Keep track of your smart key.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by treejohnny, Nov 22, 2015.
  1. Nov 22, 2015 at 4:30 PM
    treejohnny
    treejohnny [OP] Well-Known Member
    2016 ACOR
    I started the truck with smart key in pocket, went inside purposely left smart key on table and drove away. As I drove away the truck beeped at me and instrument panel told me that key was not detected in truck. It looks like I could drive as far or fast as I wanted without smart key. I would expect to be SOL if I was to shut it off.
    I am sure it is plausible to jump into running, warming truck without key, impossible to drive away not knowing you did not have key with you. This was something I needed to know.
  2. Nov 22, 2015 at 5:04 PM
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    You needed to know and now you do. Lol
    Yup if you would have turned it off sol would have been about right.
  3. Nov 22, 2015 at 5:09 PM
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    One would think they would've at least had enough sense to make the truck shut off if you pushed the brake without the smart key present similar to a lot of remote starts. Not really sure there's a scenario where you would want to drive without the smart key.
  4. Nov 22, 2015 at 5:12 PM
    tdnick
    tdnick Go Vols!
    Alabamer
    2018 Cummins 4x4
    When you go out drinking heavily that night for a one way ride ha
    TacoManz, NC Rick and gsxxr like this.
  5. Nov 22, 2015 at 5:12 PM
    gsxxr
    When I test drove my lexus the salesman held the key. Other then that I have no clue either.
  6. Nov 22, 2015 at 5:23 PM
    treejohnny
    2016 ACOR
    When we go on road trips it has been a practice to use a hide a key. It was easy fix to family getting separated and still have access to stuff in truck (don't like to travel without my own security system). This procedure will have to change with the smart key.
    So if I separate the key from the FOB, can the truck be started with key only?
    I read that we can shut down the proximity side of the FOB, maybe that is best for traveling.
  7. Nov 22, 2015 at 5:26 PM
    allvuong
    allvuong Well-Known Member
    Of course your car was going to drive away even without the key in the car. It's to keep your car from turning off if the battery dies in the fob or its stops communicating for some reason. Wouldn't want it to turn off while your car is moving.
  8. Nov 22, 2015 at 5:34 PM
    PJnc284
    Garner, NC
    Wouldn't be any reason for it to cut off while in gear or moving. Just seems logical for security reasons to not allow the brake to be pressed while in park without the smart key present. You can still start the truck if there's an issue with the fob by touching the toyota emblem to the start button though.
  9. Nov 23, 2015 at 9:08 AM
    spp
    spp OC, Kalifornia
    OC California
    Key will only open the door. Holding down the lock button and pressing the unlock twice will put fob into a sleep mode indicated by 4 short red led flashes. Hitting any button will wake it up.
  10. Nov 23, 2015 at 9:13 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    no can start with key only....see link for your hide a key fix, i have one.
    http://www.amazon.com/HitchSafe-HS7...TF8&qid=1448298697&sr=1-10&keywords=safe+lock
