KC Slimlights - HELP!
Discussion in 'Lighting' started by Nick003, Jan 14, 2013.
  1. Jan 14, 2013 at 2:46 PM
    Nick003
    Nick003 [OP] Member
    Nick
    Vancouver, BC
    01 Dbl Cab v6 4x4
    Not much, yet.
    So I'm just hooking up my KC Slimlights, and I've got an issue. I followed the diagram, and upon grounding the switch, I blow the 5amp fuse. The lights work without grounding the switch, but the light inside the switch won't work without it. On initial set up, it worked a few times, but then blew. When replacing the fuse, it blew as soon as I hooked up the ground again. Do I have something backwards?
  2. Jan 14, 2013 at 3:22 PM
    Nick003
    Nick003 [OP] Member
    Nick
    Vancouver, BC
    01 Dbl Cab v6 4x4
    Not much, yet.
    OOOOOOOOOOHHHHHH I think I just figured it out.
  3. Jan 14, 2013 at 3:47 PM
    Ronn
    Ronn Well-Known Member
    Ron
    Northern Ontario
    2007 DCLB 4x4 SR5
    Westin bullbar, KC slimlites, Mini D2S headlight retrofit, 5100 front @ 1.75 and 5100 rear, Wheelers HD leaf pack
    I would advise against wiring it that way, the switch is getting the full current from the battery and could pose a fire risk, getting hot, melting etc.
    Try it like this, it's how KC recommends to wire and if you pull a low amp draw to power the switch from say the windshield wipers you won't kill your battery if you forget to turn the switch off. You would have got a relay and all the supplied wiring with the kit.
