    Jdizzy92 Beer.taco
    Bay Area, CA
    Nice setup. Like you have a roof to protect from the rain when you have to off load your truck. Off loading from a trip is already not fun but doing in the rain makes it worse. I went with a 1 ton gantry on wheels in my side yard and I reinforce my runners in my garage to hang an electric 440 lbs. hoist to store my RTT.
    https://www.instagram.com/p/B7PzSaKg1X6/?utm_source=ig_web_copy_link
  17. Jan 12, 2020 at 9:46 PM
    #177
    Papadave418
    That’s nice it can hang the whole time, great work
  18. Jan 13, 2020 at 5:08 AM
    #178
    QuadCop
    QuadCop Member
    @Papadave418 Apologies if I missed it, but would you share your overall clearance height with the iKamper mounted?
    Thank you sir, I love your set-up and your information will really help guide my build.
  19. Jan 13, 2020 at 7:39 AM
    #179
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    I'm not sure what you're confused about. All of our bed racks are here: https://www.max-modular.com/shop-max-modular
    Our TACO Max racks are made specifically for the Tacoma. We make them in steel and aluminum. We offer 10", 14", 18", and 22" tall racks. We offer those in 46" and 58" lengths.
    If you have any specific questions, let me know.
    Accessories are towards the bottom of the page.
  20. Jan 13, 2020 at 8:18 AM
    #180
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The supports cannot be removed. If you need to load tall cargo, simply remove the rack, it comes out by removing four bolts.
    Rack weights are shown on our website. Load ratings are also shown on our website.
