KB Voodoo Remote Start Review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by winston50, Dec 10, 2016.
  1. Feb 13, 2018 at 11:57 AM
    #61
    TRDFerguson17offroad
    TRDFerguson17offroad New Member
    2017 TRD off-road
    Did you take any pictures of how you tapped in?
  2. Feb 13, 2018 at 11:57 AM
    #62
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It uses your factory fob, so it has the same range as that would have.
  3. Feb 13, 2018 at 12:56 PM
    #63
    ratcityrain
    ratcityrain Well-Known Member
    Seattle, WA
    2017 Double Cab Off Road
    OEM Running boards |oemassive headlights | winjet tail lights | led lighting | hid headlight & fogs | oem tri-fold Bed cover | Custom dual JL Audio 10tw3-d4 sub box and custom amp rack | black off road wheels | painted oem grille | jbl door speakers |
    Range is ok on oem remotes, hence why I went with the Smart start so I could use my cell phone to start my truck
  4. Apr 9, 2018 at 1:40 PM
    #64
    kata_batic
    kata_batic Member
    Edmonton, AB
    2017 AC OR
    Just installed this today. It’s not particularly difficult at all just need to be semi-confident with your wiring skills. Things that I found that dont seem to be common:
    -Those plastic t splices are retarded. Dont bother
    -Toyota doesnt leave an awful lot of slack in the wires. Take your time and make sure you have the correct wire. Read the instructions, read them again, read them with your fingers on the wire, then read them when you connect.
    -I used butt splices. Two wires in one side, one in the other. Worked brilliant.
    -if you cant butt splice (not enough room, etc. ) strip, twist together and solder. Wrap tight in tape then zip tie so tape doesnt unravel.
    -Take your time.
    Otherwise, great price, good 2-beer evening project.
    ratcityrain, Hank Heel and KB Voodoo like this.
  5. Jan 9, 2019 at 4:44 PM
    #65
    epack236
    epack236 Well-Known Member
    2018 BBP TRD OR
    Question for anyone that installed this:
    I have tapped all the wires listed in the instructions, and the video, but I have a purple/yellow wire that I cannot find any reference to. What is up with this wire?
  6. Jan 9, 2019 at 8:48 PM
    #66
    ratcityrain
    Seattle, WA
    I just went through all my drawings and diagrams and I do not see any wires that are purple/yellow. You may want to contact kbvoodoo
  7. Jan 9, 2019 at 8:53 PM
    #67
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We already took care of him, but thanks for looking into it.
    ratcityrain[QUOTED] likes this.
  8. Jan 9, 2019 at 8:53 PM
    #68
    epack236
    2018 BBP TRD OR
    I sent them an email, got a pretty quick reply with the answer.
    The purple/yellow wire is not used, at least for 2018 smart key.
    They need to update their instructions, 2018 use different CAN wires, and the only reference is on the second page in one of the images. Front page still says to use the OBD2 connector which is incorrect for 18+.
    I ended up tapping the wrong wires and having to swap then when it would not program.
  9. Jan 9, 2019 at 8:55 PM
    #69
    ratcityrain
    Seattle, WA
    Glad you got it figured out. I have a '17 so there must be a slight difference between '17 and '18. Good to know.
  10. Jan 9, 2019 at 8:55 PM
    #70
    epack236
    2018 BBP TRD OR
    Yup, thank you!
    I recommend updating instructions ASAP to clear up the purple/yellow wire and add some clarification for different years on the front page. I read through the packet several times but the red 2018 square wasn't quite enough to avoid mistake the first time around.
  11. Jan 9, 2019 at 8:57 PM
    #71
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The instructions should be up to date. This is the first we've heard of an issue.
    We have three more units in stock. When they're gone, we're pulling the plug on this project. Electronics is not what we want to focus on.
  12. Feb 12, 2019 at 10:59 AM
    #72
    Tacoma<318
    Tacoma<318 New Member
    Nicole
    '17 Toyota Tacoma Limited 4x4
    Anyone know where to get one from now? KB Voodoo is not carrying them anymore
  13. Feb 12, 2019 at 11:01 AM
    #73
    epack236
    2018 BBP TRD OR
    12v solutions and N2 have plug and play options.
  14. May 20, 2021 at 2:03 PM
    #74
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    @KB Voodoo you happen to have instructions laying around by chance? Just picked up a used remote start and didnt come with instructions. Thanks!
