Kc light install help
Discussion in 'Lighting' started by tacomaLS53, Jan 8, 2014.
  1. Jan 8, 2014 at 2:00 PM
    tacomaLS53
    tacomaLS53 [OP] Well-Known Member
    I'm wiring my lights that I put on my bull bar and I've got a few questions.
    1) How/where do I put the switch in? It won't fit in one of those blank ones
    2) how did y'all get the wires into the can to go to the switch?
    3) and how did you connect the white wire to power?
  2. Jan 8, 2014 at 2:07 PM
    Large
    Large Red
    IMO, I am a professional electrician and if you have to ask these questions, you shouldn't be wiring anything. But I don't like to come and piss in someone's thread so here goes,
    1: You might have to trim the holes to make the switch fit.
    2: There is several ways, but there is a rubber grommet behind the e-brake to the firewall.
    3: cmon man..
  3. Jan 8, 2014 at 2:31 PM
    tacomaLS53
    I know there's a grommet but I don't know how to get it in and I know I have to connect it to the battery but there's no way to connect it in the kit!
  4. Jan 8, 2014 at 2:35 PM
    Leoffensive
    Leoffensive Well-Known Member
    Leo
    San Diego, CA
    2007 prerunner TRD sport
    Icon 2.5 coilovers with resi, Custom OMD rear leaf pack, Pelfreybilt IFS skid, Magnaflow muffler
    For the switches yes your gonna have to trim. I used a dremel for mine.
    As far as wiring I'd assuming you'd use connectors
  5. Jan 8, 2014 at 2:37 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Put a ring connector on it and connected to the red side of the battery.
    Use a coat hanger to punch thru the grommet.
  6. Jan 8, 2014 at 2:44 PM
    tacomaLS53
    How did you get the wires through the firewall?
  7. Jan 8, 2014 at 2:52 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Same way as i described above. Use a coat hanger to punch thru the silicone in the grommet.
  8. Jan 8, 2014 at 2:55 PM
    Leoffensive
    Leo
    San Diego, CA
    Ramon said it. Use the coat hanger to punch through the gromet
