KC HiLiTES Chaselight Bar
Discussion in 'Product Reviews' started by erok81, Oct 3, 2017.
  1. Oct 3, 2017 at 12:36 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    I recently installed a KC HiLiTES chase bar on my Tacoma (thanks @Taylor@KC HiLiTES) . I grabbed it for a few reasons. My tent is on full time so I wanted to move the third brake light out so I still had one. I wanted a bright reverse light. Plus the chaselight is cool. So why not. :notsure:
    Install is fairly straightforward. It has a main power wire then different wires for different setups. Here are the options they give you (I can't find the instruction page so you get an image instead):
    I had to google the mfg'r of the light bar to figure out how to attach the brackets. I'll save you the trouble. You pull the non corded end off and slide the bolts in. Then the brackets (sold separately) bolt to those. You can either mount so they face out like in the pic or tucked in. I chose tucked but don't have a pic of that.
    Remove these:
    Slide bolts here:
    Attach brackets:
    I hooked mine up to be switch for reverse and amber. But tails and brake lights for the two red options. You can't really tell from the photos but the two reds are quite different. Pictures of lights is kind of tough, so here go.
    Taillight at night:
    Brakelight at night:
    Taillight daytime:
    Amber daytime:
    Reverse daytime:
    Amber and taillight daytime:
    Specs from KC:
    -Multi Function Integration and Design:
    • Red LED Tail & Brake Lights with Blinker Capability
    • Amber LED Dust Lights with Strobe Capability
    • White LED FloodLights
    -Lightweight Extruded Aluminum Housing for Maximum Heat Dissipation and Durability
    -Weather Resistant Enclosure and Shatter-Proof Polycarbonate Lens for Maximum Durability
    -40° Spread and 180° Flood Beam Optics
    SPECIFICATIONS
    -LED Source: 4W Cree LED
    -Raw Lumens: 4,500 lm
    -LED Color: Red, Amber, and Clear LEDs
    -Amp Draw: 5.0A (max draw)
    -Voltage: 12V DC
    -Certifications: SAE J595, CT13, SAE J1119
    -Product Dimensions: H - 1.22" x L - 28.14" x W- 2.25"
    I think that's about it. I'm happy with it so far. Let me know if you have questions. :cheers:
    Rd62, mccombsworld and MostEpic like this.
  2. Oct 3, 2017 at 12:41 PM
    MostEpic
    MostEpic IG: letthemeatdust
    Los Angeles
    2013 PreRunner DCSB
    Party in the front Party in the rear
    What kind of switches are you running? Can you wire to flash one or both ambers?
    Thanks, been debating a bar or just singles.
    EDIT: just read you listed strobe capability
    erok81[OP] likes this.
  3. Oct 3, 2017 at 12:52 PM
    erok81
    Imposter
    I am using a switch pros for everything.
    And yep. As you saw. You can only strobe both though. Not individually. I was going to use them as signals but decided as a light was better.
  4. Dec 6, 2017 at 1:01 AM
    OnlyTaco
    OnlyTaco Well-Known Member
    That's pretty cool. I was looking for a similar solution, I have a mid rack kb voodoo rack as well. Instead of the tent however, I'm going to put my spare tire up there and a couple of water/fuel jugs. This is a perfect solution to have a functional 3rd brake light again. Thanks! Would you mind letting me know how you wired it up for brake light function?
  5. Sep 22, 2018 at 8:30 AM
    Papadave418
    Papadave418 Well-Known Member
    I’ve been looking at these, and maybe @TaylorU can answer, are these the only street legal chase bars? There’s a couple of brands like xpsrites and rlbstore.com that sell similar for half price, but I want what’s quality. Just curious on your input.
  6. Oct 11, 2018 at 2:40 PM
    Papadave418
    I bought one as well, did you ever do turn signals? Or just brake lights and switch on ambers?
  7. Oct 11, 2018 at 2:41 PM
    erok81
    Imposter
    Mine’s amber switched. Unless you take apart the bar and rewire it, the ambers are hooked together. I originally was going to use them as signals too.
  8. Oct 14, 2018 at 11:04 AM
    Rd62
    Rd62 Well-Known Member
    2014 DCLB TRD Sport
    I really like those
  9. Oct 24, 2018 at 11:15 AM
    dualstroke
    dualstroke Well-Known Member
    2017 OR AC
    Looks great. Good idea and multifunctional. Thx
  10. Mar 13, 2020 at 1:46 PM
    NewEnglandTaco
    NewEnglandTaco Member
    2016 Quicksand TRD Off Road
    Hi sorry to bring up a dead thread but could you go into more detail on how you wired it up? I have a Switch-Pros 9100 and ordered the chase bar today
  11. Mar 14, 2020 at 5:24 PM
    erok81
    Imposter
    I wired the reds into my tail lights. The amber and white into the switch pro.
    it’s really easy. Each color light has its own wire. So no different then hooking up multiple lights.
  12. Mar 14, 2020 at 5:24 PM
    erok81
    Imposter
    If you have questions when doing it let me know. :D
  13. Mar 25, 2020 at 11:01 AM
    NewEnglandTaco
    Did you run the red to where the brake light wire is under the hood or did you go all the way to the rear?
  14. Mar 25, 2020 at 10:19 PM
    erok81
    Imposter
    Mine is mounted on my rack at the rear after my tent. So it’s pretty close to the tail gate.
    All of the red lights (dim to tails and brights to brakes) I ran to the passenger side tail light. The reverse (white) and amber I ran up to my switch pros under the hood.
